#127 |
Drives: 2015 frs
The jig is in the vice nice and level. Going to do more welding tomorrow. Hopefully I make decent progress.
#128 |
Drives: 2015 frs
I got the uprights welded. I wanted to tig them but I'm waiting on a gas lens kit so they got welded with the wire feed machine. Crossbars, and control arm mount will be next. Last will be the steering rack mount.
#129 |
Drives: 2015 frs
I changed the a arm portion on the jig to a more heavy material to resist distortion when welding the control arm mounts in. The unistrut pieces in front were the old ones. The new ones are 2 1/2" square tubing uprights welded to 2 1/4" horizontal pieces with holes through it representing the a arm location.
#130 |
Drives: 2015 frs
Made a little more progress. Control arm mounts made and tacked in place. It took all day just to make these four parts.
| The Following User Says Thank You to Zer0 For This Useful Post: | DIY (08-24-2019) |
#131 |
Drives: 2015 frs
I got a couple more things done on the front crossmember. Had a friend final weld the control arm mounts in place. I also was able to make the side angled supports and tack them in. 6 pieces left to get this thing in the car so I can build the mounts for the engine and steering rack.
#132 |
Drives: 2015 frs
Doing a little mock up on the crossmember as I build it.
#133 |
Drives: 2013 BRZ Limited 6MT
Sitting quite nicely so far. Good work!
| The Following User Says Thank You to ka-titties For This Useful Post: | Zer0 (08-30-2019) |
#135 |
Drives: 2015 frs
Crossmember minus the engine mounts . In the process of building them now. Lots of O.T. at work so probably 2 weeks out on getting those done.
#136 |
Great progress. I'm very keen to see the finished product.
| The Following User Says Thank You to ka-titties For This Useful Post: | Zer0 (09-09-2019) |
#137 |
Drives: 2015 frs
Started motor mount mock up.
#139 |
Drives: 2015 frs
I got the mockup done and tack welded in the uprights for the motor mounts.
| The Following User Says Thank You to Zer0 For This Useful Post: | DustinS (09-16-2019) |
#140 |
Man, this thing is gonna be wild AF
| Andy0323's Back To Basics Build Thread <Long Term Project> | andy0323 | Member's Car Journals | 15 | 02-02-2018 12:16 AM |
| long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 08:56 AM |
| Long term | Bt216 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-06-2013 11:58 PM |
| Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 02:18 PM |
| Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 09:55 PM |
