Old 08-24-2019, 11:19 AM   #15
CSG Mike
CSG Mike's Avatar
Please do not use a harness and bucket in a street car. You are compromising the safety systems designed to keep you safe.
Please do not use a harness and bucket on track without at least a half cage with harness bar. This method of using harness is for show cars only, and is NOT SAFE.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
CrowsFeast (08-26-2019), NoHaveMSG (08-24-2019), Racecomp Engineering (08-29-2019), timurrrr (08-24-2019), why? (08-24-2019)
Old 08-24-2019, 10:29 PM   #16
jayliu.jiayu@gamil.com
jayliu.jiayu@gamil.com's Avatar
Drives: 2017_86 2016_frs 2007_335i
if i add a harness bar. is it will be safe enough?
jayliu.jiayu@gamil.com is offline   Reply With Quote
Old 08-24-2019, 10:45 PM   #17
CSG Mike
CSG Mike's Avatar
Nope.
Old 08-24-2019, 11:44 PM   #18
Nope.
any link for install the seat safely ?
Old 08-24-2019, 11:55 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The problem is not the install of the seat.
Your OEM seat is designed so that it can collapse in a roll over that crushes the roof. A racing seat will be not and you will be crushed without a roll cage.
Old 08-25-2019, 05:44 AM   #20
so, its need a roll cage then.
Old 08-25-2019, 11:01 AM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Half cage with a harness bar min as CSG Mike said.
Old 08-26-2019, 03:35 AM   #22
thx for the help, slowly getting there!
Old 08-26-2019, 04:55 AM   #23
86MLR
86MLR's Avatar
For a street car, you only really want a half cage, with a full cage ingress and egress is a PITA (a full cage without side intrusion is stupid), plus without a helmet your head will open up like a smashed water melon if it comes into contact with the bar (window bar or front leg), seat design can negate this to a point, but visibility can be lost , harness bar is a given.
For a street car there is always compromises, BUT, never on safety.
Weld in is best, bolt in is adequate.
Good installation is paramount, welds, bracing, plating, bolts, if any of these points fail, the roll bar might not give any protection, or kill you even in a minor crash.
Seat mounting, same same, mounting points and seat angle.
Harnesses, if you are doing it, do it right, get a 6 point, your balls will thank you, mounting points, correct fixture position, both angles and points.
No point adding safely devices that are installed incorrectly, making them worse than OEM in a crash.
My 2 cents, go to a joint that preps race cars, NOT, your local tuner, or mate with a drill and welder.
Cool story (bro): when I was young and dumb I put in a 4 point, it worked OK, till I hit a barrier, then I basically ended up mostly in the foot well, turned out my seat angle was wrong (not enough angle) and the 4 point was actually the reason I turned into a submarine.
Be safe, have fun.
Old 08-26-2019, 09:19 AM   #24
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
If you are at all wondering why the installation is so important (and often unsatisfactory for bolt-ins) look at this picture closely (unless you're squeemish)
This was a bolt in cage that did not have proper reinforcement/bracing at the mounting locations. Notice that the cage just blew right through the floor pan and that there is no 'roof' anymore. Miraculously I believe that both the driver and passenger survived this crash uninjured but don't expect the same fate awaits everyone experiencing this failure.
EDIT: can't seem to figure out why the image is only visible half the times I load the page...
CrowsFeast is offline   Reply With Quote
The Following User Says Thank You to CrowsFeast For This Useful Post:
Old 08-27-2019, 01:13 AM   #25
Be safe, have fun.
so for the stx in autox and 4 trackday in a year
i may just need harness bar and a good hans right?
in my opinion, the only thing i changed is side airbag, and 6 points harness(only use it on track maybe)
it should be just safe as factory right?
did nothing but a seat, and stock seat belt is working just as before
Old 08-27-2019, 01:15 AM   #26
Be safe, have fun.
by the way any link for build a half cage ?
Old 08-27-2019, 02:42 AM   #27
86MLR
86MLR's Avatar
https://www.google.com/search?q=roll...obile&ie=UTF-8
I used a Bond bolt in half cage in my Skyline and a MX5 Plus bolt in in my, um, MX5
Old 08-27-2019, 10:57 AM   #28
ka-t_240
If you need a link to build one, you probably should not try to build yourself. Find a local fabrication shop and build something.
ka-t_240 is offline   Reply With Quote
The Following 2 Users Say Thank You to ka-t_240 For This Useful Post:
NoHaveMSG (08-27-2019), timurrrr (08-28-2019)
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 06:59 AM
Portland people meet with Seattle area people before going into ForumFest 2013? stockysnail Northwest 24 06-18-2013 06:19 PM
Passenger seat not sliding to let people out.. wparsons Issues | Warranty | Recalls / TSB 9 10-01-2012 07:28 AM
Seat fit for tall people? clubraf Scion FR-S / Toyota 86 GT86 General Forum 14 06-29-2012 10:51 AM
Pics of people sitting in rear seat glorydays FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 12-08-2011 04:54 AM
