Old 05-09-2019, 07:27 PM   #1
jayliu.jiayu@gamil.com
jayliu.jiayu@gamil.com's Avatar
Drives: 2017_86 2016_frs 2007_335i
To help people who wanna to change a seat
First of all, it is not safest way to do the seat until u combo
1. seat and bracket
2. harness
3.harness bar
4.roll cage
5.hans
6.helmet
as lots of common said.
i am totally agreed
but i have no problem pass the local auto x event as stx class
and local track"not racing just training use as they said "
the only thing i changed is the seat with no side airbag on the side and the stock seat belt working same as before
so u lost side air bag for sure, and people said it also not safe during the roll over"dont understand that part".
anyway, just sharing my experience for buying a seat.
and help people can study some thing from my mistake.
Hi all
over a past month for change the seat that wut i got
1.test fit
if u know someone already had the seat installed in their car, go test it out for the fitment. this is the most easiest way to find out ur size
and planning ahead for the harness if u wanna one, cause some of the seat come with the hole right under ur leg and some of them not
the main different which is 4 points harness or 6 points harness.
the seat with hole is for 6 pints harness, with out is for 4 points.
i recommend pick a seat with hole so u can easily change it.
2.pick a seat
u need measure ur waist and upper body for buying the right seat for u, i did my by test seat whatever the seat i can find, then i ask the owner which brand is the seat and which series is belong to, also the size for the seat. after that, i was searching the size on the internet for the seat i was testing. u should have a pretty good idea on the size for ur need by know at end
for example u should find something like this and pay attention on those number i had circled. that is the most important number for fit ur body, car, and bracket!!
3.find a bracket
once u narrow down the seat u wanna buy, u should looking for the bracket now, this is the most important part over all the process.
a good bracket should let u seat as low as the floor, and center with the steering wheel.
keep ur eyes on that number, this is how u know if the bracket will fit ur seat or not.
for the bride seat, they don't give u that number for any reason
buy i found when u go to their home page and select the seat u wanna, then the next task is for pick a bride bracket where they will told u which one will fit ur seat and ur car. very helpful info
http://bride-jp.com/en/seat/
now u should had a good idea on the bracket size
4.harness
the harness is the most important thing for ur safety
there r a lot of rules, some of them asking that angle. some of them r not.
i am not respond for any safely issues
Name:  harness angle.jpg
first of all, get ur angle right. follow the local track requirement.
and either buy a harness bar or mounting the harness on the chassis
i keep my stock seat blot and not really using the my 6 points harness
so i end up just using the hock on the top of the rear seat where there is a baby seat safety hock
Name:  rear hock point.jpg
the one in the mid had hock behind the rear seat from factory too
anyway
angle is one thing
harness bar is another
and hans is the important too
if u really get all them working right
here is my tho just give u a idea
for the side part of the harness,
i drill a hole at transmission panel and get the the hock blot installed on the right side
and take that factory seat blot cover at bottom, u will find there is the hock for factory seat belt, and i just hocked it in there.
the most difficult part is the lap part.
their is brake line and chassis structure right under the point for my drill point.
i guess it is cause they design it for left hand drive maybe
i end up with the cusco seat brace.
Name:  cusco seat brace.jpg
it fit perfect, but it may off the angle a bit, just a bit.
by the way, the stock seat belt should run thought the left side hole on the seat, my seat just fit me perfect or a bit tight. when i seat in the car, the stock seat belt fit me perfect like before.
here is the stock seat belt bracket
6.buy a resister
which is 3.3ohm u can get it in any electric store and tap for warp the resister
the drive side is very easy, nothing but the resister and take out the wires from factory seat
the passage side is not,
u need take all the above and also a pad between the stock seat and bracket, that is for trigger the air bag for passage side.
then u put it under ur bucket seat fiber pad.
http://www.ft86club.com/forums/showp...&postcount=448
here is the link who is explaining better than i for sure
7.need a zip tie
for clean up the harness and the wires under the seat
8.hardware
a lot of things come with the seat and the bracket in the package
a)but u still need 4 spacers to security the factory bolt for the chassis
b)1or3 large space for install the harness, this is goes under the car so pick something that not going to rust out. and apply some permit coating after u tight them up.
all in all
hope this is going to help, i study that in the hard way
bought one sparco ergo and sparco bracket and seat rail, which i find out it just too high, even higher than stock seat. i don't recommend it at all
so i bough another nagisa bracket which i really love it, but it was not fit my seat, just a 5 mm.
so i sold the sparco seat and went buy the bride zeta iii type L
compare those two seat, the bride has a better quality for sure
much better!!!!
i am 183 cm 42 waist with 90kg
my seat is bride zeta iii type -L
harness is sparco 6 point
bracket is nagisa double locked seat rail
jayliu.jiayu@gamil.com is offline   Reply With Quote
The Following User Says Thank You to jayliu.jiayu@gamil.com For This Useful Post:
HaXx (05-10-2019)
Old 05-09-2019, 07:47 PM   #2
CoolHandMoss
Drives: 2013 FRS
Wut the F dud u sey?
CoolHandMoss is offline   Reply With Quote
The Following User Says Thank You to CoolHandMoss For This Useful Post:
chickunfut (05-09-2019)
Old 05-09-2019, 07:55 PM   #3
15limited
15limited's Avatar
Reading the first couple steps makes my head hurt
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following 2 Users Say Thank You to 15limited For This Useful Post:
chickunfut (05-09-2019), FRSBRZGT86FAN (08-24-2019)
Old 05-09-2019, 10:21 PM   #4
StraightOuttaCanadaEh
Wes
are harnesses street legal in canada? If I was ever to get a bucket seat, I'd wanna use the stock seat belt.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
why? (08-24-2019)
Old 05-09-2019, 11:50 PM   #5
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Also follow the harness mounting instructions. The shoulder harness rear mount point doesn’t look right to me. Is that per the instructions? Angle appears too high.
Plus, harness without a half cage is generally considered unsafe... definitely less safe than using OEM 3 point belts.
Sleepless is offline   Reply With Quote
Old 05-10-2019, 03:35 AM   #6
86MLR
86MLR's Avatar
A fixed seat and a 6 point works well without a cage, until you crush your head, a 4 point works well till you submarine and find yourself in the foot well.
Yeap, some good advice on fixing a seat.
The Following User Says Thank You to 86MLR For This Useful Post:
15limited (05-10-2019)
Old 08-23-2019, 05:17 PM   #7
sry for my bad english skills
i will do it more carefully
everything is good now
nagisa double locked bracket
spraco 6 points harness
cusco seat brace
here is the over all for my mods and some pic on the set up
https://www.ft86club.com/forums/showthread.php?t=136068
Old 08-23-2019, 06:52 PM   #8
sry for the bad english, i did my best this time. was working on the car for a bit last month
Old 08-23-2019, 06:53 PM   #9
ok just be nice for a guy who is not native speaker maybe
i did my best this time hope it will help .
Old 08-23-2019, 06:54 PM   #10
yep keep the stock seat belt for sure
Old 08-23-2019, 06:55 PM   #11
yea, safety first. did it again to current my language
hope it will help others
Old 08-23-2019, 06:56 PM   #12
thats why u need hans and helmet and a 6 points harness
Old 08-23-2019, 07:17 PM   #13
86MLR
86MLR's Avatar
And roll cage
Old 08-23-2019, 07:19 PM   #14
And roll cage
right right right.
a racing car required
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 06:59 AM
Portland people meet with Seattle area people before going into ForumFest 2013? stockysnail Northwest 24 06-18-2013 06:19 PM
Passenger seat not sliding to let people out.. wparsons Issues | Warranty | Recalls / TSB 9 10-01-2012 07:28 AM
Seat fit for tall people? clubraf Scion FR-S / Toyota 86 GT86 General Forum 14 06-29-2012 10:51 AM
Pics of people sitting in rear seat glorydays FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 12-08-2011 04:54 AM
