Old 08-19-2019, 10:44 AM   #15
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Originally Posted by GrantedTaken View Post
So, replacing a stud is the same on front and rear?
No weird parking brake issues?
Just remove rotor and pop off the studs?
I didn't remove the parking brake shoe when I did mine.
JohnJuan is offline   Reply With Quote
Old 08-19-2019, 01:17 PM   #16
I don't think you have to for the front. There's plenty of clearance.
Old 08-19-2019, 06:21 PM   #17
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
If you reread in the rear you have to rotate the hub around to one area where there is clearance to get the stud in/out. But you don't have to remove anything extra at least for stock length studs.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
JohnJuan (08-20-2019), Overdrive (10-10-2020)
Old 08-19-2019, 08:11 PM   #18
GrantedTaken
Thanks for clarifying that, finch
GrantedTaken is offline   Reply With Quote
The Following User Says Thank You to GrantedTaken For This Useful Post:
finch1750 (08-20-2019)
Old 08-20-2019, 02:28 PM   #19
JohnJuan
JohnJuan's Avatar
Yeah, I took off one hub each front and rear, then noticed I didn't have to do the other one. Learn from my mistake.
Old 08-20-2019, 04:42 PM   #20
m86
Drives: FRS
I confirm that the parking brake doesn't need to be removed with stock studs. Just remove the brake rotor. You also don't need a press, just screw a wheel on (before putting brake rotor back) to pull the stud in.
m86 is offline   Reply With Quote
Old 08-20-2019, 05:52 PM   #21
finch1750
finch1750's Avatar
Use washers. Not a wheel
Clutch Dog (08-20-2019)
Old 08-20-2019, 06:25 PM   #22
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
I used a stack of washers. and a sacrificial nut. and then hit it with a dugga ugga.
it is very shade tree. but i had a split front lug out and new one in within 20 min.
the goal is to tighten down the nut on the washers and then have the nut draw the lug through while it is rotating on the washers. i typically like to run a few fat ones with a huge hole and then one that barely clears the new wheel stud
this allows the washer to deform a little when the stud is tight without stripping threads or stretching the stud (hence sacrificial lug nut)
Clutch Dog is offline   Reply With Quote
Old 08-20-2019, 07:22 PM   #23
m86
Drives: FRS
I didn't have enough washers so used a wheel. Nothing wrong with that if you torque up to the usual 90ft/lbs.
Old 08-20-2019, 07:56 PM   #24
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Originally Posted by YamahaR86 View Post
I just bought the $20 bearing press tool from harbor freight.
Took off wheel, caliper, rotor. Then use the tool to push it out, rotate the hub to push the next one out. There is a small gap without having to remove anything extra on the rear.
I 2nd this. I also did this. The tool can be used both to pop the stud out and to press the new stud on nicely too. I only have experience doing the front, though.
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
YamahaR86 (08-21-2019)
Old 10-07-2020, 11:56 AM   #25
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
Thanks for this, I installed my Konis & Eibach suspension and noticed I hated the OEM lugs. Ordered new ones and broke a stud trying to get the OEM lug off. Going to the dealer to get a stud, then doing this.
The videos I found had me taking the whole assembly apart, glad to see I won't have to.
e30cabrio is offline   Reply With Quote
Wheel stud replacement Dave-ROR DIY (Do-It-Yourself) Guides 267 01-21-2022 08:20 PM
South Bay Wheel Stud Replacement? HachiRo Northern California 4 02-04-2016 04:56 PM
Replacement Windshield w/ blue shade band? hmong337 Scion FR-S / Toyota 86 GT86 General Forum 51 08-27-2015 06:00 PM
anyone know if there's a rear window shade? nycfl123 Scion FR-S / Toyota 86 GT86 General Forum 18 03-07-2014 02:39 AM
Replacement Lug Stud/Wheel Hub swift996 Issues | Warranty | Recalls / TSB 3 08-30-2013 01:58 PM
