Old 08-19-2019, 10:01 AM   #1
Alpha86
Drives: 2013 Firestorm Red FRS
Serial Number Decoding
Hey guys, I just bought a blown FA20 from a twin and grinding trans with plans of an FI build. All is well, but I'm not 100% sure on what the model years of each part are, and neither does the guy I bought it from since he bought it off his friend. The engine might be a 2013, which is good since my FRS is 2013 and there'd be no issues with harnesses, and the trans might be a 2016.
Is there any way to verify what model years I have? Serial numbers, production stampings, etc? Thanks.
Alpha86 is offline   Reply With Quote
Old 08-19-2019, 12:23 PM   #2
solidsnake11
Drives: brz
2013 had short valves and the rockers are smooth on top of the pivots. Long valve has a circle on top of the pivot. Post a picture of the rockers.
solidsnake11 is offline   Reply With Quote
Old 08-20-2019, 09:36 AM   #3
Alpha86
Gonna have to get back to you on that, the engine is sitting on my garage floor upside-down lol
Old 08-20-2019, 09:39 AM   #4
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
https://www.carfax.com/blog/vin-decoding
BigTuna is offline   Reply With Quote
Old 08-20-2019, 11:21 AM   #5
Fred E
Drives: WRB BRZ
Years 2013 through 2015 have the same engine/harness connectors, so engines from any of those years would be compatible in your 2013 car. However, 2014 and 2015 engines had internal revisions that make them safer than 2013 engines, including removing the need for the valve spring recall. Keeping that in mind, discovering that the engine is out of anything but a 2013 would be preferable.
I'm not sure if the original car's VIN is actually etched on the engine, but that would clearly identify the year if it is.
Try finding the plaque pictured in this thread: https://www.ft86club.com/forums/showthread.php?t=128854
Fred E is offline   Reply With Quote
The Following User Says Thank You to Fred E For This Useful Post:
Tcoat (08-20-2019)
Old 08-21-2019, 07:22 PM   #6
Alpha86
It appears that the sticker was peeled off
I don't want to pull the valve covers off yet since it's not on a stand, I'll have to come back to that later. Hoping that the VIN is etched somewhere.
Old 08-23-2019, 10:08 AM   #7
wparsons
wparsons's Avatar
Slight clarification, the 2014/2015 engine revisions aren't the reason they don't need the valve spring recall. Only some 2013's are affected, and it's because of bad batch of springs, not a faulty design.
flickr
Fred E (08-26-2019)
ECU serial number aagun Software Tuning 3 05-24-2017 04:26 PM
Stock wheel serial number? Junbug Northern California 5 02-13-2016 03:52 AM
Stock wheel serial number? Junbug Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-11-2016 09:11 AM
FS Unichip with USB to serial cable robtan Engine, Exhaust, Bolt-Ons 6 08-04-2014 03:15 PM
Decoding BRZ Series Blue VIN Jimmy45brz BRZ First-Gen (2012+) — General Topics 4 07-20-2014 12:11 AM
