Old 05-21-2017, 11:55 AM   #1
aagun
Drives: 86
ECU serial number
Hi
I am looking for ECU serial number inside of boot mate or user mate or in the RAM .
Iam using sh72531 mate in frs/brz .
Master ECM or ABS serial number is ok too of i can use it in ecu mate and read it there
What iam try to do ? Using it like a reference
Thx
aagun is offline   Reply With Quote
Old 05-21-2017, 05:24 PM   #2
steve99
Use hex editor to compare boot MAT area from two different brz/86 ecu is their any difference ?? or same 0000-7FFFF
User MAT 8000-13FFFF unlikely to have any serial numbers as can be overwritten.
Maybe use the Vehicle VIN number its stored in ECU and is unique to each vehicle but in different area ??
Old 05-24-2017, 11:01 AM   #3
aagun
Drives: 86
I can't read user boot mate until now . I don't think Ecutek BRZEDIT OFT flashedit read it for public . It is privet .
I found user boot mate as a new base mate . I try find any sign of vin Number in it but to luck
I start read sh72531 user manual to get more information about a spical code
Market ecu flasher as above flashs user mate only . I am looking for a read/write code to send it to ecu for R/W in that area . By using RE in flasher app .
I believe the ecu store the VIN . Only no serials proved until now
Old 05-24-2017, 04:26 PM   #4
steve99
You can read/change vin with Toyota techstream software. Tactrix can be used with Techstream as the interface cable.
I have not investigated but VIN is likely in separate area of ECU maybe not in SH72531 chip.
If you have CAN buss sniffer you could sniff the requests on can buss when using Techstream to read/change VIN
http://www.ft86club.com/forums/showthread.php?t=35530
Stock wheel serial number? Junbug Northern California 5 02-13-2016 03:52 AM
Stock wheel serial number? Junbug Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-11-2016 09:11 AM
FS Unichip with USB to serial cable robtan Engine, Exhaust, Bolt-Ons 6 08-04-2014 03:15 PM
Serial of 8000 manufacturing date... Harvey Scion FR-S / Toyota 86 GT86 General Forum 24 06-14-2014 07:56 PM
What's up with the number 127.0? avusblue Scion FR-S / Toyota 86 GT86 General Forum 13 06-22-2012 08:02 AM
