Old 08-19-2019, 12:21 PM   #1
jslack
Drives: 2017 Red subaru BRZ Limited
Best spark plugs to get. OEM or another brand
Hello group. It's that time for my BRZ to get some new plugs and I was just seeing if OEM works just fine to replace or is there any better ones out there. I'm running E85 on NA engine but hoping to go supercharger over the next year. Any suggestions would be great. Thanks.
jslack is offline   Reply With Quote
Old 08-19-2019, 12:43 PM   #2
Skyehigh55
Drives: 2017 Pure Red BRZ w/ Perf Package
ALL STEPS COLDERRRR~
Jk. The consensus on the forum seems to be to stick with the OEM plugs. Unless going really high performance (like track built monsters), the OEM plugs work perfectly fine with the 86 platform's forced induction applications.
Skyehigh55 is offline   Reply With Quote
Old 08-19-2019, 12:47 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Oem.
Old 08-19-2019, 02:16 PM   #4
jslack
Thanks group. I'm all for the OEM plugs.
Old 08-19-2019, 02:30 PM   #5
Once upon a time going with a better plug was a great way to improve power. Nowadays the OEM plugs are far better than even the best performance plugs of old. No real advantage to "better" plugs unless you are burning off the old ones.
Old 08-19-2019, 03:54 PM   #6
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
stock plugs gapped a little tighter have no problem with 700+whp and 30-40psi of boost.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 08-19-2019, 04:09 PM   #7
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Denso makes our stock iridium plugs so they're good to go.
Current DD: M235i
8RZ is offline   Reply With Quote
spark plugs Legend@wheels Engine, Exhaust, Transmission 3 12-12-2018 12:13 AM
How to gap spark plugs Strife26 Engine, Exhaust, Transmission 38 01-09-2018 01:06 AM
Spark Plugs at 65K user4815 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 50 12-25-2017 04:19 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 10:47 AM
