Old 04-03-2016, 04:59 PM   #71
_gt86_user
Inactive
Drives: .
Someone should add the Perrin intake which is now CARB approved.
_gt86_user is offline   Reply With Quote
The Following User Says Thank You to _gt86_user For This Useful Post:
MJones_RB (04-04-2016)
Old 06-11-2016, 01:45 AM   #72
Irace86
Drives: BRZ + Ducati M796
https://www.bar.ca.gov/pdf/APPENDIX%...%2012-2009.pdf
Just found this, and I wanted to share. I need to go through it some more, but it looks like oil catch cans are exempt from CARB. Surprise to see that, but it makes sense...still surprised.
Irace86 is offline   Reply With Quote
Old 08-16-2019, 12:49 AM   #73
platypus01
Drives: DAR
it seems to have gotten pulled off...
archive/wayback:
https://web.archive.org/web/20190323...%2012-2009.pdf
differently-formatted, but content looks similar:
https://www.saddleback.edu/uploads/a...nal12-2009.pdf
also:
https://www.bar.ca.gov/pdf/Smog_Chec...ence_Guide.pdf
title page dated "5/17/2019".
page E-2 (64 of 69), section 8 "Aftermarket Parts":
All non-OEM configurations or aftermarket components installed on the recipient vehicle or donor engine must adhere to BAR’s Aftermarket Parts Verification Guidelines located in the Smog Check Manual, Appendix G [...]
it sounds like the "Appendix G exemptions" (in some form) still apply, even though the file seems to no longer be available on their website. but i'm just guessing...
platypus01 is offline   Reply With Quote
The Following User Says Thank You to platypus01 For This Useful Post:
Irace86.2.0 (08-16-2019)
Old 08-20-2019, 02:31 PM   #74
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
As many of you probably know already, Edelbrock Supercharger is CARB approved:
https://www.edelbrock.com/e-force-su...2-0l-1556.html
Would be curious to learn about more new CARB-approved products, especially for MY17+.
Old 08-20-2019, 04:26 PM   #75
Lantanafrs2
Drives: 2013 frs red
Other than carb approved fi kits, theres probably nothing else carb certified that's worth buying
Lantanafrs2 is offline   Reply With Quote
Old 08-20-2019, 06:45 PM   #76
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Pretty much. There are smog exempt parts like closed circuit catch cans or catback exhausts, which often get confused for being illegal or needing a CARB sticker. CAI might be the only other example of a CARB EO product, and its benefits without a tune is suspect.
Old 10-22-2019, 11:23 AM   #77
MiLo86
Drives: 2016 UM FRS
Hi, I was doing some searching and now the AFE Takeda, Momentum and Hopefully Greddy(since made by AFE) CAI are now SMOG Legal
I printed these out to leave in my Car since there are no Stickers.
https://ww3.arb.ca.gov/msprog/afterm...o/d-550-23.pdf
MiLo86 is offline   Reply With Quote
Old 10-22-2019, 01:22 PM   #78
scuzzy
Drives: 22 BRZ limited MT
Is it true the Open Flash Tablet is now illegal in California?
scuzzy is offline   Reply With Quote
Old 10-22-2019, 02:40 PM   #79
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Well if you want to get technical it is everywhere. But the only way to get an EO is if someone where to do a locked carb tune, do the testing, and get it approved. Bet then it would still only apply to a certain engine family, model year, ect.
Old 11-25-2019, 07:41 PM   #80
WhiteRose
Drives: 2013 Genesis Sedan
Quick Question, will an e85 tuned vehicle pass with a catback and stop header/op/fp?
Sent from my ONEPLUS A6013 using Tapatalk
WhiteRose is offline   Reply With Quote
Old 11-25-2019, 08:51 PM   #81
Irace86.2.0
Not the visual.
Old 11-25-2019, 08:57 PM   #82
WhiteRose
Sorry i meant to say stock header/op/fp**
Old 11-25-2019, 11:52 PM   #83
Irace86.2.0
I figured, but let me ask what is your setup, and what are your concerns?
Most CARB renewals of new cars consist of a visual inspection and an OBD2 readiness check. If you are just running a dual tune (pump or E85) then you will pass with E85 in the tank. If you are running a Flex Fuel setup then you will fail the visual inspection, unless the technician is nice or an idiot.
If you are concerned about some type of emissions roller or sniffer test then E85 has shown to have less or negligibly different emissions, so you would pass there.
I am hoping Harrop will release a CARB tune/EO sticker, so I can remove my Flex Fuel kit and use a base tune from DT (something that works with my 770cc injectors and pump gas), so I can pass the visual.
Old 11-26-2019, 12:18 AM   #84
WhiteRose
Ah i see, yeah I'm thinking about running a flexfuel kit but keep it hidden somewhere in the engine bay
Recent Thread List Anthony Site Announcements / Questions / Issues 0 07-21-2013 10:24 AM
Any of the FI kits CARB approved yet? RYU Forced Induction 27 05-05-2013 10:51 PM
Carb legal intakes EN2_Squirrel Engine, Exhaust, Transmission 2 04-18-2013 05:59 PM
Parts.com = Master Limited BRZ > FR-S Thread? dkenne2586 Cosmetic Modification (Interior/Exterior/Lighting) 1 03-12-2013 12:44 AM
B2autodesigns Master exhaust thread. Invidia,Takeda, Berk, Magnaflow and more b2autodesigns Engine, Exhaust, Bolt-Ons 29 01-02-2013 10:44 AM
