#71 |
Inactive
Drives: .
Someone should add the Perrin intake which is now CARB approved.
| The Following User Says Thank You to _gt86_user For This Useful Post: | MJones_RB (04-04-2016) |
#72 |
Drives: BRZ + Ducati M796
https://www.bar.ca.gov/pdf/APPENDIX%...%2012-2009.pdf
Just found this, and I wanted to share. I need to go through it some more, but it looks like oil catch cans are exempt from CARB. Surprise to see that, but it makes sense...still surprised. |
#73 | ||
Drives: DAR
archive/wayback: https://web.archive.org/web/20190323...%2012-2009.pdf differently-formatted, but content looks similar: https://www.saddleback.edu/uploads/a...nal12-2009.pdf also: https://www.bar.ca.gov/pdf/Smog_Chec...ence_Guide.pdf title page dated "5/17/2019". page E-2 (64 of 69), section 8 "Aftermarket Parts": Quote:
| The Following User Says Thank You to platypus01 For This Useful Post: | Irace86.2.0 (08-16-2019) |
#74 |
Drives: 2022 GR86
As many of you probably know already, Edelbrock Supercharger is CARB approved:
https://www.edelbrock.com/e-force-su...2-0l-1556.html Would be curious to learn about more new CARB-approved products, especially for MY17+. |
#75 |
Drives: 2013 frs red
Other than carb approved fi kits, theres probably nothing else carb certified that's worth buying
#76 |
Drives: Q5 + BRZ + M796
Pretty much. There are smog exempt parts like closed circuit catch cans or catback exhausts, which often get confused for being illegal or needing a CARB sticker. CAI might be the only other example of a CARB EO product, and its benefits without a tune is suspect.
#77 |
Drives: 2016 UM FRS
Hi, I was doing some searching and now the AFE Takeda, Momentum and Hopefully Greddy(since made by AFE) CAI are now SMOG Legal
![]() I printed these out to leave in my Car since there are no Stickers. https://ww3.arb.ca.gov/msprog/afterm...o/d-550-23.pdf |
#78 |
Drives: 22 BRZ limited MT
Is it true the Open Flash Tablet is now illegal in California?
#79 |
Drives: Crapcan
Well if you want to get technical it is everywhere. But the only way to get an EO is if someone where to do a locked carb tune, do the testing, and get it approved. Bet then it would still only apply to a certain engine family, model year, ect.
#80 |
Drives: 2013 Genesis Sedan
Quick Question, will an e85 tuned vehicle pass with a catback and stop header/op/fp?
Sent from my ONEPLUS A6013 using Tapatalk |
#81 |
Not the visual.
#83 | |
Most CARB renewals of new cars consist of a visual inspection and an OBD2 readiness check. If you are just running a dual tune (pump or E85) then you will pass with E85 in the tank. If you are running a Flex Fuel setup then you will fail the visual inspection, unless the technician is nice or an idiot. If you are concerned about some type of emissions roller or sniffer test then E85 has shown to have less or negligibly different emissions, so you would pass there. I am hoping Harrop will release a CARB tune/EO sticker, so I can remove my Flex Fuel kit and use a base tune from DT (something that works with my 770cc injectors and pump gas), so I can pass the visual.
#84 | |
| Recent Thread List | Anthony | Site Announcements / Questions / Issues | 0 | 07-21-2013 10:24 AM |
| Any of the FI kits CARB approved yet? | RYU | Forced Induction | 27 | 05-05-2013 10:51 PM |
| Carb legal intakes | EN2_Squirrel | Engine, Exhaust, Transmission | 2 | 04-18-2013 05:59 PM |
| Parts.com = Master Limited BRZ > FR-S Thread? | dkenne2586 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 03-12-2013 12:44 AM |
| B2autodesigns Master exhaust thread. Invidia,Takeda, Berk, Magnaflow and more | b2autodesigns | Engine, Exhaust, Bolt-Ons | 29 | 01-02-2013 10:44 AM |
