Old 08-13-2019, 02:36 PM   #1
Mark Methods
Mark Methods's Avatar
Drives: 2014 BRZ
FA20 Part Guide Resealing Engine
Hey Everybody,
I tried to order the seals without the OEM head gaskets for a rebuild I'm attempting however I found it cheaper to order the whole kit. A lot of places are charging $222 for this same seal kit.
You can either buy the whole kit for $141.20 + shipping: 10105AB550
Or you can buy the broken out list below for $180.43:
Part No. Part Name QTY
806792010 OILSEAL -92X109X8 1
806916080 O RING-16.1X2,3 2
11044AA810 GSKT -CYL HEAD 1
10944AA100 GSKT-CYL HEAD,2 1
10966AA041 GSKT-SPARK PL PIP 4
806915170 O RING-15.4X1.8 4
803916010 GSKT-16X21X2.3 1
806932030 O RING-32.6X2.7 3
806939060 O RING-39.0X2,0 1
806924120 O RING-23.8X2.8 1
806912190 O RING-12.1X2.5 3
806750080 OILSEAL -50X62X7 1
15090KA000 SEAL-OIL LEVEL 1
13270AA250 GSKT-ROCKER COVERRH 1
13272AA180 GSKT-ROCKER COVERLH 1
14035AA610 GSKT-INT MANIF 2
17555AA040 GSKT -FUEL PIPE 1
806931110 O RING-31.5X2.0 1
806933010 O RING-33.7X3.5 2
44011AC030 GASKET F 2
Thought it was something interesting; hopefully it helps someone out.
- Mark
Mark Methods is offline   Reply With Quote
The Following 9 Users Say Thank You to Mark Methods For This Useful Post:
DAEMANO (08-14-2019), humfrz (08-14-2019), Joon525 (08-13-2019), jordan7831 (08-14-2019), NoHaveMSG (08-14-2019), radroach (08-15-2019), Tcoat (08-14-2019), Tristor (08-13-2019), Ultramaroon (08-17-2019)
Old 08-13-2019, 03:38 PM   #2
Tristor
Tristor's Avatar
Great info, thanks.
Tristor is offline   Reply With Quote
Old 08-14-2019, 10:44 AM   #3
I don't see the five gallons of Three Bond RTV Silicone you will need as well.
https://www.amazon.com/dp/B008Y60R5K...yoheadqucom-20
Old 08-16-2019, 08:57 AM   #4
Mark Methods
Drives: 2014 BRZ
This is indeed missing, Subaru should add this to the kit.
The Following User Says Thank You to Mark Methods For This Useful Post:
Tcoat (08-16-2019)
Old 08-17-2019, 10:18 AM   #5
CoolHandMoss
Drives: 2013 FRS
As many of these that have problems leaking, people still think three bond is the best sealant option?
CoolHandMoss is offline   Reply With Quote
Old 08-17-2019, 10:39 AM   #6
Yes. When applied properly. The issue isn’t with the sealant since all FA20s use it with out many issues. The problem is that some get sloppy when removing and reapplying it.
Old 08-17-2019, 12:45 PM   #7
ermax
ermax's Avatar
Originally Posted by Mark Methods View Post
Hey Everybody,
- Mark
I came to the same conclusion when rebuilding my engine. I did add a few other things that were not in the kit like HP injector seals and OCV filters.
I used three tubes of TB1217H but the third tube was hardly used and I actually resealed the cam subs trice because I accidentally rotated my box of shims which screwed my lash.
ECU and Engine Tuning Reference Guide swift996 Software Tuning 140 11-02-2022 12:18 AM
[FS] 2013 FA20 part-out ML Engine, Exhaust, Bolt-Ons 5 12-12-2018 03:36 PM
Headlight resealing in SoCal CatalystPLUR Southern California 6 07-06-2017 03:53 PM
Looking to buy FA20 engine ndreim Want-To-Buy Requests 0 12-15-2015 06:43 PM
Engine Sensor OBD II Guide swift996 Software Tuning 4 01-10-2014 04:48 PM
