Old 08-08-2019, 01:30 AM   #1
SmoothIsSlow
3mm spacer on track, lug nut had almost 8 turns
Hi all,
I put on my 225 45R17 on 17x8 +45mm wheels. My front have -2.4* from camber bolts.
Unfortunately, with these SX2s that I put on today, there was only about one credit card worth of clearance (1mm) between the tire and the spring perch. I bought 3mm hubcentric stancemagic spacers expecting this as a possible issue.
Should I run my two track days this weekend with the spacers (the lug nuts had 7 3/4 of turns)? It’s too late to schedule for an alignment if I were to bring down the camber at home.
Another option is to run my old 215 PS4Ses, I wanted to stop tracking on them because the shoulders were getting murdered...
SmoothIsSlow is offline   Reply With Quote
Old 08-08-2019, 01:42 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
I consider 6 full turns a safe minimum. I'd say you are ok at 7.75 turns. Check torque every time out.
SmoothIsSlow (08-08-2019)
Old 08-08-2019, 07:29 AM   #3
i8ur911
Drives: 17 BRZ Series.Yellow
Agree with Dan......you should be all good.
FYI, don't check torque when wheels are hot, but check it a couple minutes before heading out that session.
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
The Following 2 Users Say Thank You to i8ur911 For This Useful Post:
SmoothIsSlow (08-08-2019), Tristor (08-08-2019)
Old 08-08-2019, 07:48 AM   #4
steverife
Drives: 2016 Scion FRS
Surprised you have that little clearance with that camber. SSC folks can get away with running +45's with around -3.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
Old 08-08-2019, 08:08 AM   #5
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Another chiming in that it sounds like a safe amount of engagement.
CrowsFeast is offline   Reply With Quote
The Following User Says Thank You to CrowsFeast For This Useful Post:
Old 08-08-2019, 08:20 AM   #6
Tokay444
1.5xD minimum thread engagement.
The Following 3 Users Say Thank You to Tokay444 For This Useful Post:
Clutch Dog (08-08-2019), NoHaveMSG (08-08-2019), strat61caster (08-08-2019)
Old 08-08-2019, 09:28 AM   #7
SmoothIsSlow
Sorry, what is D in this case? Diameter of the studs?
Old 08-08-2019, 09:29 AM   #8
SmoothIsSlow
I am on stock Performance package sachs. I had about 4mm with 225 Sottozero IIIs that we’re previously mounted on the exact same wheels. I am thinking the SX2s are just wider?
Old 08-08-2019, 09:31 AM   #9
SmoothIsSlow
Thanks! Would everything seem too lose when the wheels are hot? Or the opposite?
Old 08-08-2019, 09:36 AM   #10
Tokay444
D is what it always is. Diameter.
Old 08-08-2019, 09:55 AM   #11
i8ur911
The hotter the component, the more it stretches.
You only want to torque your wheels when they're "cold". I've seen too many people come right off the track and grab their torque wrench to start torquing wheels. Bad news. That's how you weaken components or snap studs.
The Following 3 Users Say Thank You to i8ur911 For This Useful Post:
jflogerzi (11-10-2019), Tristor (08-08-2019), ZDan (08-08-2019)
Old 08-08-2019, 10:43 AM   #12
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Most are spacing out to the max +40 to hit -3 degrees.
ineedyourdiddly
Old 08-08-2019, 11:51 AM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
What he said ^^^
Check a few minutes *before* going out, don't torque them hot, right off the track!
Old 08-08-2019, 12:05 PM   #14
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Quoted from the McGard website
"Note: When installing wheel lock nuts and lug nuts, verify that it is the correct thread size, seating surface type (cone seat, radius seat, shank) and style as recommended by the wheel manufacturer. Minimum thread engagement must be equal to the thread diameter of the wheel stud. Example: M12 x 1.5 nut requires a minimum of 12mm (.472”) of thread engagement."
i8ur911 (08-08-2019)
Small spacer vs big spacer Atomic Rooster Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 11-09-2017 01:30 PM
Radiator/AC turns off temporarily Scrub Issues | Warranty | Recalls / TSB 18 07-21-2016 02:09 PM
Clicking with Sharp Turns carma143 BRZ First-Gen (2012+) — General Topics 7 12-09-2014 12:43 AM
Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-03-2014 12:53 PM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 11:59 AM
