Old 07-20-2019, 07:05 PM   #1177
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
Originally Posted by Conman View Post
by the amount of smoke we sent out I would be surprised if there is any left
if it is truly that much, I don't the aos would be it. What brand aos is it? Then I can at least try to see how it is hooked up vs how it should be to be sure.
We can do this diagnostic via pm as well so not to clutter the owners thread.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
Old 07-21-2019, 09:57 AM   #1178
ShansBRZ
Drives: 2017 brz
If your running an open pcv valve and not venting to atmosphere with your aos then that’s your problem. I made that mistake and it took 3 months for the oil to stop dripping out of my exhaust.
ShansBRZ is offline   Reply With Quote
Old 07-21-2019, 10:44 AM   #1179
Conman
Conman's Avatar
Drives: Red FRS
They said they removed the pcv valve.. But yeah for the first start the aos was recirculated to the intake port. The shop doesn't seem to think the aoS would cause this. Even after ive shown them peoples responses online telling me that aos is the cause. They are saying it should not cause that much oil to get pulled though at idle. It was a god awful amount of smoke. Like we just dumped straight oil into the exhaust.
Conman is offline   Reply With Quote
Old 07-21-2019, 11:06 AM   #1180
Tonrogs
did you check the aos to see if it also was full of oil? If so, then the aos could be the cause, but I would still pull the charge pipe off the turbo to check for oil there. Its only 2 clamps.... That is if your bumper is still off the car. You could also just pull that line off that went from the intake to the aos and check it for oil.
Once you find the issue, as stated above, it will take a long time for the oil to clear out.
Given you have oil built up in the downpipe, I'm still leaning towards the restrictor was missing. But we have more diagnostic steps to take to determine that.
So, 2 ways for oil to get where you have it.
1 is through the seals in the turbo and directly into the exhaust
2 is through the aos and into the intake, through the motor and into the exhaust
We need to find out if oil is in your charge piping or not. And also how far in the charge piping and how much oil if it is there. That will determine where to look next.
The Following User Says Thank You to Tonrogs For This Useful Post:
Conman (07-21-2019)
Old 07-21-2019, 11:35 AM   #1181
Conman
Conman's Avatar
Drives: Red FRS
I will forward this to the shop... But honestly at this point thinking I might need to just tow the car home or to a new shop. Not sure I have the funds to fix any more issues that are going to cost more money.
Old 07-21-2019, 12:13 PM   #1182
ShansBRZ
Drives: 2017 brz
Yep that’s your issue then. I’m almost positive. Put a STI pcv valve in there or unhook your intake manifold line to the separator and plug the manifold and I bet it stops sucking the oil in. When I messed up it it filled my catch can full of oil and filled my exhaust full of oil and smoked so bad I left a trail of smoke a mile long. After fixing it it still smoked burning off the excess but nothing near before.
The Following User Says Thank You to ShansBRZ For This Useful Post:
Conman (07-21-2019)
Old 07-29-2019, 11:25 AM   #1183
Amputechture
Drives: 2014 BRZ
I would suggest just removing the AOS from the equation altogether. When in doubt, remove variables.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
Old 07-29-2019, 11:29 AM   #1184
Amputechture
Drives: 2014 BRZ
For the life of me I'll never understand five hundred dollar catch cans. My fourty dollar K-motors can has a baffle, a drain valve, and my intercooler and charge piping are clean.
The Following User Says Thank You to Amputechture For This Useful Post:
sroby (07-29-2019)
Old 07-31-2019, 04:29 PM   #1185
Amputechture
Drives: 2014 BRZ
Is anyone aware of a ball bearing upgrade to the old precision 4854/4831 that can utilize the same downpipe connection? The only T3 2.8 compressor inlet/2.0 outlet to vband discharge turbo I am finding online is a 5558, which to my understanding is a competitor to a garrett gt3067r. I was hoping for something comparable to a gt28 ball bearing, if not one itself but it appears it's not adaptable to the v1 setup.
Old 08-07-2019, 02:38 PM   #1186
Conman
Conman's Avatar
Drives: Red FRS
So yeah the engine is blown. Rod knock after the first 4psi data log...Most likely due to Impulse Performance installing the AOS wrong and sucking oil into the intake during the first start up...
Old 08-07-2019, 03:13 PM   #1187
WC-BRZ
Drives: Black BRZ
Good lord, sorry to hear ...
...are these "impulse performance" clowns the 2019 version of FA20 club or something!?
WC-BRZ is offline   Reply With Quote
Old 08-07-2019, 10:15 PM   #1188
Conman
Conman's Avatar
Drives: Red FRS
Anybody looking for a used JDl kit on the cheap?
Old 08-07-2019, 10:35 PM   #1189
jRuN
How cheap?
Sent from my Pixel XL using Tapatalk
jRuN is offline   Reply With Quote
Old 08-08-2019, 12:39 AM   #1190
Steveiam
Drives: 86
I was following your build thread and I thought everything got situated. Sorry to hear that happened. Are you thinking of rebuilding the block?
Steveiam is offline   Reply With Quote
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
