Old 07-31-2019, 02:26 PM   #15
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Originally Posted by blown View Post
Are ohlins valving specs secret to dealers?
I already have a set of RT MK2 and would like them revalved to be more aggressive.
Springs as well.
We should have access to the valving specifications. Typically, we send our R&T coilovers back to Ohlins to have them re-valved to match specific spring rates. Just responded to your PM. Let us know which rates you're interested in - i'll check if we have them in stock!
- WORKS Team
WORKS is offline   Reply With Quote
Old 08-05-2019, 11:46 PM   #16
PossiblyLost
Drives: BRZ?
Any updates to this?
PossiblyLost is offline   Reply With Quote
Old 08-07-2019, 01:14 PM   #17
BizzMan
BizzMan's Avatar
Drives: 2016 BRZ Limited
Originally Posted by RayRay88 View Post
@BizzMan
Has Ohlins released this kit to market yet, or will it be a BTO type deal?
I'd be very curious to see shock dyno's if possible.
They're aiming to fully releasing this kit towards the end of the year. I'll be at VIR with NASA the 17th and 18th of this month, so I'll have a bunch of feedback to share with everyone come the 19th.
BizzMan is offline   Reply With Quote
The Following User Says Thank You to BizzMan For This Useful Post:
RayRay88 (08-07-2019)
Old 08-20-2019, 05:51 PM   #18
BizzMan
BizzMan's Avatar
VIR Testing, August NASA Event
Alright everyone,
I spent the weekend at VIR with NASA and had an absolute blast. It was scorching hot and it's time for an oil cooler (temps hit over 260 degrees for oil a couple times). The car felt great and the Ohlins felt even better. Again, I'm no pro driver and drove HPDE 2 SOLO all weekend. My average laps were between 2:25 and 2:30, so I'm very happy with everything and really couldn't expect a better setup. To drive 4 hours to the track, change nothing, drive all weekend, throw all my crap back in my car and drive 4 hours home without changing a single thing? I mean, come on.
From my understanding I was able to corner at an additional 5-6 mph and under hard braking while trying to trail brake. I felt the suspension was a lot stronger, and as an example of this I felt it most in turn 1, 11 and 14. Again, more seat time can be the result of this, but this DFV Dedicated kit is a dope setup for the money.
Let me know what questions you have and criticism on my driving is welcome.. because that's the only way you get better.
Video: [ame]https://www.youtube.com/watch?v=AkgxH316kx8&t=502s[/ame]
Old 09-10-2019, 11:00 AM   #19
RayRay88
Drives: 2017 86 860 Special Edition
Do we have a release date for this yet?
RayRay88 is offline   Reply With Quote
Old 11-21-2019, 06:01 AM   #20
chch83
chch83's Avatar
Drives: 2004 Mercedes CL600, 2018 Toyota 86
Any information for this product?
chch83 is offline   Reply With Quote
Old 02-21-2020, 03:35 PM   #21
RayRay88
updates?
Old 09-18-2022, 09:24 PM   #22
sidebrake
Drives: '14 BRZ Limited
I just sent my Ohlins in for a rebuild and re-valve to the Dedicated spec and I'm planning to get a set of Swift springs. What's the length of your springs and are the helper springs necessary? Thanks.
sidebrake is offline   Reply With Quote
Old 09-19-2022, 11:22 AM   #23
RacingredGR86
RacingredGR86's Avatar
Drives: 2022 GR86
@sidebrake - what spring rates where you running and what new spring rates you plan on going with via Swift springs.
As for spring lengths, I found in other threads that original spring that comes with the R&T kit are approx. 9". Swift makes a wide range of spring rates at this length that could work.
RacingredGR86 is offline   Reply With Quote
Old 09-19-2022, 08:37 PM   #24
sidebrake
Was originally running the 5/5k set up. It is getting re-valve to 9/9k.
The Following User Says Thank You to sidebrake For This Useful Post:
RacingredGR86 (09-21-2022)
My ohlins warranty problem!!!!!!see what Ohlins China replies!!!!!!!!!!!!!!!!!!!!!!!! kkman User/Vendor/Sponsor Reviews, Feedback, Comments 18 03-31-2016 10:59 AM
Trailer | Ohlins Install | Interviews With Essex & Ohlins Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 12-24-2013 03:01 PM
what if you dedicated $2,000 brichard0625 Engine, Exhaust, Transmission 28 04-07-2013 01:13 AM
Dedicated race series? Swift Tracking / Autocross / HPDE / Drifting 48 10-30-2012 09:41 PM
Dedicated to those who are in a YARIS! do to them having issues with there FRS/BRZ 86'ing Issues | Warranty | Recalls / TSB 23 09-15-2012 04:57 PM
