Old 08-05-2019, 02:30 PM   #1
lumbeardjack
lumbeardjack's Avatar
Drives: 2017 Toyota 86
replacing car emblems
*Not for my 86, hence why I'm posting it in the off-topics
I took my mazda's emblems off to paint and now I'm wondering how to put them back on. It sounds like a no-brainer but I'd rather get the 0.02 from someone that's already done this before. 3M tape? Caulk? Glue? Horror stories?
lumbeardjack is offline   Reply With Quote
Old 08-05-2019, 04:13 PM   #2
tobin
tobin's Avatar
Drives: '13 BRZ
Get new emblems; they come with adhesive already attached and aren't deformed from removal.
tobin is online now   Reply With Quote
The Following 3 Users Say Thank You to tobin For This Useful Post:
DarkPira7e (08-10-2019), maslin (08-05-2019), Tcoat (08-05-2019)
Old 08-05-2019, 04:59 PM   #3
maslin
Benz Tech
Drives: 2017 BRZ Premium
That's the way. Pre-spaced and pre-taped.
We've tried everything over the years, nothing comes out as good as a fresh set.
maslin is offline   Reply With Quote
Old 08-08-2019, 10:05 PM   #4
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Did it on my old old car with 3M double sided tape. Held up fine including through the winter. Trick is getting it all on straight. (can use painters tape for alignment)
CrowsFeast is offline   Reply With Quote
Old 08-10-2019, 02:53 PM   #5
lumbeardjack
fortunately they have tabs so they will go in the same way. I was wondering about double sides 3M tape and just cutting away any that showed from the profile but originally they didn't have tape so the tape may create an unwanted stacked tolerance issue
Old 08-10-2019, 03:12 PM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
Sounds like a lot of hassle, go for the de-badged look.. if you ever sell, it becomes someone else's issue..
The Following User Says Thank You to JD001 For This Useful Post:
why? (08-12-2019)
Old 08-12-2019, 08:08 AM   #7
CrowsFeast
CrowsFeast's Avatar
Sounds like going debadged isn't an option without metalwork. (way more hassle obv)
3M has a number of different double sided tapes available of various thicknesses and I don't think they're the only reliable brand either. Double sided tape has 2 major advantages: you can adhere the tape to the badge and trim it prior to installing it (super clean installation with no extra visible adhesive and very easy to do) and if the one you use is too thick or has other problems then it's easy enough to remove and do-over with very little cost.
replacing BRZ key/fob brzcountsright BRZ First-Gen (2012+) — General Topics 12 03-13-2020 02:31 PM
Dealership said they are replacing the ECM? Sherb BRZ First-Gen (2012+) — General Topics 2 01-12-2016 07:39 PM
need help with replacing tire wingrider BRZ First-Gen (2012+) — General Topics 3 05-01-2015 10:22 AM
anyone have DIY for replacing OEM HU?? mbh1101 DIY (Do-It-Yourself) Guides 2 01-27-2013 12:18 PM
