Old 04-30-2015, 09:56 PM   #1
wingrider
Drives: subaru brz
need help with replacing tire
Hi All,
BRZ is the first car I have ever owned. Recently I hit a flat tire due to a nail, and the nail is close to the sidewall and I need to replace a tire now. My BRZ has about 5K miles on it so treads were quite good and I will have to take the loss of the tire.
Can someone help me here with choosing a new tire. If i am not wrong the stock tire is Michelin HP Primacy 215/45R/17 87W. That costs roughly 200$ + fitting.
Questions>
1) Should I get a new one of stock tire
2) Do tread designs matter (what if I use one tire of different manufacturer)
3) It seems the W is for very high speeds, i do not think i will touch 149 miles with V, do I need a W tire.
4) Michelin makes ton of tires in this spec, eg M4x4, what are those for?
I do not plan to do track racing, I just like to drive spiritedly when I find empty roads, but not at speeds above 100 mph.
Any suggestions with another make of tire would also be welcome.
Thanks,
Ravi
wingrider is offline   Reply With Quote
Old 05-01-2015, 12:38 AM   #2
tyrantcf
Drives: '16 WRX, CBR1000RR
You need to keep the W speed rating and load index, it's about more than just top speed.
I'd strongly suggest you go with the same Primacy HP unless you plan to change all 4 tires right now to something else.
Source: I work in a tire shop.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 05-01-2015, 08:56 AM   #3
Shedd22
BAMF
Shedd22's Avatar
Drives: 2014 SWP BRZ
Originally Posted by wingrider View Post
Hi All,
Questions>
Thanks,
Ravi
Check the classifieds section. You can probably get a stock tire with about the same tread wear (if you're worried about that) for a lot cheaper than a brand new one.
Some people might be nice enough to sell you one as opposed to all four or even just two. I have 4 stock ones laying around that have about 3k miles on them that I want to sell. I'd be willing to give you one for cheap if shipping wasn't ridiculous.
Shedd22 is offline   Reply With Quote
Old 05-01-2015, 10:22 AM   #4
Ashikabi
Ashikabi's Avatar
Check the classifieds if not in a hurry, there are some good deals
Replacing OEM tires. FRiSson New England 22 02-12-2016 11:43 AM
Replacing the BRZ mustache FrSnake Cosmetic Modification (Interior/Exterior/Lighting) 5 05-06-2014 01:15 AM
Replacing headers only diss7 Engine, Exhaust, Transmission 36 11-17-2013 12:28 AM
anyone have DIY for replacing OEM HU?? mbh1101 DIY (Do-It-Yourself) Guides 2 01-27-2013 12:18 PM
