Old 06-12-2018, 05:01 AM   #1
mkodama
86 Challenge
Drives: 2017 BRZ
Brembo Torque Specifications
What’s the specified torque for caliper mounting bolts on the Performance Package Brembo calipers, and are the caliper bolts reusable?
Unofficial answer:
59lb-ft/80Nm with anti-seize has been working great; numerous track days with no issue, and taking the calipers off a year later everything looked great.
mkodama is offline   Reply With Quote
Old 06-12-2018, 07:56 PM   #2
Grady
Grady's Avatar
Brembo’s use German torque. Gutentight, I beleive is the setting.
The Following 10 Users Say Thank You to Grady For This Useful Post:
Brink (10-14-2019), FRSBRZGT86FAN (07-05-2018), humfrz (06-13-2018), meWant (07-31-2019), mkodama (06-13-2018), Mr.ac (06-12-2018), RToyo86 (07-31-2019), spike021 (07-31-2019), Tristor (06-15-2018), weederr33 (06-27-2018)
Old 06-12-2018, 08:15 PM   #3
FirstWinter
Drives: Car
Yes, they're reusable. Are these the fronts? If so, 60 ft-lbs and call it a day.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
Old 06-13-2018, 02:01 AM   #4
mkodama
86 Challenge
Drives: 2017 BRZ
lulz
This is what I ended up going with. Dry, it is impossible to properly torque these bolts with less than 120Nm as they want to seize. With some copper anti-seize, all 4 front bolts tightened to their original position(clocked with a pen mark) at 60ft-lb/80Nm.
The Following User Says Thank You to mkodama For This Useful Post:
Old 06-28-2018, 11:43 PM   #5
Razorlor
Drives: 2017 BRZ Limited, Perf Package
I looked in my service info, I don't have any specs listed for either. Should just be able to snug em both up and be fine, add a little extra oomph to the banjo bolts.
Razorlor is offline   Reply With Quote
Old 07-31-2019, 07:46 AM   #6
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Stumbled upon this thread, as well as a similar thread on an STI forum.
https://forums.nasioc.com/forums/sho....php?t=2894993
Looks like the answer is ~80–88 lb-ft which with anti-seize translates to about 60 lb-ft indeed.
Old 08-01-2019, 06:22 PM   #7
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
3 ugga duggas should do it!
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
The Following User Says Thank You to JeremyR For This Useful Post:
soundman98 (08-02-2019)
Old 10-03-2019, 04:41 PM   #8
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Front caliper bolts: 88.5 ft·lb or 120 Nm
Rear caliper bolts: 53.8 ft·lb or 73 Nm
Bleeder valves: 14.8 ft·lb or 20 N·m
Source: Subaru BRZ, 2020 Service Manual
The Following User Says Thank You to timurrrr For This Useful Post:
Tristor (10-10-2019)
Compression Test Values - Factory Specifications? kharn83 Engine, Exhaust, Transmission 14 11-13-2017 03:21 AM
Requesting OEM Clutch Line Specifications RJasonKlein Engine, Exhaust, Transmission 6 05-21-2015 01:06 AM
TRD GT86/AERO Specifications 1904 Cosmetic Modification (Interior/Exterior/Lighting) 8 11-06-2014 03:03 AM
front and rear fender well specifications PineappleFriedRice Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-22-2013 07:06 PM
