#15 | |
2013 Series 10 FRS #553
#16 | |
Drives: 2018 BRZ PP (Modified)
FWIW I do like my HKS Hipermax GTs on my Performance Pack BRZ for $1600, but next time around I might do Fortune Autos or the CSG Teins. |
#17 |
Drives: 2013 FR-S 10-Series
Location: SJ/OC/IE California; Temporarily: Glendale,AZ
Hm, from what I've been reading it seems that the consensus is that a quality dampener like koni/billstein + spring combination would outperform coilovers in the $1000 range (independent of corner balancing, alignment, etc.) @Racecomp Engineering , any thoughts on the koni + a spring w/ 1.4 inch drop (i.e. eibach sportline) vs coilover?
#18 | |
#19 | |
I was hoping that I could get better performance for cheaper with a used set of Konis/Billsteins & a set of sportlines (for height), similar to OP. I believe with used koni/billsteins & eibach sportlines, I could (maybe?) achieve better performance than $1000 coilovers, and have money left over to spend on components like bushings, angle kit, etc. Please let me know your thoughts, thanks in advance! |
#20 | |
I do like a good strut + spring combo, but 1.4 inch drop is too much even with Konis or Bilsteins for performance. - Andrew |
#21 | |
Konis & Bilstein setups are generally for people who want a little beefier handling experience but also want to maintain OEM+ look and feel. (Obviously being slammed on coilovers compromises that OEM sensation) I've seen some autocrossers using these setups, usually with either stock wheels or similar 17 inch aftermarket wheels, again sticking with that OEM+ theme. If you're on a budget you might want to check out Fortune Auto 500s, around $1300 and adjustable. You can also customize even further by adding Swift springs and picking out your own spring rates. My HKS coilovers are nice for sure but I think the FA's might be a better deal. RCE Super Streets are also a shout but I don't personally know anyone with them. |
#22 |
Thanks for the insight @Shizuka, I like FA a lot too but didn't know what category it was considered to be in (good/bad) after reading people talking about $1k range coilovers.
@Racecomp Engineering do you have a few recommended coilovers for that price range? I think I could find a used set for less, just need some pointers as to which models to go for or stay away from. Thanks! |
#23 | |
https://www.racecompengineering.com/...rz-frs-86.html Another option in the price range would be CSG Tein Flex. - Andrew |
#24 |
Drives: 2019 Toyota 86 TRD SE
Any major clearance issues with 1" drop? I mean I know there's going to be some.
#25 |
#26 |
Sorry. To clarify, clearance issues with the road. Not in regards to rubbing the fenders or anything like that.
#27 | |
Country Boy 4 Life
) lowered on Prokit 1" springs. 1" drop , at least in my area is still practical to DD. I'm now 1.25" lower than stock on coils; I can scrape on stuff I didn't used to.
I LIKE TIRES! |
#28 |
| Sachs PP Shock & Eibach Spring Combo - Roll Center Correction? | x_hawker | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 07-18-2019 02:41 AM |
| Eibach Sportline Lowering Spring front and rear camber bolts | WallsAndFoundations | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 08-20-2014 10:09 AM |
| WTB: Eibach sportline lowering spring. | bhbnuckle | Brakes, Suspension, Chassis | 1 | 03-11-2014 12:05 AM |
| FS Eibach Sportline lowering springs + Stock Strut $200! | Randyliciious | Brakes, Suspension, Chassis | 8 | 02-06-2014 12:57 AM |
| Eibach Sportline Lowering Springs | ebhopal | Brakes, Suspension, Chassis | 6 | 10-22-2013 05:00 PM |
