Will the EIBACH SPORTLINE lowering spring be ok with my stock sachs?
Hello recently purchased a 2019 rs brz, love the car a lot, but want to do something with the ugly gap between the fender and wheels.
Thinking about the lowering spring since I don’t track nor do a lot of auto x either. So imma try to stay away from coilover plus winter here in Canada is salt heavy. I want those sexy one finger gap between the wheel and fender so I figure 1.4” drop from the sportline would be a perfect choice, but idk how well they will pair with the stock sachs dampeners. Anyone have any experience with this set up? How do the shocks hold up in a long run? P.s I don’t mind harsh or stiffer ride either. Thanks !!! |
If you are planning on keeping the OEM shocks; I would not recommend any springs that lower your car more than 1".
If you really want one finger wheel gap, you'll have to be lowered a lot-- probably more than you'd think. I'm on HKS Hipermax coils now with 1 finger gap, and my car is scrape-on-driveway low. Any spring that drops you that much on the OEM Sachs is going to compromise ride quality significantly. As it is, my coils are supposed to be "daily driver friendly" and they're still very stiff at my height. Pic for reference: https://ibb.co/Ns1N0R4 |
Do you have the gt or sp version? Sent from my iPhone using Tapatalk |
What about the red version spring? I heard they lowered 1” and is same as the eibach pro Sent from my iPhone using Tapatalk |
The trd lowering spring which is 1” would be okay tho? Sent from my iPhone using Tapatalk |
You know many fingers can you fit between the gap? When u had the eibach pro? Cus someone locally is seling his TRD I might just buy his Sent from my iPhone using Tapatalk |
Do you have the measure between the gap with the rce? Sent from my iPhone using Tapatalk |
As others said 1" drop max. I have had both eibach pros and yellows. I like the rce yellows a bit more but eibach is almost as good with a bit more of a drop.
Sent from my GM1915 using Tapatalk |
What if he paired his Eibach Sportlines with a set of Koni Dampers? I haven't seen any posts with that combination for some reason.
Not sure how the performance on that would be either. Any thoughts? |
| All times are GMT -4. The time now is 05:00 PM. |
User Alert System provided by
