Old 07-10-2019, 01:55 AM   #589
ayoshioka1
Drives: 2019 BRZ / E36 325is
ADVAN RACING TC3 18x9.5 +45 square setup 255/35/18 firehawks
23 GR86 Halo MT Prem - Racecomp Engineering SS-2 - Sayber Designs - Voltex - RE71RS - Project Mu
ayoshioka1 is offline   Reply With Quote
The Following 3 Users Say Thank You to ayoshioka1 For This Useful Post:
CxG (11-13-2019), JD001 (08-06-2021), MCTeeJ (07-30-2019)
Old 07-30-2019, 04:33 AM   #590
broberg
broberg's Avatar
Drives: 2017 BRZ
AC Wheels Syclone Bronze 8x18" ET+38 (Running Dunlop Sport Maxx RT2 235/40)
Notes :
Car is lowered 1"
Tires are a bit to high, should probably be 35 instead of 40.
// Pierre Broberg
2017 Subaru BRZ, Christal White Pearl
broberg is offline   Reply With Quote
The Following 3 Users Say Thank You to broberg For This Useful Post:
Busybee (07-30-2019), Drifter X (07-30-2019), OwlDance (07-30-2019)
Old 07-30-2019, 12:53 PM   #591
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Actually I really like your setup. For me, the tires are just right. How's the ride quality?
Drifter X is offline   Reply With Quote
Old 07-30-2019, 12:58 PM   #592
broberg
broberg's Avatar
Drives: 2017 BRZ
Thanks!
The Ride quality is pretty much the same as stock, it's feels a bit heavier due to the 18" wheels, it has a lot more grip than the stock "plastic" wheels!
// Pierre Broberg
The Following User Says Thank You to broberg For This Useful Post:
Old 07-30-2019, 03:07 PM   #593
Drifter X
Drifter X's Avatar
Sick ride! What suspension are you running?
Old 07-30-2019, 03:08 PM   #594
Drifter X
Drifter X's Avatar
Originally Posted by broberg View Post
Thanks!
Last question. What suspension are you on?
Old 07-30-2019, 03:32 PM   #595
broberg
broberg's Avatar
Drives: 2017 BRZ
Stock dampers with Eibach Pro springs.
// Pierre Broberg
Old 07-30-2019, 03:42 PM   #596
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Notes :
Car is lowered 1"
I think your car looks great!
IIRC, there is only one 235/35/18 street tire, so that's not really possible. If your tires are too tall for you, then next time get 225/40/18. They are a very common size (which makes them cheaper usually too) on tirerack with 141 tires to choose from.
I LIKE TIRES!
Old 07-30-2019, 04:42 PM   #597
ayoshioka1
Fortune Auto 500 Gen 7
Whiteline RLCA
Whiteline Diff Inserts
Whiteline Subframe Inserts
The Following User Says Thank You to ayoshioka1 For This Useful Post:
Old 07-30-2019, 06:08 PM   #598
Drifter X
Drifter X's Avatar
Whiteline RLCA
Thank you!
The Following User Says Thank You to Drifter X For This Useful Post:
ayoshioka1 (07-30-2019)
Old 08-02-2019, 02:13 PM   #599
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Don't know if the original posts are getting updated at all but here's another couple pictures for Super Advan Racing (SAR) v2.
17x8, et IIRC is 35
Tires: 215/40/R17 (too small)
Stock suspension
Also have a poor picture of Konig Ultraforms
17x9, et 35 front, et 40 rear (5mm spacers front)
255/35/R17 tires
stock suspension +alignment goodies for -3* camber front and -2.2* rear
CrowsFeast is offline   Reply With Quote
Old 08-07-2019, 10:38 AM   #600
N_Raged
Drives: 2019 BRZ Sport-Tech RS
I don't see the OEM BRZ performance pack wheel on the top post so I weighed mine since I had no tires mounted.
20.8 LBS, 17x7.5" +48
N_Raged is offline   Reply With Quote
The Following User Says Thank You to N_Raged For This Useful Post:
phm14 (04-18-2020)
Old 08-17-2019, 05:14 PM   #601
Glitchy86
Drives: Red 86
I need your help guys.
I just got 17×9 +38 wheels and was wondering if I could fit 255/40 on them, I will be installing the Eibach pro kit lowering springs 1inch with some front camber bolts.
I know that the 245/40 will fit easily but was wondering if the 255/40 would fit.
Thanks.
Sent from my SM-G975F using Tapatalk
Glitchy86 is offline   Reply With Quote
Old 08-17-2019, 05:35 PM   #602
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
https://lmgtfy.com/?q=site%3Aft86clu...%22255%2F40%22
-> https://www.ft86club.com/forums/showthread.php?t=44927
You may also find a lot of useful info in the "meaty tire thread".
The Following User Says Thank You to timurrrr For This Useful Post:
Glitchy86 (08-17-2019)
brz aftermarket wheels, brz wheels, fr-s aftermarket wheels, frs aftermarket wheels, scion fr-s wheels, scion frs wheels, subaru brz wheels
BRZ/FR-S Wheel Fitment Photo Topic DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-12-2012 04:16 AM
BRZ/FR-S/86 Wheel Fitment Simulators JDMSushi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-05-2012 10:49 PM
Stock Suspension and Wheel Fitment bneale Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 06-29-2012 07:42 PM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
Wheel fitment sfwg BRZ First-Gen (2012+) — General Topics 6 10-28-2011 06:33 PM
