| Member's Car Journals Car journals by our members. |
Drives: 2017_86 2016_frs 2007_335i
Zay's Toyota 86
Hi everyone
first of all, my first language is not English so try to ignore all my mistake plz slowly getting there right? ![]() this is all about long build with date and feedback for my aftermarkets part. follow by the auto x and track video the example for review format "yyyy.mm.dd modified part name feedback" I had a 2016 Scion Frs for 2 years. First impression to drove the gt86 was remember me the go kart when I was turning into corner, then I had 2 track day on bone stock and i love it. Forgot to mention that is my first time to drive manual car exp in the drive school. After that two years lease, the 2017 Toyota 86 come out with a 5 hp power increase. By the same time, I need change my brake pad, rotor, brake fluid, engine oil, transmission fluid, diff fluid..... u can count it how much it could be to prepare my next track day,therefore i went to test drove the 2017 86 which give me a very solid feeling compare to 2016, a bit different clutch point, a smaller steering wheel, a short gear ratio, never feel the diff difference between 16 and 17. So i decided to get another lease on 2017 86 with better deal. I had one more track day with my 17 86 as bone stock which i feel i cant push my self anymore. Best time on VIMC is 1:36 at that time. 2016 frs 2017 86 2017.Dec.28 MXP Comp RS TI Tips Catback Exhaust System - 2013+ FR-S / BRZ it was all start as a accident which was on Xmas eve, i was parking the car on my friend's driveway at a snow day, after 10 mins the car slide back into a rock beside the driveway, and my exhaust tip got damaged here is the review on mxp comp rs ti tip cat back, sound good not so loud not too quiet. It is below 95 dB for sure, I have no problem on VIMC since most track has their sound limitation. it is very nice in the city, but the con part is on the highway. Since the 17 get short gear ratio, 6th gear around 90-100km/h which rpm will stay around 2500. it is require a very light throttle control, otherwise it will be very annoying. 5clicks more on stock speaker in city, 10 clicks more on the highway compare to the stock cat back. one more thing, i find out the air drag will be the problem with this cat back. There is huge empty space just in front of the rear bumper, and our bumper is a inverse "C" shape. It is looks like a parachuting, something like stock spare muffler will be much better to solve this. PERRIN EXHAUST HANGERS - 2013+ FR-S / BRZ WEATHERTECH FLOOR MATS - 2013+ FR-S / BRZ Weather tech floor mats is very good, it is covering the carpet just under the gas pedal. but little touch on the gas gate switch, not too bad but yea it does leave some scratch on that plastic. 2018.Apr.07 K&N Drop In Air Filter - 2017+ 86 MT / BRZ MT MOTUL 8100 ECO-LITE 0W20 OIL Motul 1L Transmission GEAR 300 Gear Oil 75W90 I cant feel any difference after change the engine oil, but I do feel some thing with the gear 300 for my transmission. It is a bit better after u changed the fluid anyway, but it is feel not smooth when the car not on the working temperature. After u car is warm up, it is whole different story. Motul 1L Transmission GEAR 300LS Gear Oil 75W90 Hawk DTC-60 Brake Pads (Front) - 2013+ FR-S / BRZ I really like this brake pads, pretty strong instant bite at beginning, lineer bite increase with the pedal pushed. here is a graph i draw for my feeling about the pad. Stoptech Drilled Rotor Pair (Front) - 2013+ FR-S / BRZ this is my first time using after market rotor, i don't know much about drill and slot. It was a mistake for just being cool. with the hawk dtc 60, the rotor is not strong enough to hold the pad. just check it recently, pad have tons life time left, but the rotor is fked. going to switch to DBA T3 4000 for my next pad and give it a try. StopTech Stainless Steel Brake Lines (Front) - 2013+ FR-S / BRZ K&N High Performance Oil FIlter - 2013+ FR-S / BRZ overall, without turbo we should stay with the oem calipers since it is going to be change frequently if u tracking the car. a big BBK wont help much and will cost way too much. 2018.Apr.17 Enkei RPF1 Wheels 17x8 +45mm (Gold) - 2013+ FR-S / BRZ It is really painful when I did the research on the wheel size and tire size just make sure i dont mess up anything with factory setup, I really like the factory set up a bit body roll but really help understand what is going on with the car. It is working well at VIMC exp one corner, we got a lot of off camber hair pin corner. So softer really help u dont losses the rear end. with the stock suspension, I am using square set up 17x8 +45 with re71r 245 40 17. It is looks very meaty. Toyota has their TPMS install in the end of the steam between tires and wheels. I end up bought 4 of them from dealer, and keep the stock for the winter. You also need hub ring to center up the wheel on the hub. ps: get a steel one they r going to get hot under heavy braking. 2018.May.12 Muteki SR48 Open End Lug Nuts - 2013+ FR-S / BRZ FT86SF CUSTOM ENKEI RPF1 WHEEL CENTER CAPS - 2013+ FR-S / BRZ 2018.Oct.01 http://www.ft86club.com/forums/showthread.php?t=134596 detail for the seat installing Bride zeta III type L bule Logo I order them on the ins: bridejapancanada very good experiences, the guy behind it always posting review of wheel and seat on the youtube. I am 183cm tall with 180kg weight and waist 44.5in It is a tighten, but still good. Nagisa Double locked seat bracket The reason I choose this bracket is super low, the seat almost seating on the floor without any effort I got this from evasivemotorsports, the only thing I had buy from USA. The good news is they can shipping the item to Canada with flat rate if i did not remember it wrong. Sparco Competition 6 Point Racing Harness - Universal Cusco seat brace long store in short, cant drill holes on the floor. I am sure it is not fully legit, at least I did what I can. 2019.Jun.03 SPC Camber Bolt Kit Front - 2013+ BRZ SPC ADJUSTABLE LOWER CONTROL ARMS (REAR) W/ TOE KIT - 2013+ FR-S / BRZ Perrin Inlet Hose for 2017 BRZ / 86 Manual I went a car show a week ago with my friends, which is my first time to entry a car show. To be honesty, i entry the show because all my friends entries. People open the hood show the engine bay where i am bone stock. So I did this. that is the front tire after one track day, and it is the reason I got a camber bolt. Meanwhile I am research the number I want get from alignment, I find out I need a rear control arm for the rear camber. 2019.Jul.29 Harry's Laptimer should be working already at track day since there is track info for VIMC but still not getting used for auto x. the timer not stop after finish line Ram phone mount very solid mount, i really recommend it work perfect with Harry's lap timer all the data was right Arai Quantum-X Solid Helmet It is my first helmet, bought it for auto X 2019.Aug.15 Racing number & Name Decals 2019.Aug.17 Alignment I did some permit paint just wanna to prevent the rust and I was planning to install the control arm and camber blot myself but just being lazy, was thinking it should be around $100 more but yea it was $210 for installed those two anyway, it is most expensive alignment i had ever done ![]() but the result is great overall very good alignment, but wont ask them to do any installation for part tho car drive amazing they did their best for caster a bit off but acceptable i think the front and rear was not done by the same guys from factory the rear just perfect from factory,and it is explain why my rear tire wearing so even i did change 2 front tires before the alignment the closest event will be auto x, will test it all! 2019.08.23 Sparco 002093AZ2M - Meca 3 Blue Medium Glove i really like frs 's steering wheel, 17 86 steering wheel is all leather get stick for unknown reason. since last time i bought sparco ergo seat with very bad quality i don't like sparco anymore but i really wanna a short gloves and that the only thing i found fitment is good, quality is good 2019.09.08 Jackson Racing Engine Oil Cooler Kit - 2013+ FR-S / BRZ Model NA just bought this, hopefully I will get it before last trackday and get it installed. 2019.09.11 OBD2Link MX+ very easy to use, got it from amaze. much cheaper to get oil temp and other data Piloti Racing Shoes my second one very good shoes. every time i drove other manual car, my left foot is kind leave with that car for a day maybe. very sensitive on clutch feeling, even change the shoes will cost some and i found this shoes. 2019.11.27 Jackson Racing Engine Oil Cooler Kit - 2013+ FR-S / BRZ installing finally get a time to do this. it is my first time take off my front bumper, and the YouTube video really help me a lot. here is the link for the video i found [ame]http://www.youtube.com/watch?v=_EOskL7XIw0&list=PLAP_wQ5ajd5woWPvVXCuwr-Ds4vtiwf1t&index=14&t=466s[/ame] for the installing there are some tools you need 1.clip remove tool 2.27mm socket 3.general tool box mainly 10mm and 12mm socket jack stand 4.high temp sealant 5.29mm open wrench 6.6.5L engine oil 7.that space for doing to oil change 8.tape for cover the fender and headlight prevent scratch the paint by the time you take off your bumer after you save toke off the bumper, take off the head light and those intake ducts. then just follow the instruction from the jackson racing right now is 2degree outside, it took me 30 mins to warm up my car to 80degrees. once the oil temp go over 80, the cooler since start to work. my oil temp stay at 80 forever. really like this, will see on the summer track day. 2019.12.07 Bell M8 helmet Hans adjustable full SA2015 & FIA approved with hole build in design touch with hans that arai helmet is SA2015 but i need drill the hole. Photos Track Video 16 Scion Frs [ame]http://www.youtube.com/watch?v=13lZnjhTLsE&t=328s[/ame] with bone stock had been there 4 times, pb at 1.36 and i decided to change tires and brake pads 17 Toyota 86 [ame]http://www.youtube.com/watch?v=nZVoOEvoeLk&list=UUBXFeelPFI8XzGese8Eug-g&index=2[/ame] MXP RS ti tip catback K&N air filter K&N oil filter Motul Eco 0W20 engine oil RPF1 17x8 +45 RE71R 245 40 17 all around Front Hank DTC 60 brake pad Front StopTech Rotor Front StopTech Brakelines others r stock a racing seat maybe my next move, it was my first time used re71 had used stock tire all the time. way much better compare to before the pads were really getting hot since this is our last section. best around 1.28~1.29 from video this time. it was huge improves compare last time with stock tires and brake pad stock on 1.36 average is 1.30 this time 2019.08.31 [ame]http://www.youtube.com/watch?v=72HigUE5P1Q[/ame] [ame]http://www.youtube.com/watch?v=OLwCQtgIxDk[/ame] set my new best time as 1:2581 it could be wrong, the data is mass up but i did it twice at 1:2581 and 1:2598 go pro only got one section when i link the lap timer with go pro found on video very close to 1:26 just between video1 and video2 ![]() if the lap timer did more accuracy on start and finish time, it could be right the trail braking really open to a new world, a lot of things to improve new references point and try to be constant next time will do it again in end of Sep and i am already paid ![]() hopefully no rain this time Auto X [ame]http://www.youtube.com/watch?v=y2Z0IPcxFyA[/ame] it was my third auto x need more seat time not the best of the day cause my go pro is died this was the second best. but i manage myself got first in all the gt86! class in stx just because the 245 tire size compare to the stock i may going to stock size next time! [ame]http://www.youtube.com/watch?v=SLgFVKBsPng&t=30s[/ame] Team Enduro AutoX "twice+1" first place in the PAX time ![]() Bottle of beer for everyone in the team A free event for me as the fastest in novice ![]() 2020.03.08 hard compound n low temp spark brake dust ![]() and i took the pad off to prove i am not run out the pad open for all the driving tips!!!! currently -wait for the end of Oct track day, and be constant and make sure my personal best is right at 1:2581 -thinking to keep using the old tire or not, it is not that bad. but not good for set personal best time tho -waiting for the jackson racing oil cooler
YouTube Video:http://www.youtube.com/channel/UCBXFeelPFI8XzGese8Eug-g
ins:zayliu.jiayu Build Journal:http://www.ft86club.com/forums/showthread.php?t=136068 "if in doubt flat out" Last edited by jayliu.jiayu@gamil.com; 03-08-2020 at 11:10 PM. |
| The Following 3 Users Say Thank You to jayliu.jiayu@gamil.com For This Useful Post: |
#2 |
Drives: ZC6
Great driving! I've always wanted to drive at VIMC, but the trip is so expensive with the ferry ride.
Do you plan on going to any other tracks?
2015 Subaru ZC6 BRZ
SPC Front Camber Bolts - PMU Club Racer Advance - GT Radial Champrio SX2 215/45/17 - HKS Type-S Oil Cooler - Verus Engineering Fuel Starvation Door |
#3 |
I want to try area 27 for the nearly futures, but I know it is going to be expensive compare the vimc, the up coming lapping day at end of sep will be 400!!!! Usually is $450
ins:zayliu.jiayu Build Journal:http://www.ft86club.com/forums/showthread.php?t=136068 "if in doubt flat out" |
#4 |
update on aug.17
#5 |
update on aug.23
sparco gloves!!
#6 |
update on aug.26
team enduro
#7 |
update on aug.31
trackday with new personal best
#8 |
update on 2019.09.11
obdlink mx+ and plioti shoes
#9 |
update on 2019.11.27
oil cooler install
#10 |
trackday on 2020.05.31
any suggestion or tips to get me faster?
ins:zayliu.jiayu Build Journal:http://www.ft86club.com/forums/showthread.php?t=136068 "if in doubt flat out" Last edited by jayliu.jiayu@gamil.com; 06-08-2020 at 07:39 AM. |
| The Following User Says Thank You to jayliu.jiayu@gamil.com For This Useful Post: | alphasaur (06-08-2020) |
#11 |
Drives: Subaru BRZ
Hey mate. Great to see you using your car in the way they were intended.
My advice is to aim for consistent lap times. Then you can start to test different things and measure their effect. If you are not consistent you will not know if any changes to driving technique have made a difference, or if it is just random error. Sent from my SM-G973F using Tapatalk |
| Toyota 222D: The Story Behind Toyota’s Secret Group S MR2 Rally Car | vh_supra26 | Other Vehicles & General Automotive Discussions | 2 | 05-25-2017 09:10 AM |
| Production Toyota FT-86 Details and Design Previewed by Toyota Sports Vehicle Boss | ft86cbx | Scion FR-S / Toyota 86 GT86 General Forum | 541 | 11-18-2011 10:04 PM |
| Toyota FT-86 G's Sport Concept moved to Toyota Mega Web showroom at Odaiba | Kenji | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 23 | 05-02-2011 02:11 AM |
| Toyota FT-86 G-Sport Concept car displayed with AE86 at Toyota Amlux, Tokyo | Kenji | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 03-09-2010 12:09 AM |
| Report: Toyota chooses alternative Toyota FT-86 design (by Calty studio)! | Nemesis | Scion FR-S / Toyota 86 GT86 General Forum | 128 | 02-19-2010 12:36 PM |
