| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Red 86
Durable Wheels !
As much as I hate starting new topic, I couldn't find a clear answer for what I'm looking for.
I was about to get the Enkei RPF1 until I saw a lot of ppl online complaining about the durability of the wheels mostly the barrel getting bent easily. I daily drive my 86 and will be taking it to the drift track later on this year. I wanna get the most durable wheels without breaking the bank. I'm looking into Gram lights 57CR or Weds TC105N, but the TC105N are about 400$ more expensive. My question is are the TC105N 400$ more durable than the 57CR or it's not that big of a difference in durability? Sorry for the long ass post. Sent from my SM-G975F using Tapatalk |
| The Following User Says Thank You to Glitchy86 For This Useful Post: | sato (10-05-2022) |
#2 |
Drives: 2017 BRZ
I only see a ~$200 price difference, but hey. Both are, by all accounts, really good wheels. I believe the 57CR are heavier, which may be a good thing for your goal. Either are excellent.
The other thing to remember is that, when you get into racing, wheels become a wear item. You hit curbs, rumble strips, etc. and over time they wear out. Sometimes less time. Bending a wheel means it's not garbage; the cheap stuff cracks or shatters. Another wheel to consider on a bit more of a budget is the 949 6ul. A bit heavier build than the RPF1. You'll still bend it on a hard curb hit (honestly, you're likely to bend any wheel if it's hard enough). I run TC105n (note, the TC105x is the new version of this... anything 'n' is old stock, if it's actually even in stock...) and 6ul. Prefer the look of the Weds, but from inside the car I can't see that...
#3 | |
Drives: Red 86
I got a deal on the 57CR in ceramic white for 1400$ in the other hand the Weds cost about 1780$. I'm trying to get the price for the Weds to match the 57CR. I live in Saudi Arabia and the shipping will cost me so much money that's why I wanna be sure whichever wheel I get will be durable coz I can't afford to ship a fucked up wheel that is under warranty back to the US to get it replaced. Never thought picking a wheel will be so damn hard lol. Sent from my SM-G975F using Tapatalk |
| The Following User Says Thank You to Glitchy86 For This Useful Post: | cjd (07-29-2019) |
#4 | |
Because compromise ®
Drives: Red Herring
A few things come to mind. 1/ I was under the impression that RPF1s were very good value for their weight and strength. 2/ Any wheel will deform/break given sufficient impact. 3/ I went searching for stories about these wheels' poor performance and admittedly I did not spend much time looking but the only stories I found was about cracking/bending after they had had a heavy impact with a kerb or pothole. Would @CSG Mike share his opinion?
#5 | |
Drives: Red 86
Is post along side the comments is that one made me think about not getting the RPF1. I just want something that won't get bent/cracked so easily and trying to ask ppl in here coz I know so many ppl have a lot of experience not like myself. Sent from my SM-G975F using Tapatalk |
#6 |
Drives: 2014 GT86
Glitchy86: then again upon those few posts where they bent wheels, imho there are at very least 10x times more that keep happily using them just fine. And i see nothing to point to rpf1 wheels as being weaker then many others, that for that specific (ab)use won't bend other wheels too.
Also given popularity of rpf1, imho they are in many places easier to source if need for replacement arrives. Given that they are overall imho of good compromise of strength/weight/cost, i see no reasons to not get them, unless one knows that will do gravel rallying
| The Following User Says Thank You to churchx For This Useful Post: | timurrrr (07-29-2019) |
#7 | |
Drives: Red 86
So out of the three that I listed is any of them are significantly more durable than the other or are they pretty close to each other durability wise. Thanks again. Sent from my SM-G975F using Tapatalk |
#8 | |
Drives: Red Herring
The second post says "I know a few local Time Attack teams who used to run RPF1's and they would bend quite a few of the wheels after a seasons use due to various berms or track off's." My bold. As I said, any wheel will deform/break given sufficient impact. I'm guessing you've seen the RPF1 thread? http://www.ft86club.com/forums/showthread.php?t=58908
#9 | |
Drives: Red 86
I'm a noob and that's why I'm asking the guys like yourself who bought aftermarket wheels many times. Just want to make sure I'm getting a good set of wheels. Sent from my SM-G975F using Tapatalk |
#10 | |
Drives: Red Herring
CSG Mike hasn't chimed in as yet but he and his shop (Counter Space Garage) is extremely well regarded on this forum. CSG sells RPF1s and he doesn't sell crap.
#11 |
Drives: 2022 GR86
RPF1s are a great value for money for AutoX. They would still be a great product even if they completely melted after just one lap at the track.
A friend of a friend recently switched from PP wheels to RPF1s and managed to bend one on a pothole within weeks. Now he hates them 💁*♂️ Some of the folks I've met at AutoX and track say that RPF1s are great, but are also based on outdated tech and modern lightweight wheels are stronger. To the OP: having said that, if you plan to keep the car for at least a few years, you should think about what you optimize for. It seems like RPF1s are great if one optimizes for weight at the least amount of money that's reasonable. IIRC, the next lighter wheel in the same size would be TC105N, which is basically twice as expensive. What you should probably optimize for however is lifetime per dollar. You might literally be better off buying rally wheels for an STI. Another possible solution is just to accept the fact that you'll bend a wheel every once in a while, and save on shipping costs by buying them 6 or even 8 per order. |
| The Following User Says Thank You to timurrrr For This Useful Post: | Glitchy86 (07-29-2019) |
#12 |
Only happy when it rains.
Drives: series.blue
Buy forged wheels, they are totally worth it. I had a set of Volk Ce28n on my Yaris that I use to daily. After a decade of use $2000 or so isn't a big deal. I didn't have to worry about anything, they were awesome.
| The Following User Says Thank You to why? For This Useful Post: | Glitchy86 (07-29-2019) |
#13 |
Drives: 2014 GT86
Not so sure on "worth it". If buying new, i'd strongly disagree. Well, in one way is - if you buy those forged wheels used, at fraction of price. Though choices of specific sizings might be limited.
| FRS Seat material durable? | IronDuke | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 02-14-2016 08:03 PM |
| How durable are Michelin Pilot Super Sport on the track? | Ferrari | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-21-2014 11:55 AM |
| Whiteline Tie Rod Replacements - More Durable than Stock? | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 05-30-2014 10:06 PM |
| How durable is it?? | SubarooMike | Other Vehicles & General Automotive Discussions | 7 | 11-15-2012 07:46 PM |
| Wheels, Wheels, Wheels | Island Import Performance | IslandImportPerformance | Wheels and Tires | 4 | 07-31-2012 10:08 PM |
