Old 07-28-2019, 11:40 PM   #58703
LiamBlack
LiamBlack's Avatar
Drives: 17 BRZ
The best is my post Ok, tell me how was your weekend?
LiamBlack is offline
Old 07-28-2019, 11:41 PM   #58704
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
What day is it?
Sapphireho is offline
Old 07-28-2019, 11:47 PM   #58705
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Originally Posted by cjd View Post
Go out with the lawn mower. You'll find it. Never fails.
just, stand clear so you don't get hit with shards of flying metal...
I've mowed 3 times, nothing flying. Love my John Deere.
cjd (07-29-2019)
Old 07-28-2019, 11:49 PM   #58706
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Do not give a woman going thru the "change" access to the thermostat. I woke up from my nap in a 68° house.
humfrz (07-29-2019), spike021 (07-28-2019)
Old 07-28-2019, 11:58 PM   #58707
soundman98
ProCrastinationConsultant
soundman98's Avatar
You need to set her up with a window unit in the sewing room
soundman98 is offline
Old 07-29-2019, 12:01 AM   #58708
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Laundry room doesn't have a window.
soundman98 (07-29-2019)
Old 07-29-2019, 01:23 AM   #58709
Best you just leave her be, unless you want to suffer the after effects of a "meltdown" -
humfrz is offline
Sapphireho (07-29-2019)
Old 07-29-2019, 01:39 AM   #58710
Here ya go (I'm being serious). This will be the best $30 you ever spent.
No matter what the temperature is, meltdowns will happen. I suggest you place this puppy close to where she usually sits, so she (NOT YOU) can turn it on whenever she wants. HINT: Don't YOU turn it on or she will attack.
NEVER ask her why it's ON, it don't matter if the house is 65 degrees F and you are wearing heavy sweat pants, a flannel shirt and a cotton vest.
humfrz is offline
Sapphireho (07-29-2019), soundman98 (07-29-2019)
Old 07-29-2019, 01:48 AM   #58711
Septic. Have a guy coming out Tuesday to locate it and pump out.
When he arrives, ask him to see a copy of the "As-Built", which he should have. That sketch will show the location of the tank and drain fields plus reserve field (if necessary in that area).
humfrz is offline
Old 07-29-2019, 01:57 AM   #58712
Originally Posted by Stephen W. View Post
Here in Ontario, (Canada) when you purchase a country property the seller is responsible for filling the oil and/or propane tanks as well as pumping out the septic tank. There should be a recent (within 10 years) survey showing the lot lines, the house and any under ground pipes, fixtures and cables. This must be verified by the buyers lawyer before the deal can close. The one exception is if you buy "as is" with no conditions.
I'm dealing with a septic issue myself right now. It appears the last three times we've had the tank pumped they only removed one cover. The second cover was part way under a concrete walk so they never tried to remove it. I had the walkway busted up and the tank cleaned last week. Unfortunately the out flow pipe seems to be plugged. The crew who were here thinks it's either been crushed or plugged by roots. There are two giant trees either side of where the pipe exits the tank not to mention an over grown bush right on top of it. Tomorrow I get out the chain saw and remove the bush. Then, start digging to find the pipe.
Yep, same here in Washington, the seller has to have the septic inspected and pumped (if not recently done) prior to a sale and transfer of title.
I have owned three houses that have been on septic and all three were problems when I sold them (although they worked fine - ).
During my 10 years of being a real estate broker, I sold hundreds of houses that were on septic. Interesting stories I could tell - shut up humfrz, no one wants to hear your shit stories!
humfrz is offline
Old 07-29-2019, 09:22 AM   #58713
This is why I will always live in a city where they have heard of real sewer systems!
Tcoat is offline
humfrz (07-29-2019)
Old 07-29-2019, 09:51 AM   #58714
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Like anything, you take care of it, it works great. I have septic at both my properties.
Old 07-29-2019, 09:57 AM   #58715
qcbaker
Shitpost Generator v8.6
qcbaker's Avatar
Originally Posted by qcbaker View Post
Well, I just got another hit on my CL ad. If this one doesn't work out I'll probably have my dad post it up on there as well.
This one worked out, the bike is finally sold.
Sold it to a younger dude who was gonna learn to ride on it. He brought his dad who was licensed to come ride it home, but the dad hadn't ridden a bike for something like 4 years. He stalled it out like 5 times trying to test ride, then when restarting it, held the starter button for way too long and nearly burned it out, causing a little bit of smoke to come off the side of the bike. The starter still seemed to work fine though so :dunno_black: . Hope the dad was able to ride it home okay lol
qcbaker is offline
The Following User Says Thank You to qcbaker For This Useful Post:
humfrz (07-29-2019)
Old 07-29-2019, 10:10 AM   #58716
But, even then, sometimes -
humfrz is offline
soundman98 (07-29-2019), Tcoat (07-29-2019)
