Old 07-28-2019, 04:26 AM   #1
mcnvgget
mcnvgget's Avatar
Drives: 2018 Toyota 86
static offset on stock body
hi guys, i’m trying to get my 86 to be more static and i’m having a hard time trying to get information on wheel specs n such. i’m tryna see if i can run BC extreme low coilovers with 10 inch wheels in the rear and 9.5 front with 225/35/18’s all around with lower control arms but not sure which ones to get, i was thinking of just getting SPC’s for that toe adjustment, and what offset would be best for camber for the front and rear? i see people having like super deep dish rims and i just dunno pls help!
mcnvgget is offline   Reply With Quote
Old 07-28-2019, 05:28 AM   #2
86MLR
86MLR's Avatar
I had to google what static meant IRT cars.
I pity humanity
Old 07-28-2019, 07:32 AM   #3
new2subaru
Weight Weenie
Drives: 15 FR-S
I pity humanity
I had to google what IRT meant
Old 07-28-2019, 08:32 AM   #4
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
I had to google Google
Jesse36m3 is offline   Reply With Quote
Old 07-28-2019, 09:59 AM   #5
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Most people in this section of the forum are interested in improving the performance of the car, not wrecking it. Wheel and Tire and Suspension is where you want to be.
PetrolioBenzina is offline   Reply With Quote
Old 07-28-2019, 12:48 PM   #6
extrashaky
Drives: 2014 BRZ Limited
I don't think he's even using the term correctly. How do you get more static than stock?
Does he want to be more static than static? Is that like more human than human? Is Philip K. Dïck rolling in his grave by now?
Ice Road Truckers?
Old 07-28-2019, 03:46 PM   #7
I pity humanity
An explanation for the old guys from some dude on the internet:
"stance is a broad term for lowering your car and fitting wide wheels that fill up the wheel wells. Static is a form of stance where the car is lowered via static suspension components such as coilovers. While coilovers are adjustable they cant be adjusted without lifting the car and spending 30 minutes with a wrench. Static means the caris stuck at that ride height. The opposite to this is bagged cars which use airbags similar to the hydraulics on lowriders. These can be easily raised or lowered with a switch at an instants notice. Typically the static folks like to think they are more hardcore or dedicated because they arent afraid of destroying their carevery time a speed bump comes. The bagged guys are viewed as semi cheating since they can put the car at any ride height they want and if they park super low its not a badge of honor that they drive that low like a static dude. I think the whole phenomenon is stupid with a special emphasis on how dumb static cars are."
An example from the old days. Hey old guys, you do remember at least one of these in your neighborhood (county) ??
Old 07-28-2019, 03:54 PM   #8
Old 07-28-2019, 03:54 PM   #9
Cole
Not a troll
Cole's Avatar
You’re gunna want that offset well into the -20’s or even -30’s.
Alternatively, you could be not lazy and do your own math to figure out how many offsets you need to make your car useless.
Cole is offline   Reply With Quote
Old 07-28-2019, 04:02 PM   #10
I can't find it - when applied to automobiles - ??
Maybe my Google is not big enough -
Old 07-28-2019, 04:15 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
i'm completely lost in this thread.
static is how i used to shock my sister after i'd scrub my socks on the carpet.
IRT is the sound windshield wipers make as they move across dry glass.
i have no clue what either of these things have to do with lowering a car.
Old 07-28-2019, 05:02 PM   #12
WAT automobiles
Old 07-28-2019, 05:19 PM   #13
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Soooo isn’t static waaaayy too mainstream, bro? Like everyone and their mom has static ride height!
Old 07-28-2019, 06:16 PM   #14
Back in the day, some idiots would remove leaf springs in the rear to where frame would sit on the axle. If that wasn't low enough, they would heat the remaining spring with a torch until it was.
Then they would heat the front coil springs until the front part of the frame would rest on the cross member. If that didn't get the front low enough, one would simple cut some of the coils out of the springs.
Back then, we didn't call it "static", we called it "stupid".
So, what's the stock offset? rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 12-17-2018 10:47 PM
BRZ Stock Head Unit + iPod through USB = Occasional Static? Cope Electronics | Audio | NAV | Infotainment 0 10-05-2016 11:09 AM
What offset wheel to run with V3's and wide body jay1989 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-24-2014 01:28 AM
Static audio with radio reception? FRS stock stereo encity5 Electronics | Audio | NAV | Infotainment 14 10-02-2013 09:58 PM
Stock Wheel offset smbrm Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-15-2012 12:09 PM
