Old 07-26-2019, 10:02 PM   #15
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I don't understand why anyone would want a shorter shifter in this car?
Anyone?
The shifter shouldn’t actually be shorter, it’s the throws that are.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
humfrz (07-26-2019)
Old 07-26-2019, 10:12 PM   #16
Thanks.
OK, so why would anyone want shorter throws?
Ultramaroon (07-27-2019), Yoshoobaroo (07-27-2019)
Old 07-26-2019, 10:17 PM   #17
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
IRP, broke boy
Dr. BRZ is offline   Reply With Quote
Old 07-27-2019, 10:07 AM   #18
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Quite simple...there are only two choices for best short shifter I'm aware of: CAE Ultra shifter or the IRP shifter. Both are of similar design and entirely replace the factory setup unlike every other shifter out there - no rubber bushings anywhere in them. Direct, solid connections with ZERO play and one of the most satisfying shifting feel you'll ever get. Plus you get short throw with longer lever that puts the shifter at a more ideal height than most factory shifters. Of course with these you are talking $$$$...especially for the CAE Ultra shifter.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following 3 Users Say Thank You to Vracer111 For This Useful Post:
churchx (07-27-2019), Dr. BRZ (07-27-2019), why? (07-27-2019)
Old 07-27-2019, 12:23 PM   #19
WNDSRFR
Drives: FR-S,GTI
Shorter throw+Longer lever=?
The Following User Says Thank You to WNDSRFR For This Useful Post:
humfrz (07-27-2019)
Old 07-27-2019, 12:33 PM   #20
Vracer111
Vracer111's Avatar
Shorter throw than stock even with the longer lever...
The Following 2 Users Say Thank You to Vracer111 For This Useful Post:
humfrz (07-27-2019), why? (07-27-2019)
Old 07-27-2019, 12:49 PM   #21
jc7993
Drives: Looking to buy
What would be the best shifter that is not like the IRP/CAE? Looking for something that is like stock form but have shorter throw and no rattle. There were other options like the TRD quick shifter but there were reviews where you need to go back and check on it every once in a while because it came come loose which is something that I definitely do not want to do and waste my time on. The FT86SF short shifter option has a rattling noise that people says it has in higher rpm/gears. So it seems like there are always some kind of drawbacks...
jc7993 is offline   Reply With Quote
Old 07-27-2019, 12:50 PM   #22
Joveen
Joveen's Avatar
Drives: Bone stock
Raceseng makes an adapter that connects the reverse lockout to make it longer.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 07-27-2019, 12:54 PM   #23
OK, I watched the movie.
My question still is, why would anyone want shorter throws?
Old 07-27-2019, 01:00 PM   #24
Vracer111
Vracer111's Avatar
Well they are designed for racing use... you have to decide on if you want best shifter feel or no added noise but stockish feel. The IRP / CAE feel nothing like stock, everything else is a varation of stockish feel.
The Following User Says Thank You to Vracer111 For This Useful Post:
humfrz (07-27-2019)
Old 07-27-2019, 01:11 PM   #25
Vracer111
Vracer111's Avatar
Depends on the vehicle... but can shift quicker or same with less effort on the IRP /CAE. Quicker can be a problem though as they can easily shift too fast for the synchros. The stock FR-S throw is fine to me, but the IRP / CAE appeal to me is more about their shift feel and absolute precession with ZERO slop unlike traditional short shifters. Like an HK semiauto pistol versus a Ruger...racking the slides are two very different experiences. German engineers seem to know something about the feel of precision...and it feels just right.
Now on my Nissan Frontier I absolutely want the PRG Racing short throw shifter....way too much movement of entire arm required for stock, a little too much reach for the forward gears - ain't no shifting with the wrist movement.
humfrz (07-27-2019), jcw99 (07-27-2019)
Old 07-27-2019, 01:15 PM   #26
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
because the quicker the shifts the less time your hand is off the wheel. And the CAE is even better because the shifter is closer to the steering wheel, so you spend even less time shifting. Plus it justs feels better, and there is no way to screw up or miss shift. Look at how little the shifter actually moves.
Go to 1:15 or so
why? is offline   Reply With Quote
The Following 2 Users Say Thank You to why? For This Useful Post:
humfrz (07-27-2019), Plumbus (10-30-2020)
Old 07-27-2019, 01:41 PM   #27
Go to 1:15 or so
OK, so, if one would like less time off the steering wheel, it would seem that an AT with paddle shifters would be even better -
As far as feeling better, maybe that's because many new drivers are used to the feel of the toggle things on game controllers? -
As far as miss-shifting, it would seem to me that the closer the shift positions are the less margin of error there is, thus more of a chance of miss shifting. Hell, in my old 1937 Chev pickup with a floorboard shifter, second gear was anywhere from pointing the shifter towards the speedometer all the way over to the glovebox -
Old 07-27-2019, 02:52 PM   #28
Go to 1:15 or so
Quicker shifting is a myth. The shift speed is limited by the time it takes for the syncro to slow down or speed up the input side of the gearbox. A short-throw lever only decreases the force the operator applies to the syncro clutches.
They feel cooler. That's all.
humfrz (07-27-2019), Tcoat (07-27-2019)
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 09:57 PM
TRD Short Shifter FNCrazy Engine, Exhaust, Transmission 22 07-02-2016 12:58 PM
cae ultra shifter vs short shifter jdmblood Engine, Exhaust, Transmission 22 01-13-2016 11:19 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 01:24 AM
