Old 07-19-2019, 04:54 PM   #1
Tom Brady
Drives: 2015 Scion FRS
New Tires HELP!
Hello ladies and gents, I am swapping out the OEM wheels, for some 18x8.5 with a +33 offset wheels. The fact of the matter is, I need new tires. I do not want to spend a whole lot on tires, but at the same time do not want to go super cheap. A happy medium if you will. Please list down below recommended tires. I do not track this car, but I want a sticky tire that I can full send my car on, around turns and stick to the ground. Thank you in advance!
Tom Brady is offline   Reply With Quote
Old 07-19-2019, 05:20 PM   #2
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I have no experience with these tires but the reviews are solid and I do plan on buying them eventually. I'm guessing because I'm not too familiar with the sizes for 18s, but I'd say a 245/35/18 should be nice and meaty on those wheels. If not that size, then this tire seems to be pretty widely available.
https://www.tirerack.com/tires/tires...omCompare1=yes
Cheaper option, again no experience with this tire, no plans to buy, but it has good (if not very many) reviews.
Expensive option and the recommendation you will probably receive regardless of your request for a cheap option because they are gold standard tires. My personal experience with them was amazing.
Nevermore is offline   Reply With Quote
Old 07-19-2019, 05:34 PM   #3
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
There’s tons of info on this. Top two I’d recommend are Nitto Neo Gens and Indy 500s. There are those cheap Federal 595s but I’ve heard they have a lot of road noise which would be bad for daily driving.
I personally would not cheap out on tires. I would rather cheap out on wheels to get quality tires. They’re important not just for performance, but for safety as well.
Will BRZ is offline   Reply With Quote
The Following User Says Thank You to Will BRZ For This Useful Post:
wparsons (07-25-2019)
Old 07-19-2019, 05:58 PM   #4
JD001
JD001's Avatar
Drives: Subaru BRZ
I would never skimp on tyres, brakes and disks.. 8.5inches of contact patch at each corner of the car is not much and far more risker on shittier tyres.
The Following User Says Thank You to JD001 For This Useful Post:
Old 07-19-2019, 06:55 PM   #5
new2subaru
Weight Weenie
Drives: 15 FR-S
This, buy cheap wheels but good tires.
Old 07-20-2019, 12:17 AM   #6
Tristor
Tristor's Avatar
Firestone Firehawk Indy 500s are probably the cheapest tire that performs decently well.
If you've got the ching, Michelin PS4S.
Tristor is offline   Reply With Quote
Old 07-20-2019, 01:50 AM   #7
Grey86
Grey86's Avatar
Drives: Tornato grey 86
nitto invo sticky but very quiet tires for decent price
Grey86 is offline   Reply With Quote
Old 07-20-2019, 10:39 AM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
245/35/18 is a great size, I run it. But it costs way more. 225/40/18 indy 500 costs $118, a 245/35/18 indy 500 costs $188.
For someone on a budget, id suggest 225/40s.
I LIKE TIRES!
Old 07-20-2019, 11:55 AM   #9
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Do these tires need to do late fall-winter-early spring duties?
Old 07-21-2019, 12:45 PM   #10
meWant
Drives: '16 BRZ Limited
Or go a touch wider. 255/35/18 indy 500 cost $138.50 on tire rack. and they'll fit the wheels fine.
meWant is offline   Reply With Quote
Old 07-25-2019, 11:23 AM   #11
Jordanwolf
Rice King
Jordanwolf's Avatar
What if you've only got the chong?
Glorious Honda.
Jordanwolf is offline   Reply With Quote
The Following 2 Users Say Thank You to Jordanwolf For This Useful Post:
Leonardo (07-25-2019), meWant (07-25-2019)
Old 07-25-2019, 11:51 AM   #12
Leonardo
Country Boy 4 Life
Leonardo's Avatar
IMO, a 255 is for a 9.5" wheel. Additionally, the 225/40 will fit better on 18x8.5 +33 wheels on OEM suspension (that I assume OP still has).
I LIKE TIRES!
meWant (07-25-2019)
Old 07-25-2019, 01:39 PM   #13
meWant
While I agree that the wider wheel would be ideal for the 255, OP wheel size still is within the recommended range for the tire. And theres no issues with rubbing in that size (on 18x8.5+35 with 255/35/18 indy 500 myself. Only diff is I'm lowered on rce yellows)
But overall I do agree with you. Just wanted to give OP another suggestion.
Old 07-25-2019, 01:54 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The recommended range is just that a "range". The "sweet spot" on the other hand is in the middle of the range. And, IMO, our car is more sensitive to having tires/ wheels/ suspension dialed into (or out of) the "sweet spot".
I had 255/35 on a 8.5 before, I felt it was pinched.
I LIKE TIRES!
meWant (07-26-2019)
Toyo Tires Proxes Sport - New max summer performance tires DarkSideFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-18-2018 05:06 PM
2 Sets of tires, 1 Half a set of tires, 2 Sets of wheels+tires, 1 TPMS Sensor Jayela Wheels and Tires 0 04-23-2018 03:45 PM
TIRES, TIRES, TIRES! @ Pure Automotive Performance Pure Automotive Wheels and Tires 1 02-04-2013 02:32 PM
FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped apexsti46 Wheels and Tires 6 09-05-2012 02:54 AM
