| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2015 Scion FRS
New Tires HELP!
Hello ladies and gents, I am swapping out the OEM wheels, for some 18x8.5 with a +33 offset wheels. The fact of the matter is, I need new tires. I do not want to spend a whole lot on tires, but at the same time do not want to go super cheap. A happy medium if you will. Please list down below recommended tires. I do not track this car, but I want a sticky tire that I can full send my car on, around turns and stick to the ground. Thank you in advance!
#2 |
Wayward Member
Drives: Hot Lava 86
I have no experience with these tires but the reviews are solid and I do plan on buying them eventually. I'm guessing because I'm not too familiar with the sizes for 18s, but I'd say a 245/35/18 should be nice and meaty on those wheels. If not that size, then this tire seems to be pretty widely available.
https://www.tirerack.com/tires/tires...omCompare1=yes Cheaper option, again no experience with this tire, no plans to buy, but it has good (if not very many) reviews. https://www.tirerack.com/tires/tires...omCompare1=yes Expensive option and the recommendation you will probably receive regardless of your request for a cheap option because they are gold standard tires. My personal experience with them was amazing. https://www.tirerack.com/tires/tires...omCompare1=yes
#3 |
Damn that's crazy...
Drives: 2015 BRZ
There’s tons of info on this. Top two I’d recommend are Nitto Neo Gens and Indy 500s. There are those cheap Federal 595s but I’ve heard they have a lot of road noise which would be bad for daily driving.
I personally would not cheap out on tires. I would rather cheap out on wheels to get quality tires. They’re important not just for performance, but for safety as well. |
| The Following User Says Thank You to Will BRZ For This Useful Post: | wparsons (07-25-2019) |
#4 |
Drives: Subaru BRZ
I would never skimp on tyres, brakes and disks.. 8.5inches of contact patch at each corner of the car is not much and far more risker on shittier tyres.
| The Following User Says Thank You to JD001 For This Useful Post: | wparsons (07-25-2019) |
#5 |
Weight Weenie
Drives: 15 FR-S
#6 |
Firestone Firehawk Indy 500s are probably the cheapest tire that performs decently well.
If you've got the ching, Michelin PS4S. |
#7 |
Drives: Tornato grey 86
nitto invo sticky but very quiet tires for decent price
#8 |
Country Boy 4 Life
245/35/18 is a great size, I run it. But it costs way more. 225/40/18 indy 500 costs $118, a 245/35/18 indy 500 costs $188.
For someone on a budget, id suggest 225/40s.
I LIKE TIRES! |
#9 |
The Dictater
Drives: '13 Red Scion FRS
Do these tires need to do late fall-winter-early spring duties?
#10 |
Drives: '16 BRZ Limited
Or go a touch wider. 255/35/18 indy 500 cost $138.50 on tire rack. and they'll fit the wheels fine.
#11 |
Rice King
What if you've only got the chong?
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#12 |
Country Boy 4 Life
IMO, a 255 is for a 9.5" wheel. Additionally, the 225/40 will fit better on 18x8.5 +33 wheels on OEM suspension (that I assume OP still has).
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | meWant (07-25-2019) |
#13 | |
But overall I do agree with you. Just wanted to give OP another suggestion. |
#14 | |
Country Boy 4 Life
I had 255/35 on a 8.5 before, I felt it was pinched.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | meWant (07-26-2019) |
| Toyo Tires Proxes Sport - New max summer performance tires | DarkSideFRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 09-18-2018 05:06 PM |
| 2 Sets of tires, 1 Half a set of tires, 2 Sets of wheels+tires, 1 TPMS Sensor | Jayela | Wheels and Tires | 0 | 04-23-2018 03:45 PM |
| TIRES, TIRES, TIRES! @ Pure Automotive Performance | Pure Automotive | Wheels and Tires | 1 | 02-04-2013 02:32 PM |
| FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped | apexsti46 | Wheels and Tires | 6 | 09-05-2012 02:54 AM |
