#5041 |
Every car varies in what it likes; no two engines are alike, but super rich is what you do when you want to "play it safe" and not really spend the time to dial it in. JRSC boost levels are not unknown territory. If you're using a one time off-the-shelf tune, then sure, I get why its rich. If you're getting a custom tune, it doesn't need to be.
My personal boosted car (turbo) runs typically around .82 lambda under WOT. This is ~~12:1 |
#5042 |
Drives: Q5 + BRZ + M796
I'm running a Harrop kit with e85 at an AFR that is in the high 11's at WOT. Tuned by Zach when he was at DT, who is now at CSG.
#5043 | |
2013 Series 10 FRS #553
#5044 | |
#5045 |
Drives: 2013 FRS
Anyone running the Verus brake duct kit with the JRSC kit? With the smaller wiper reservoir and the IC tubing I'm trying to remember how much space was left in there for brake duct tubing.
#5046 |
Drives: '14 BRZ Limited
I was mistaken. When I said 11.2 AFR @ full boost that was me glancing at my gauge while driving, just took a log on the highway and it reads 12.17 AFR @ full boost. Waiting for Mike to tell me where I can send it, anybody else wants to take a look let me know.
Also, @kowalski wanted to know temps from the JRSC dual cooler. For now, I can tell you cruising on the highway it's a steady 190 for water and 192 for the oil. I work from home so I don't spend a lot of time in stop and go traffic, but I can share data from Daytona after next week provided Mike gives me an OK. |
#5047 | |
#5048 | |
Drives: brz 2017 hksv2
you are catless right? |
#5049 |
#5050 |
have you ever measured EGT during hard track days?
what do you get? |
#5051 | |
#5052 |
#5053 |
well i Hope so?
![]() i have problems keeping a friend's car under 970 celsius 0.7Bar boost, he has wrapped header and front pipe with 200 cells metal cat, no mattera what we do, even with 10.5afr and 102 Ron and intercooler waterspray, and ignition timings to the edge of the knock correction, EGT goes high Fortunately he is going to switch to catless soon, but i hoped you were going to check EGT in your race car, it must be high the EGT with cat, boost and such an AFR |
#5054 |
Drives: Series Blue WRB JRSC C38 HBP Flex
I've been kicking around the idea of going E85 with my C38 on stock pulley. Upgrading the injectors, pump, and a DT FF kit. My question is is anyone running E85 on stock pulley as a daily and how many miles so far? What reliability can I expect out of a stock motor with this setup? I know tuning is a big part as well and how much of a power increase does E85 give on stock pulley? I'll be switching between E85 and 93 quite often more than likely. Thank you guys.
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
