Old 07-24-2019, 07:13 PM   #5041
CSG Mike
CSG Mike's Avatar
Every car varies in what it likes; no two engines are alike, but super rich is what you do when you want to "play it safe" and not really spend the time to dial it in. JRSC boost levels are not unknown territory. If you're using a one time off-the-shelf tune, then sure, I get why its rich. If you're getting a custom tune, it doesn't need to be.
My personal boosted car (turbo) runs typically around .82 lambda under WOT. This is ~~12:1
tomm.brz (07-25-2019)
Old 07-24-2019, 07:21 PM   #5042
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I'm running a Harrop kit with e85 at an AFR that is in the high 11's at WOT. Tuned by Zach when he was at DT, who is now at CSG.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
jflogerzi (07-24-2019)
Old 07-24-2019, 08:35 PM   #5043
jflogerzi
jflogerzi's Avatar
Interesting I was not aware that's where he went...
2013 Series 10 FRS #553
Old 07-24-2019, 08:47 PM   #5044
Irace86.2.0
http://www.ft86club.com/forums/showthread.php?p=3240307
sroby (07-24-2019)
Old 07-25-2019, 12:40 AM   #5045
steved
Drives: 2013 FRS
Anyone running the Verus brake duct kit with the JRSC kit? With the smaller wiper reservoir and the IC tubing I'm trying to remember how much space was left in there for brake duct tubing.
steved is offline   Reply With Quote
Old 07-25-2019, 01:41 PM   #5046
peaches
Drives: '14 BRZ Limited
I was mistaken. When I said 11.2 AFR @ full boost that was me glancing at my gauge while driving, just took a log on the highway and it reads 12.17 AFR @ full boost. Waiting for Mike to tell me where I can send it, anybody else wants to take a look let me know.
Also, @kowalski wanted to know temps from the JRSC dual cooler. For now, I can tell you cruising on the highway it's a steady 190 for water and 192 for the oil. I work from home so I don't spend a lot of time in stop and go traffic, but I can share data from Daytona after next week provided Mike gives me an OK.
peaches is offline   Reply With Quote
The Following User Says Thank You to peaches For This Useful Post:
kowalski (07-25-2019)
Old 07-25-2019, 03:45 PM   #5047
CSG Mike
CSG Mike's Avatar
you can upload it to a datalog website of your choice, or email to me, or upload to google drive and give me a link. Whatever suits your fancy.
Old 07-25-2019, 03:49 PM   #5048
tomm.brz
Drives: brz 2017 hksv2
you are catless right?
Old 07-25-2019, 04:07 PM   #5049
CSG Mike
CSG Mike's Avatar
No, I am catted.
Old 07-25-2019, 04:46 PM   #5050
tomm.brz
have you ever measured EGT during hard track days?
what do you get?
Old 07-25-2019, 05:42 PM   #5051
Irace86.2.0
Datazap
Old 07-25-2019, 06:33 PM   #5052
CSG Mike
CSG Mike's Avatar
what do you get?
I no longer have an EGT sensor, as the one I used to use was a borrowed setup.
That said, my ceramic hasn't failed, so i know my sustained temps have to be under 2300F.
sroby (07-27-2019)
Old 07-25-2019, 07:01 PM   #5053
tomm.brz
well i Hope so?
i have problems keeping a friend's car under 970 celsius
0.7Bar boost, he has wrapped header and front pipe with 200 cells metal cat, no mattera what we do, even with 10.5afr and 102 Ron and intercooler waterspray, and ignition timings to the edge of the knock correction, EGT goes high
Fortunately he is going to switch to catless soon, but i hoped you were going to check EGT in your race car, it must be high the EGT with cat, boost and such an AFR
Old 07-30-2019, 04:18 AM   #5054
Brz866
Brz866's Avatar
Drives: Series Blue WRB JRSC C38 HBP Flex
I've been kicking around the idea of going E85 with my C38 on stock pulley. Upgrading the injectors, pump, and a DT FF kit. My question is is anyone running E85 on stock pulley as a daily and how many miles so far? What reliability can I expect out of a stock motor with this setup? I know tuning is a big part as well and how much of a power increase does E85 give on stock pulley? I'll be switching between E85 and 93 quite often more than likely. Thank you guys.
Brz866 is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
