Old 12-13-2013, 10:09 AM   #15
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
I feel the exact same way about my pro-kits, with exception of the additional 1/4-1/2" of lowering that you get with the Sportlines. Eibach has a great product here.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 12-13-2013, 01:03 PM   #16
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
So I do need lower control arms to dial out the static negative camber if going with the sportlines? These springs have the drop I want but I am less inclined to get them if I have to throw a bunch more money into the setup...
hmong337 is offline   Reply With Quote
Old 12-14-2013, 09:34 PM   #17
3_NA_HAF
Diesel Tech
3_NA_HAF's Avatar
Drives: 2013 FR-S Hot Lava 6MT
I think a full parts list to make a full stuck alignment would be nice. I don't really intend on tracking my car much, so I'd like to not compromise my stock handling.
3_NA_HAF is offline   Reply With Quote
Old 12-14-2013, 11:26 PM   #18
hmong337
Emperor JDM
hmong337's Avatar
Exactly what I'm going after! ~1.5 inch and a bit stiffer than stock is what I'm after. I want a set of 17x9 or 18x9 set of wheels too
Old 02-11-2016, 09:24 PM   #19
Frs_chil
Frs_chil's Avatar
Drives: 14' FR-S
Great info. You've helped me make the decision between the sport line and pro kit. I will be going sport line until I can fund a coilover suspension.
Instagram @chillychil87 @nes_lifestyle
Frs_chil is offline   Reply With Quote
Old 07-24-2019, 06:23 PM   #20
Kcc-Breeze
Drives: 2019 BRZ RS
would you still recommend the sportline over the prokit after all these years?
Kcc-Breeze is offline   Reply With Quote
Suspension Review: Eibach Pro-Kit Lowering Springs DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 136 10-09-2020 06:26 PM
Actual Spring difference BRZ vs FRS Motopythons Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 05-13-2015 10:12 PM
Lowest quality spring? Synack Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-26-2012 12:00 PM
Eibach Sportline Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 4 07-06-2012 11:04 AM
