Old 07-23-2019, 04:39 PM   #1
Kcc-Breeze
Drives: 2019 BRZ RS
Will the EIBACH SPORTLINE lowering spring be ok with my stock sachs?
Hello recently purchased a 2019 rs brz, love the car a lot, but want to do something with the ugly gap between the fender and wheels.
Thinking about the lowering spring since I don’t track nor do a lot of auto x either. So imma try to stay away from coilover plus winter here in Canada is salt heavy.
I want those sexy one finger gap between the wheel and fender so I figure 1.4” drop from the sportline would be a perfect choice, but idk how well they will pair with the stock sachs dampeners. Anyone have any experience with this set up? How do the shocks hold up in a long run?
P.s I don’t mind harsh or stiffer ride either.
Thanks !!!
Kcc-Breeze is offline   Reply With Quote
Old 07-23-2019, 04:54 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
If you are planning on keeping the OEM shocks; I would not recommend any springs that lower your car more than 1".
I LIKE TIRES!
Old 07-23-2019, 06:00 PM   #3
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
I agree, I have a 2018 Performance pack and it was already fairly stiff to begin with. I would say only a small drop would suit those struts; anything dramatic will start to get crashy.
If you really want one finger wheel gap, you'll have to be lowered a lot-- probably more than you'd think. I'm on HKS Hipermax coils now with 1 finger gap, and my car is scrape-on-driveway low. Any spring that drops you that much on the OEM Sachs is going to compromise ride quality significantly. As it is, my coils are supposed to be "daily driver friendly" and they're still very stiff at my height.
Pic for reference: https://ibb.co/Ns1N0R4
Shizuka is offline   Reply With Quote
Old 07-23-2019, 06:47 PM   #4
Kcc-Breeze
Drives: 2019 BRZ RS
Do you have the gt or sp version?
Old 07-23-2019, 06:52 PM   #5
Shizuka
Shizuka's Avatar
Hipermax IV GT
Old 07-23-2019, 06:54 PM   #6
Kcc-Breeze
Drives: 2019 BRZ RS
What about the red version spring? I heard they lowered 1” and is same as the eibach pro
Old 07-23-2019, 06:54 PM   #7
Kcc-Breeze
Drives: 2019 BRZ RS
Hipermax IV GT
The trd lowering spring which is 1” would be okay tho?
The Following User Says Thank You to Kcc-Breeze For This Useful Post:
Leonardo (07-23-2019)
Old 07-23-2019, 07:35 PM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes, I had the 1" Eibach Pro-Kit springs (IIRC, they are the same as the USA TRD springs) for 65,000 miles on OEM shocks. 1" drop springs work well paired with the OEM shocks.
I LIKE TIRES!
BirdTRD (07-23-2019)
Old 07-23-2019, 07:44 PM   #9
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Thanks !!!
I have RCE yellows with OEM shocks for about 50K miles, no issues. Just added Eibach front and rear sways , stiffened things up quite a bit, thinking about going back to OEM sways for daily driving.
BirdTRD is offline   Reply With Quote
Old 07-23-2019, 08:21 PM   #10
Kcc-Breeze
Drives: 2019 BRZ RS
You know many fingers can you fit between the gap? When u had the eibach pro? Cus someone locally is seling his TRD I might just buy his
Old 07-24-2019, 03:14 PM   #11
Kcc-Breeze
Drives: 2019 BRZ RS
Do you have the measure between the gap with the rce?
Old 07-24-2019, 07:19 PM   #12
BirdTRD
Simply Forgotus
BirdTRD's Avatar
It really depends on tire size/wear and how even the ground is you're parked on. The RCE's are about a .75" drop whereas the Eibachs are about a 1" drop. From the ground to the fender is about 25".
Old 07-25-2019, 12:59 AM   #13
jflogerzi
jflogerzi's Avatar
As others said 1" drop max. I have had both eibach pros and yellows. I like the rce yellows a bit more but eibach is almost as good with a bit more of a drop.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Leonardo (07-25-2019)
Old 07-30-2019, 03:01 PM   #14
x_hawker
Drives: 2013 FR-S 10-Series
Location: SJ/OC/IE California; Temporarily: Glendale,AZ
What if he paired his Eibach Sportlines with a set of Koni Dampers? I haven't seen any posts with that combination for some reason.
Not sure how the performance on that would be either. Any thoughts?
x_hawker is offline   Reply With Quote
Sachs PP Shock & Eibach Spring Combo - Roll Center Correction? x_hawker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-18-2019 02:41 AM
Eibach Sportline Lowering Spring front and rear camber bolts WallsAndFoundations Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-20-2014 10:09 AM
WTB: Eibach sportline lowering spring. bhbnuckle Brakes, Suspension, Chassis 1 03-11-2014 12:05 AM
FS Eibach Sportline lowering springs + Stock Strut $200! Randyliciious Brakes, Suspension, Chassis 8 02-06-2014 12:57 AM
Eibach Sportline Lowering Springs ebhopal Brakes, Suspension, Chassis 6 10-22-2013 05:00 PM
