Old 07-21-2019, 11:03 AM   #1
littlezav
Drives: b
Brakes making a jingling noise over bumps
Hey everyone,
Every time I drive over a bump, there is a jingle coming from by brakes. I know it's my brakes because if I tap the brake while going over bumps the noise goes away, but if the brakes aren't engaged, I get the noise again.
Any idea?
littlezav is offline   Reply With Quote
Old 07-21-2019, 12:04 PM   #2
ls1ac
ls1ac's Avatar
Take off the wheels and tap with a rubber mallet. Will probably find the pads are bouncing around. If it is something else be glad you looked.
The Following User Says Thank You to ls1ac For This Useful Post:
Tristor (07-22-2019)
Old 07-22-2019, 12:36 PM   #3
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
You left out way too much info for us to give you a good answer?
What model twin? What brakes? Fixed caliper? Floating caliper?
Fixed caliper brakes can suffer from pad knockback. This is pretty common, as subaru doesn't use anti-knockback springs in their fixed calipers.
The Brembo's Subaru offers probably suffer from this as well. I don't have them so someone correct me if i'm wrong, but I do not think they have springs in them either.
I have Subaru 4pot/2pot calipers and my right rear makes knocking/slapping sounds after a hard driving session. The noise goes away if I lightly tap/drag the brakes.
Switching from reverse to forward or vice versa also causes the pads to clunk. This is just the nature of certain caliper types. No way to stop it really unless you use springs to apply a constant pressure to your pads.
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Clunky noise when turning and driving over bumps WRITEX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-07-2019 08:56 AM
K Sports making noise? Brentkeys1814 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-22-2016 07:24 PM
Rear passenger noise over bumps enivid Issues | Warranty | Recalls / TSB 3 01-20-2015 10:55 PM
Clunking noise when on and off throttle and bumps DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 04-24-2014 12:18 AM
Strano Performance Parts making use of Suspension and Brakes Sam Strano Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-11-2012 08:52 PM
