| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2014 BRZ Limited A/T
Lightest 215/45/17 Summer Tires?
Hi Guys, I finally ordered a set of TWS T66Fs from Japan.
17x8 +42, 14lb wheels. Arriving in 2 weeks. To stick with the goal of lightest wheel/tire combo on stock setup, i want to stick with stock tire size, since all 215/45/17s tires still seem to allow 7-8 wheel widths, improve grip esp. during hard braking, be useable in rain, but still allow some play/slide at full lock + throttle. So far, looking around shows that the lightest tires would be in the Max Perf. Category, all at 19 lbs, 1. Michelin PS4 180+USD 2. Continental Extreme 150+USD 3. VENTUS V12 EVO2 105+USD 4. EAGLE F1 ASYMMETRIC 3 141+USD How are these 4 comparable? the Ventus with a low price looks really tempting too. Last edited by leevanf; 07-18-2019 at 08:09 AM. |
#2 |
Only happy when it rains.
Drives: series.blue
it depends. What are you using the car for? And you know every manufacturer lists tire weights on their website, so you can check them all.
#3 | |
For DD and spirited driving. I dont track and in rare cases i do, for fun and non-competitive. I used tirerack as a reference and found those two lightest. Not sure yet what/where i can filter tire shopping by weight Sent from my iPhone using Tapatalk |
#4 | |
Wayward Member
Drives: Hot Lava 86
If you spent your whole budget on the wheels (likely) then buy the Ventus, they should serve you well enough.
#5 | |
Thats a great point. Im considering lower priced wheels because i realized i may not benefit from the max grip and performance at limits of the ps4 since its just a city DD. Basically, do you think the price you are paying for expensive tires of the same category, are only seen when driving near the upper limit? If so, the ventus makes a great choice. But if even dd is marginally different with a ps4, i could consider it. What do you think? Sent from my iPhone using Tapatalk |
#6 | |
#7 | |
Wayward Member
Drives: Hot Lava 86
The PS4s will provide more grip than needed, but it's nice to have. The Ventus shouldn't be too much of a compromise though.
#8 |
Drives: 2014 GT86
Nevermore: he mentioned PS4 (more street oriented and more different sizing), not PS4S (which as you say are PSS successor). For non tracked car should do though.
#9 |
Drives: BRZ 2018
Talking about minimising unsprung and rotational mass, other than lightening the wheel and tyre, you may also want to get two-piece brake rotors. You can knock off another 6 lb per (front) wheel.
#10 |
Drives: Crapcan
I ran the Extreme Contact Sport. It rains a lot out here and it performed well, even in the winter. Got about 30K miles out of them. Once they got close to the wear bars the shoulders went away really quick which I found odd. They were reasonably quiet.
I will likely buy them again. |
#11 |
Country Boy 4 Life
As someone that went from a MPSS to the Hankook EVO V12; I would highly suggest not getting the Hankooks. Compared to the MPSS (which I loved till they got below 50%), Their side walls are too soft. I do not like them. In no way do they out perform the MPSS. (except cost) I will be getting the MPS4S next.
I LIKE TIRES! |
#12 | ||
Wayward Member
Drives: Hot Lava 86
| The Following User Says Thank You to Nevermore For This Useful Post: | Leonardo (07-18-2019) |
#13 | |
Country Boy 4 Life
I seriously doubt that the lightest summer 215/45/17 is also the best summer 215/45/17 tire. IMO, It makes more sense to ask what's the best tire for street driving (or be specific Like: mixed use Street/track) with a UTQG from 200 - 320. (or something like that).
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | Nevermore (07-18-2019) |
#14 |
Wayward Member
Drives: Hot Lava 86
No, no doubt. But, the original question was just what is the lightest he can get. He's already said he doesn't need the best tire because he might not push the car hard enough to warrant it. My original recommendation was that he get both, or the best lightest, but price seems to be a factor as well so it's a pick two situation.
| Toyo Tires Proxes Sport - New max summer performance tires | DarkSideFRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 09-18-2018 05:06 PM |
| Summer Tires | Flame9020 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 44 | 03-12-2017 05:29 PM |
| Good looking Summer tires? | g0ast | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 39 | 12-07-2014 10:21 PM |
| FS: OEM Tires used for 1 summer. | zex | Canada Classifieds | 7 | 11-22-2014 07:05 AM |
| Yep, these are summer-only tires. | FRiSson | New England | 5 | 11-09-2012 09:12 AM |
