Old 07-13-2019, 02:58 PM   #1
Hudson456
Rear subframe 19mm bolts reusable?
I removed the 2 rear 19mm bolts on the subframe to install a cusco brace, and according to this diagram the bolt are supposed to be replaced - are these torque to yield bolts that should not be reused? I've never seen anyone on the forum mention this.
Also, should these bolts have loctite on them? Mine had red substance on them - I'm not sure what this is. Are these bolts supposed to be lubricated when reaching the 107 ft/lb torque spec?
Thanks
Hudson456 is offline   Reply With Quote
Old 07-13-2019, 03:28 PM   #2
maslin
Benz Tech
Drives: 2017 BRZ Premium
If the torque spec is just 107ft/lb they are not torque to yield.
The one time use is due to that red substance. The applied “loctite” is one time use.
Same with any pinch or locking nut and any bolt that is torque to yield.
Very few bolts are lubricated prior to installation, I believe I’ve only seen that on head bolts.
maslin is offline   Reply With Quote
The Following 2 Users Say Thank You to maslin For This Useful Post:
NoHaveMSG (06-10-2022), strat61caster (07-14-2019)
Old 07-13-2019, 04:34 PM   #3
Would you use red, or blue if it was yours? In some cases I feel like red is overkill.
Old 07-13-2019, 05:59 PM   #4
maslin
Benz Tech
It’s not Loctite specifically. It’s a coating they apply to hardware that keeps the bolts in. Colors don’t match the known purple, blue, red, green scheme.
I would never apply loctite in a tube to any of those bolts. I would either run them back in and assume you’re never going to have a problem, or replace the hardware as specified.
Old 07-13-2019, 07:38 PM   #5
new2subaru
Weight Weenie
Drives: 15 FR-S
I’ll bite, why not?
Old 07-13-2019, 08:28 PM   #6
Ooo, good point.
I mostly switch between the blue, green, and white. I'd probably just clean and reuse the screws for those subframe mounts.
Old 07-13-2019, 08:35 PM   #7
maslin
Benz Tech
Originally Posted by new2subaru View Post
I’ll bite, why not?
Because I have no desire to glue bolts into a car. The stuff that comes on new bolts is dry, it tightens up the tolerance between the fasteners, keeping everything tight along with the tension on the bolt.
I’m not a big fan of liquid loctite. It certainly has its place, but I wouldn’t try to outsmart the engineers that designed the car. If they wanted them loctited in they would specify loctite. Instead they specified a bolt with a coating. I’d either replace the bolts or reinstall and forget about it.
I’ve replaced thousands of one time use fasteners, I doubt I’ve used one of the little tubes of loctite in 10 years.
Old 07-13-2019, 09:05 PM   #8
The main reason factory screws come pre-coated is for quality control in the assembly process. IRL, a properly-chosen, carefully-applied liquid adhesive is just fine. That being said, I have a couple tubes that are probably 20 years old. Should probably just toss them.
maslin (07-13-2019), new2subaru (07-14-2019), NoHaveMSG (06-10-2022)
Old 07-14-2019, 12:07 AM   #9
new2subaru
Weight Weenie
Drives: 15 FR-S
I agree, nothing wrong with a liquid adhesive used sparingly.
The Following User Says Thank You to new2subaru For This Useful Post:
Ultramaroon (07-14-2019)
Old 07-14-2019, 01:13 AM   #10
Tristor
Tristor's Avatar
As @maslin pointed out these are not torque to yield, they are marked one-time use due to the pre-applied coating. I re-used mine, just cleaned them up on a wire wheel and applied liquid blue loctite prior to torquing to spec. I no longer have the link handy but had read a spec sheet showing the pre-applied coating is most similar in specifications to blue loctite, despite being red in color. Do NOT use red loctite on your subframe bolts.
If you are installing something like the whiteline KDT922, if you can get them you want the subframe bolts from the TS. They are identical except having a slightly longer overall length to ensure full thread engagement between the subframe and body when running bushing inserts. The TS comes with the STI bushing inserts (which look identical to the whiteline KDT922) pre-installed, so has a lengthened bolt. I tried to acquire them and found it impossible because the parts counter people at the dealership are borderline retarded and refuse to order on part numbers and I didn't have a valid TS VIN number to give them. The TS bolts aren't essential, thousands of people have installed subframe bushing inserts and reused their factory bolts, but since you seem concerned, this would be a route to replace the bolts with OEM spec bolts that have pre-applied coating and also get the longer length killing two birds with one stone.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
maslin (07-15-2019)
Old 07-14-2019, 01:49 AM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
Parts counters are almost as bad as the DMV
Tristor (07-14-2019)
Old 07-14-2019, 04:22 AM   #12
ZionsWrath
Thanks
ZionsWrath's Avatar
Their prices are much worse.
The Following User Says Thank You to ZionsWrath For This Useful Post:
soundman98 (07-15-2019)
Old 07-14-2019, 11:34 AM   #13
Tristor
Tristor's Avatar
Also, I realize you didn't ask, and the instructions don't say, but just to clear it up you should definitely get an alignment after installing the bushing inserts. The inserts will forcibly realign your subframe to be centered on the body, which may not be where it was positioned from the factory and this will affect both camber and toe in the rear.
The Following 4 Users Say Thank You to Tristor For This Useful Post:
maslin (07-15-2019), new2subaru (07-14-2019), soundman98 (07-15-2019), Ultramaroon (07-14-2019)
FS: Perrin 19mm Adjustable Rear Sway Bar yip Brakes, Suspension, Chassis 7 03-13-2017 02:43 AM
torque specs for front and rear subframe bolts mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 06-17-2015 03:54 PM
REVIEW | DC Sports rear subframe brace / rear subframe lateral brace mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-10-2014 09:59 PM
Rear swaybar mount reinforcement. How important is it for 19mm bar? mike the snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-04-2013 07:50 PM
