Old 07-13-2019, 04:45 AM   #1
gpvecchi
gpvecchi's Avatar
Vland headlights question
I have a 2019 full led model, seller says that Vland headlights are full led, can you please confirm it? Thanks!
Old 07-13-2019, 05:13 AM   #2
Brz-123
I use their OEM 2017 lookalike with pulsing turn indicators. It is LED
My bad, I spoke about taillights. Just realised based on the below post
Sent from my SM-G970F using Tapatalk
Brz-123 is offline   Reply With Quote
Old 07-13-2019, 05:33 AM   #3
kev0
Drives: '14
Be aware that the VLand light output is absolutely horrible and they only allow H7 bulbs. Any changing of the bulb will require a custom retrofit. It looks cool though, so more power to you if you don't care about the light output!
kev0 is offline   Reply With Quote
Old 07-13-2019, 10:27 AM   #4
gpvecchi
gpvecchi's Avatar
Many thanks, that's was my doubt. I had experience with chinese/taiwanese headlights and they usaually are awful...
Old 07-13-2019, 11:34 AM   #5
davidmcl
Drives: 2013 BRZ supercharged
Not sure that this is correct.... The ones I have are decent light output and are compatible with D2S base HID lamps.
davidmcl is offline   Reply With Quote
Old 07-13-2019, 12:06 PM   #6
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I can confirm this through a friend who is also running a set of Vlands.
You should be running them with a D2S bulb. His feedback is positive on light output. Some adjustment may be in order.
Overall quality is on par with the cost. They're inexpensive headlights.
He mentioned having issues with the turn indicator flickering on and off at times. Possibly a ground issue, or some internal wiring short.
Old 08-16-2019, 02:08 AM   #7
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I'll be getting these headlights in soon. I just wanted to confirm that the OEM D4S (Xenon) BRZ bulbs will not fit, and I will need to buy H7 (halogen) or D2S (Xenon) bulbs, but D2S are obviously better, right? Do they plug into the stock harness, or do I need an adapter? I'm naive about bulbs. How are these bulbs compatible, or can any bulb be used? Do they have the same mounting shape only or what? There seem to be a lot of different D2S bulbs from $40-200; what's the difference?
Old 08-16-2019, 02:09 AM   #8
Irace86.2.0
Also, I'll be running the OLM vertical DRLs. What brightness should I buy to match the color? 5k, 6k?
Old 08-16-2019, 09:10 AM   #9
RToyo86
RToyo86's Avatar
You have factory HID's?
The factory D4s uses a different housing yes. D4S harness is different from a D2S system, so a D2S bulb won't work on a D4S harness. They are not electrically compatible.
More info if you're curious
https://kensun.com/blogs/news/factory-hid-bulb-types
My friend is telling me the D2S housing fit just fine in Vland's headlight. h7 housing looks to be different from a D2S housing. It's possible he bought aftermarket D2 bulbs which had adapters for a H7 housing or Vland built in notches for both. I cannot confirm that. He doesn't know much about bulbs to give me info I can source.
https://www.theretrofitsource.com/bl...01/bulbs-3.png
Old 08-16-2019, 01:00 PM   #10
Irace86.2.0
The OEM BRZ headlights are HID.
I believe the kit comes with harness adapters for FRS, BRZ, old and new, but I didn’t know if I need to buy new bulbs or if the stock bulbs work. From what others say, the housing on the VLand headlights fits H7 which is halogen or D2S bulbs which is Xenon/HID—not the OEM bulbs. Well, maybe OEM for the FRS.
I just want to confirm before I try to install these.
Old 08-19-2019, 09:16 PM   #11
Irace86.2.0
I’m going to try to make the OEM D4S bulbs work by modifying the tabs like this link mentions.
All of these bulbs have the quartz envelope and arc positioned in the same place – so any D-series projector can use any D-series bulb by bending/cutting out the indexing tabs. For example, if you buy a AL Gen2 projector from an Audi but want to use aftermarket D2S bulbs + ballasts, just bend down the key tab! Please don’t use D*S bulbs in reflector headlights as it will effectively be a high beam and blind oncoming traffic
https://www.google.com/amp/s/www.skb...s-d4r-etc/amp/
Old 08-20-2019, 10:08 AM   #12
davidmcl
I think you'll be ok. The green retaining ring on the Vland lights has various little tabs so I think will probably work with both D4S and D2S.
Old 09-04-2019, 07:57 PM   #13
AD83
AD83's Avatar
Drives: 2017 Subaru BRZ, 2002 Ford Cougar
I know it's only been 2 weeks but just curious as to whether you got the d4s bulb and ballast to fit?
AD83 is offline   Reply With Quote
Old 09-05-2019, 11:12 AM   #14
Irace86.2.0
I will be picking up the bumper this Friday and starting to assemble the bumper/headlights this Saturday. I'll make an update by Monday if you check my build. I'll try to remember to comment here too.
FRS Led Conversion (Vland Headlights) Help Michael41197 Electronics | Audio | NAV | Infotainment 2 07-05-2019 07:44 PM
FS BNIB Vland headlights statik Exterior Parts (Aero, Lighting, Etc.) 2 07-04-2019 01:56 PM
Vland Headlight question Sikku Cosmetic Modification (Interior/Exterior/Lighting) 2 04-12-2019 09:50 AM
Vland Headlight question Sikku Cosmetic Modification (Interior/Exterior/Lighting) 5 04-03-2019 02:46 PM
Question about OEM headlights SyntrexFRS Cosmetic Modification (Interior/Exterior/Lighting) 3 06-06-2016 03:33 AM
