Old 01-17-2019, 02:01 PM   #141
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Whelp, I wiped my computer and forgot to backup the V2.076 ROMs.
Does anyone have them on their cloud drive? They're nowhere to find on OFT's website.
Old 01-17-2019, 02:24 PM   #142
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
You’re in luck.
https://www.dropbox.com/s/vjc21bddg2...2.076.zip?dl=0
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 01-17-2019, 03:43 PM   #143
Yoshoobaroo
TRACKBREAD
Originally Posted by sav View Post
Woopwoop! Thanks!
Old 01-18-2019, 12:19 AM   #144
sav
sav's Avatar
Woopwoop! Thanks!
Only a pleasure, glad I could help.
95RON SAV Tuned
Old 07-03-2019, 09:20 AM   #145
BEZO760
Drives: Blue 2016 SCION FR-S
Hey all, I'm running the OFT v1 Stage 2+ e85 tune on my 2016 FRS (auto.. It is what it is) anywho.. I love it so far and have no problems, but I do miss (neighbors don't) my obnoxiously loud cold start. I have a JDL UEL header and a full exhaust replacement using Invidia/Tomei/JDL aftermarket parts, so that cold start you can imagine was up there in the decibels.
I got to talking to a buddy of mine and he said that it is possible to play with the tune to get the cold start back. I don't know how and don't know if it's possible, I don't see why it wouldn't be possible though.
If any of you experienced folk have some knowledge with regards to this that would be awesome!
I did read/scan this whole thread and couldn't find anything but it was 4:30am when I started reading so I could have easily missed what I was looking for. Thanks in advanced!
BEZO760 is offline   Reply With Quote
Old 07-03-2019, 09:33 AM   #146
sav
sav's Avatar
I can't remember all the tables, but start with the idle speed target table(s) - you'll notice they're temp related. Compare them to the stock ROM and you'll see what's been changed.
95RON SAV Tuned
Old 07-03-2019, 12:30 PM   #147
tomm.brz
Drives: brz 2017 hksv2
search table Ignition timing after start
put it very negative, at least -9 or if you want growlier tone put like -15 o -19
that table is the most effective that make louder cold start
Old 05-10-2022, 01:53 PM   #148
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
OFT Tune Tweeks and Information
Correcting In dash fuel economy readout when on E85
On OFT tunes the in dash fuel economy display will read 25-30% off on E85,to correct this adjust the Fuel_Multiplier_Display_Offset Table as per below (original values with 30% added) you may need to adjust this percentage slightly if you find the readout is still differs from actual
Note in your Definition the "Fuel Multiplier Display Offset" Table may be under the "BRZ ALPHA" folder
Hello @steve99
Is this still needing to be changed even on the v4.03 tune?
Seeing about 30-40% higher MPG on the dash than manually .alculating.
Example, calculated 313.8 miles / 12.27 gal = 25.57 mpg. Dash shows 36.1. So that's about 41% higher.
I know the calculated isn't exactly 100% either but would like to get the dash to show at least close to what I calculated.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 05-10-2022, 05:29 PM   #149
73TORANA!
Drives: Orange GTS
Cant remember the exact file but I recall that it retarded the timing during cold start to warm up the cat. from memory it retarded the timing by up to -10deg It was a single line of cells in the table that was change from -10 on STD rom to something like +4 deg in STG2 then copy and paste the all the cells to your E85 tune. Just make sure scale across the top and down the left side is the same on both roms. You can find it in Rom Raider by comparing the STG2 and Standard rom. I would look for you but im not near my computer. NOTE.... the file is not the ignition transient retard file, that file is to stop detonation during hi rpm gear changes.
Sorry cant be of more help until next week when I can look it up for you if you want to send me a P.M then. Do you have Rom Raider? .
Cheers Geoff.
73TORANA! is offline   Reply With Quote
Old 05-13-2022, 01:21 AM   #150
steve99
Drives: FT86
Originally Posted by NARFALICIOUS View Post
Hello @steve99
yes still meeds doing in e85 oft tunes
Old 01-25-2023, 11:04 AM   #151
silly86
Drives: 2017 Toyota 86
Hello, @steve99
I am following the tips for the rev limiter. however while in rom raider I have 2 limiters. rev limit A (fuel cut) and rev limit B. do I ignore the limit B settings? Could I disable it by inputting the value 'zero'?
I have tried following your settings for rev limit A and base timing b -14.88, I have found that while I am sliding in 1st gear or 2nd gear it just holds the rpm. My goal is to get it to bounce off the limiter without activating the failsafe limiter and killing power. Would setting base timing B to -0.12 be more of the characteristic I am seeking? I am trying to achieve this on my manual 2017 toyota 86.
silly86 is offline   Reply With Quote
Old 01-25-2023, 12:10 PM   #152
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by silly86 View Post
Hello, @steve99
steve99 was unfortunately banned. You can find him on the OFT FB group if you use FB. There are others here that can probably answer your question. I haven't touched any of that stuff since I had my car tuned but there are others who are very knowledgeable who may chime in and answer for you.
Old 01-25-2023, 12:40 PM   #153
tomm.brz
set rev limit A and B The same
try with bigger hysteresis like 7500/7400 , so 100rpm of difference
Old 01-26-2023, 07:04 AM   #154
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
If you want a smooth rev limiter then you need to have the ignition retard limiter limit the refs rarther than the fuel cut limiter that is rev limiter A and B.
So have the ignition retard limiter start 100-200 rpm before the fuel cut limiter and make the ignition retard ramp very sharp maybe try -30 instead of -15
Also as Tom says make the rev limit A and B hysteria ie the different between on and off values in A and B limiter small like 100 or even 50 rpm
AussieBRZ is offline   Reply With Quote
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
difference between vortech tune and perrin tune? Frs32907 Forced Induction 7 12-05-2013 02:49 PM
Information I did not want to know. K2 Great Lakes 19 07-23-2012 08:18 AM
