Old 07-02-2019, 12:36 AM   #99
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I'm not certain what he means but I'm not surprised. I wasn't happy with my CX parts either... Headers looked really cool though
well usually the headers are constructed on a jig with the initial tubes coming out being fairly straight for a few inches, and the holes are placed away from the welds. And the turbo is mounted in the pictures above, so I don't get the problem.
Old 07-02-2019, 06:37 AM   #100
Ashikabi
Ashikabi's Avatar
Maybe the runner curves too close to the head so you can't get a nut on the mounting studs
Old 07-02-2019, 07:42 AM   #101
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Some of the runners do not come straight off the flange, I can take pics today if I remember. They are also too close to the holes. Every nut I try eventually starts to scrape at the few problem runners before it's all the way tight, and then once it does that it starts to go on crooked.
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline   Reply With Quote
The Following User Says Thank You to Clash0901 For This Useful Post:
Irace86.2.0 (07-02-2019)
Old 07-02-2019, 09:26 AM   #102
Ashikabi
Ashikabi's Avatar
Maybe I'm misunderstanding but what if you cut all the runners off right at the flange then had a 1/2" spacer welded on each runner to push it out a little? Maybe too much work
Old 07-02-2019, 10:41 AM   #103
ft86xtc
Drives: 2013 FRS
I used shorter exhaust studs, no problems getting the nuts on. Also used factory nuts not the ones that came with the manifold.
ft86xtc is offline   Reply With Quote
Old 07-02-2019, 10:43 AM   #104
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Too much work and will push the turbo out 1/2" which isn't what I need.
Shorter studs won't even begin to help since the stud are not in the way of anything... And the factory nuts most definitely are too big lol. But i'm glad they worked for you! Mines ef'd for sure. Even the small/low profile nuts dont work too well. I will figure something out.
Old 07-02-2019, 03:24 PM   #105
Irace86.2.0
What about putting on a sleeve or several small washers?
Old 07-10-2019, 11:40 PM   #106
Stevemode
Stevemode's Avatar
Drives: "Baby Gurl" of FBM
Just doing research and came across your heater hose re-route. With mine all torn down I think this is the way to go. Thanks for sharing and the great pictures.
Stevemode is offline   Reply With Quote
The Following User Says Thank You to Stevemode For This Useful Post:
Clash0901 (07-11-2019)
Old 08-05-2019, 10:04 AM   #107
frsty_86
frsty_86's Avatar
Drives: 13 FR-S, 90 Honda ED6, 07 TBSS
What's the latest news?
frsty_86 is offline   Reply With Quote
Old 08-05-2019, 02:10 PM   #108
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Incredibly busy with life lately and my 2013 built sti! Also planning a wedding for this upcoming October. I'm really close with this car, literally another weeks worth of work and it should fire up but no time right now
Old 08-27-2019, 07:58 AM   #109
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
So apparently everybody BUT me knew this; but the oem (20+ years old) crank pulley/harmonic balancer likes to separate after a while. I was highly advised by multiple people to get a new one. I ordered the fluidampr and started taking things back off the car to get the old one removed and new one installed.
Before that, I was working on heat wrapping my dump tube and downpipe.
Old 09-03-2019, 07:33 AM   #110
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I've got the new Fluidampr harmonic balancer on the car. Finished with the wiring for now, got good fuel pressure, tried cranking the car over and it will not fire . I am trying to upload a revision to the tune but can't connect my laptop to the m130 ecu.
Going to try again today with some pointers from people online.
Also, my oem water pump (re-used it) is leaking from the weep hole. That was a cool $200 I saved, now I have to reclaim my coolant and take off a bunch of stuff to replace it.
I could officially go cash out a new MK5 Supra or older MK4 Supra with a turbo and v160 in it with the money I have wrapped up into this car.
Rampage (09-04-2019)
Old 09-03-2019, 07:47 AM   #111
Ashikabi
Ashikabi's Avatar
I could officially go cash out a new MK5 Supra or older MK4 Supra with a turbo and v160 in it with the money I have wrapped up into this stupid car. I hope if my build thread proved anything to anybody it's, do not do this. Find another platform or buy one already swapped.
Sorry to hear you're having problems. Not all of mine are quite solved yet either. Keep at it, you'll get there. I spent a small fortune too. I shouldn't have, and I probably wouldn't again. But I don't regret it.
The Following User Says Thank You to Ashikabi For This Useful Post:
Clash0901 (09-03-2019)
Old 09-03-2019, 11:18 AM   #112
Ashikabi
Ashikabi's Avatar
Truthfully, once it's running and tuned i'm going to probably list it for sale and try to lose, hopefully less than $15k lol. After 2 years of building this car my interests changed. Maybe my feelings will change after I actually drive the car...
Jesus, 2 years is too long for a project to last. I guess I'd be tempted to give up if I wasn't so attached emotionally to my car.
But it was never speed or power I wanted to begin with so I guess it doesn't matter. Yes I LS swapped, but I guess it was just in search of something"better". It's an addiction to grow and improve this car. Power is just one aspect that can be made "better". If it wasn't this, it would be something else
Built Turbo K24 Swap? Calmwhiteguy Engine Swaps 31 02-13-2018 05:07 PM
Custom Grill Duct Backyard Build, Opinions? Doobster Cosmetic Modification (Interior/Exterior/Lighting) 22 08-04-2017 04:20 AM
Giving flat black wheels a dash of bronze? Expert backyard painters want to weigh in? Keenercarguy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 06-02-2017 09:15 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
Rwd-boxer's backyard exhaust fix RWD-boxer Engine, Exhaust, Transmission 9 06-11-2012 06:15 PM
