Old 07-01-2019, 12:04 AM   #57723
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I've been frustrated with the floppiness of the drive line since day one. It's not just a little bit bad. For an alleged "sports car," it's atrocious. I've spent time studying it just by backing the car onto ramps, rocking it back and forth in gear, and watching deflection from underneath. The two main contributors are the engine mounts and the front diff mounts. There are a few different choices for engine mounts providing varying degrees of stiffness. The STI mounts are reputed to live in the sweet spot.
As for the diff mounts? Ugh. I dropped the hammer on a Cusco product but still feel like I could've done just as well by making shims from an old tire.
I have all my mounts except for the rear diff mounts swapped and it makes a huge difference. Really tightens up the feel of the car.
I have a set of rear diff cradle mounts but I don't feel like pulling the rear of the car apart again this year. Might leave the stock ones and build something like this instead.
https://www.maperformance.com/produc...QaAhmGEALw_wcB
NoHaveMSG is offline
Old 07-01-2019, 12:05 AM   #57724
We have our old stuff coming, but it will be pretty empty for a while. it is a lot bigger house. We are just buying what we need this year. Just bought a washer and dryer today, and looked at riding mowers.
RIDING MOWER!
I'm not seeing that much grass there - besides, now that you're retired, you have all day, every day, to mow the lawn. In addition, you will need the exercise. You just can't sit on the back patio and sip ice tea all day long, every day.
(see, I just saved you a few hundred dollars - )
humfrz is offline
spike021 (07-01-2019)
Old 07-01-2019, 12:23 AM   #57725
soundman98
ProCrastinationConsultant
soundman98's Avatar
My coworker was telling me how a neighbor somehow convinced his parents to have him mow that neighbors 3 acre property with a push mower for $2/hr.
If you can work out the same scam, it'll allow you to sip iced tea on the back porch and give some entertainment to watch with all your new free time!
soundman98 is offline
Old 07-01-2019, 01:34 AM   #57726
Hey, that was good money, back-in-the-day. I remember having to do that, back on the farm, for room & board -
Yep, raise the handle, get a run on it, lower the handle and push as hard as you could - cut 2' of grass - repeat.
No, it was not uphill.
humfrz is offline
Old 07-01-2019, 01:47 AM   #57727
Yeah. I'm easing my way up to some form of that brace. This is what happens when you convert a front-biased AWD platform into a RWD one either without really thinking it through, or more likely, choosing to overlook the issue. The problem is that with such a short arm for the moment couple, the mounts have to be super stiff. We wouldn't need any of this crap if the diff had been packaged for a dedicated RWD platform.
Ultramaroon is offline
Old 07-01-2019, 02:01 AM   #57728
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Hello from Caldwell.
All the windows are penises, but the rightmost penis has large balls.
EAGLE5 is offline
The Following 4 Users Say Thank You to EAGLE5 For This Useful Post:
JD001 (07-01-2019), soundman98 (07-02-2019), Spuds (07-01-2019)
Old 07-01-2019, 02:16 AM   #57729
JD001
JD001's Avatar
Drives: Subaru BRZ
Is @Tcoat still mowing his neighbour's lawn??
JD001 is offline
Old 07-01-2019, 02:34 AM   #57730
You're one sick puppy, @jsimon7777 and you, @JD001 are just as sick for "thanking" his post -
humfrz - out.
ZZZZZZZZZZZZZZ
humfrz is offline
JD001 (07-01-2019)
Old 07-01-2019, 02:56 AM   #57731
JD001
JD001's Avatar
Drives: Subaru BRZ
humfrz - out.
ZZZZZZZZZZZZZZ
@jsimon7777 just "beat me" to it... I was going to post the following but stopped myself..
JD001 is offline
Old 07-01-2019, 07:48 AM   #57732
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
You Californians are disgusting.
Sapphireho is offline
EAGLE5 (07-01-2019), Spuds (07-01-2019)
Old 07-01-2019, 07:51 AM   #57733
JD001
JD001's Avatar
Drives: Subaru BRZ
I'm afraid can't be "unseen"... corrupted for ever and ever...
JD001 is offline
Old 07-01-2019, 08:14 AM   #57734
Sapphireho
Famous Potatoes
Sapphireho's Avatar
What are you, Benny Hill's brother?
JD001 (07-01-2019)
Old 07-01-2019, 08:20 AM   #57735
Sapphireho
Famous Potatoes
Sapphireho's Avatar
RIDING MOWER!
That's only half the lawn.
John Deere makes one where the oil filter is the sump. To change oil you just unscrew the filter, and screw a new one on. They come pre-filled. Pretty slick.
Old 07-01-2019, 09:31 AM   #57736
qcbaker
Shitpost Generator v8.6
qcbaker's Avatar
Originally Posted by qcbaker View Post
My current plan of action after writing all this (I think...) is to charge up the battery and see if I can get it started/running.
Update: Got the oil/filter changed, charged the battery, and after many failed attempts, got the bike to start and run. Not too bad for having sat for a year lol. Took a few pics and posted it on craigslist. We'll see if it gets any attention at its current price and if not, I'll repost it for a bit cheaper.
qcbaker is offline
