Old 06-30-2019, 06:57 PM   #3627
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Has anyone else had problems with the eccentric bolt on the stock rear toe arms slipping? My alignment guy told me mine keep slipping out of place on the driver side and it throws my alignment out of whack. Apparently my rear toe has been hosed for a while I've got some pretty noticeable inside wear on those tires now. I was looking at getting one of those eccentric bolt lockout kits. Would that be a good solution or would it be better to look at aftermarket toe arms?
smg1138 is offline   Reply With Quote
Old 06-30-2019, 07:10 PM   #3628
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Replace the bolts and torque to spec and don't over torque them. They're slipping because they're yielded.
You can't do a toe arm AND a camber arm, nor can you use toe arms with sphericals (hint: most of them have sphericals)
The Following User Says Thank You to DocWalt For This Useful Post:
smg1138 (06-30-2019)
Old 06-30-2019, 07:46 PM   #3629
smg1138
smg1138's Avatar
Is that because of Street Touring rules? I looked in the rules I have but couldn't find anything about toe arms. I already have the Whiteline rear control arms so I guess that rules out new toe arms. Also, what does yielded mean in this context? Haven't heard that term before.
Old 06-30-2019, 07:57 PM   #3630
CoolHandMoss
Drives: 2013 FRS
Right. ST rules don't allow you to change more than one suspension link per corner. Also, as has been said, just replace the eccentrics with new ones. I just had to do that and it helped. Careless alignment techs will turn them while they're too tight and cause a large tolerance between the inside and outside cam. That makes it easier to slip in addition to the yielded issue also referenced above.
CoolHandMoss is offline   Reply With Quote
The Following 2 Users Say Thank You to CoolHandMoss For This Useful Post:
DocWalt (07-01-2019), smg1138 (06-30-2019)
Old 06-30-2019, 08:32 PM   #3631
smg1138
smg1138's Avatar
@CoolHandMoss Ok I guess I'll pick up some new ones at the Subaru dealership. Anybody know the part numbers?
Old 06-30-2019, 09:19 PM   #3632
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
SU00302805
And
SU00302818
Clutch Dog is offline   Reply With Quote
The Following User Says Thank You to Clutch Dog For This Useful Post:
Old 07-01-2019, 08:46 AM   #3633
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yes, ST rules preclude replacing two arms.
Yielded means the material of the bolt has stretched beyond the point of peak strength and is now deforming. You know that feeling of tightening a bolt too tight and it stops getting tighter then snaps? The "stops getting tighter" phase is when the bolt is yielding.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
bmacfrs (07-01-2019), Racecomp Engineering (07-01-2019)
Old 07-01-2019, 09:29 PM   #3634
CoolHandMoss
Drives: 2013 FRS
Is the 949 steering spacer legal? My interpretation says it is not. But I want one. Would anyone here protest me?
To clarify, it looks like the rules allow substitutions of steering wheels that do not include airbags. I am concerned about using the spacer with the OEM wheel.
Old 07-01-2019, 10:55 PM   #3635
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I am 99.9% sure it's legal, it simply turns your wheel into an aftermarket steering wheel.
That said, moving an airbag closer to you doesn't sounds like much fun in the event of an accident.
Old 07-01-2019, 11:04 PM   #3636
Clutch Dog
It is not directly legal. I wrote the SCCA to amend a rule in street classing to allow for steering wheel modifications purely for ease and comfort. their response was
26737 Steering Wheel Spacers ( my request)
"The SAC believes that 3.1.B covers modifying the controls of the vehicle to accommodate physical handicaps. Otherwise modifying the controls of the vehicle is not in the spirit of the Street category."
Now section 3.1.B states "B.
Physically
disabled drivers may use alternate vehicle controls and preparation items appropriate for the nature of their disability. In the case of a driver using alternate controls, extra care should be taken to ensure that the driver does have adequate control of the vehicle and that the control mechanisms can stand up to competition use. A waiver from the SCCA® Solo® Department is required for the use of such equipment in National Solo® events. Requests will be handled on a case-by-case basis"
So in short the SEB was telling me, being tall is a handicap and we have to ask for waivers to allow for steering wheel spacers.
NOW
As i have been in the region down in San diego before with my own spacers and such. Since we are not ultra competative like at nationals, if the general populous of those you are racing against are fine with it, then its whatever. (back in CS the top 6 guys all said its whatever) and really unless you are placing pole position no one will complain.
I intend to run the spacer in STX and if someone complains Ill file for a waiver.
The thought behind this is most STX guys arent 100% by the rulebook anyways ( some guys are running non standard lips and accessories)
its no different than moving the steering wheel closer with the telescoping wheel? and what if you where fat? then the wheel is closer still.
Old 07-01-2019, 11:07 PM   #3637
CoolHandMoss
Drives: 2013 FRS
But the oem wheel with a spacer would not be considered a modified wheel?
Old 07-01-2019, 11:09 PM   #3638
CoolHandMoss
Drives: 2013 FRS
I tend to lean toward your interpretation but it seems like a grey area to me.
As far as safety, no air bag is going to hurt me worse than the crash. I can't speak for everyone though. From experience, your wrists are more at risk than your face.
Old 07-01-2019, 11:10 PM   #3639
Clutch Dog
it is modified, it is modified to a non standard steering bit. and In the case of this particular instance. The rules also state that if there is not specific allowance for it. it is not allowed.
So I have fought hard to categorize this and basically it was "Its considered alt controls, put in a waiver"
Section 13 Street Category ( the lowest classing)
"Except for modifications authorized below, Street Category cars must be run as specified by the manufacturer with only standard equipment as defined by these Rules. This requirement refers not just to individual parts, but to combinations thereof which would have been ordered together on a specific car. Any other modifications or equipment will place the car in Street Touring®, Street Prepared, Street Modified, Prepared, or Modified Categories as appropriate. Configurations involving damaged parts (e.g., blown fuses) are not typically"
Old 07-01-2019, 11:50 PM   #3640
e1_griego
e1_griego's Avatar
Drives: Many
Seems legal to me.
Aftermarket wheels are allowed as long as the whole replacement assembly weighs more than OEM. This is adding weight to OEM, which seems to be the only consideration of the rules.
This is the STX thread, not the autox generally thread. For street it doesn't seem legal.
e1_griego is online now   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
