Old 06-28-2019, 04:16 PM   #1
mitama
Can you recommend good shocks/struts?
Hi Guys!
I'm thinking to get either Eibach Pro kit or sportline to lower my car (probably Pro kit).
At the same time, I'm trying to replace shocks/struts too (since I have a bouncy ride after accident).
Can you please recommend good shocks/struts that will be a good match with Pro kit?
mitama is offline   Reply With Quote
Old 06-28-2019, 04:33 PM   #2
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Koni adjustable Yellows.
Clutch Dog is offline   Reply With Quote
Old 06-28-2019, 04:34 PM   #3
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
My vote, find a set of used BRZ Sachs struts. But something like Koni or Bilstein would suit a lowering spring better.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
The Following User Says Thank You to Westen86 For This Useful Post:
weederr33 (06-28-2019)
Old 06-28-2019, 04:57 PM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Find some Sachs from a performance package BRZ. I'm sure you can get them cheap from someone who already swapped to coilovers.
MS, CSCS, TSAC-F, CPT
Old 06-28-2019, 05:12 PM   #5
mitama
Are the Sachs same as the struts/shocks?
Is stock performance package BRZ sachs better than Koni Struts?
Old 06-28-2019, 05:16 PM   #6
mitama
Guys,
I have a newbie question.
I have 2018 BRZ performance package, and it seems like PP Sachs are same as the shocks/struts (functions same?). And, I can replace Sachs/shocks/struts to Coilovers??
So should I just get coilovers instead of purchasing springs (to lower car) + shocks/struts because it will cost about the same??
Eibach springs + shocks/struts will cost around $600, and coilover is around $700-800
Old 06-28-2019, 05:30 PM   #7
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
Don't mess around, get you some tein flex z. Good quality, affordable price. I've had mine for about 50k miles, no issues. Plus you can adjust the height to your liking whenever you want!
Sent from my SM-G892A using Tapatalk
FRS13_ is offline   Reply With Quote
Old 06-28-2019, 06:04 PM   #8
Westen86
Purist
Westen86's Avatar
https://www.ft86club.com/forums/showthread.php?t=135331
Old 06-28-2019, 06:07 PM   #9
Westen86
Purist
Westen86's Avatar
Sachs struts are a factory upgrade to the normal BRZ, they will fit factory springs. Think TRD parts. They are not better than a Koni. You posted you have a PP BRZ with Sachs? Then just get springs or go Coilovers. Springs: $300? Coilovers: $900?
Old 06-28-2019, 06:10 PM   #10
mitama
SO...can you please confirm all I need to lower my car + fix my struts/shocks will be a coilover?
Old 06-28-2019, 06:12 PM   #11
mitama
I know Springs are much cheaper, but then I have to purchase and replace struts/shocks too. However, with the coilover, I can lower my car and I can solve the problem with damaged struts/shocks at the same time because coilover functions like struts/shocks?
Correct me if I'm wrong.
Old 06-28-2019, 06:15 PM   #12
mitama
I have a PP BRZ with Sachs, but I think my struts/shocks are damaged since my car is bouncy after accident. I'm not sure the PP BRZ Sachs functions as struts/shocks.
Should I get coilovers to lower my car and replace damaged struts/shocks?
Old 06-28-2019, 06:17 PM   #13
Westen86
Purist
Westen86's Avatar
I know Springs are much cheaper, but then I have to replace struts/shocks too. However, with the coilover, I can lower my car and I can solve the problem with damaged struts/shocks at the same time because coilover functions like struts/shocks?
Yes. Coilovers are a full package. Spring and Shock. Do some research and pick the best coilover for your situation. Or pickup the Eibach/Koni kit being sold right now I posted previously. I think $700?
Old 06-28-2019, 06:24 PM   #14
mitama
Eibach $250 + Koni kit $700 = $950 , and tein flex Z coilover around $800.
so I might choose coilover although I'm not sure I'm going to get the tein.
OEM springs/struts/shocks bfrank1972 Brakes, Suspension, Chassis 19 01-29-2019 10:03 PM
Bilstein B6 Shocks/Struts Set simpleisbest Brakes, Suspension, Chassis 6 06-08-2017 08:14 PM
FS: NJ Stock shocks/struts Joon525 Brakes, Suspension, Chassis 2 03-08-2017 12:08 PM
WTB - Front OEM Struts/Shocks for BRZ Jawnathin Want-To-Buy Requests 3 05-05-2015 08:36 PM
What shocks would you recommend? CaptainSlow Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-31-2013 01:18 PM
