Old 05-08-2019, 08:48 PM   #29
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by jdair28 View Post
got the wire harness in, and whattaya know..it works like a charm!! Wow, granted it is my butt dyno, but throttle response is great! The best part is the sound as you can just hear the increased airflow! Thanks everyone!
I know this is old. But is that the torque solution TB spacer with the grams? Thinking about getting grams or blox TB but using TB spacer for WMI got to confirm fitment.
Old 06-25-2019, 04:29 PM   #30
jdair28
Drives: 2013 Scion FR-S 10 Series
Yes it is! idk if they work better (or worse) together than individually as I got it tuned together but it's been running fine since!
jdair28 is offline   Reply With Quote
Old 06-25-2019, 05:10 PM   #31
wparsons
wparsons's Avatar
That's because you're getting in more air at lower throttle openings, not because it's actually flowing more at WOT.
I'd be interested in seeing raw MAF readings at WOT on a bigger TB vs the stock one on the same car and tune.
Anything I've read from reputable tuners says that on an N/A setup the stock TB isn't a bottleneck, so going bigger doesn't add hp.
flickr
Old 06-25-2019, 05:46 PM   #32
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I will be mating this up with the racer x intake manifold and greddy snorkel. All that air suction. Just need time peeps.
Dr. BRZ is offline   Reply With Quote
The Following User Says Thank You to Dr. BRZ For This Useful Post:
SuperTom (01-10-2020)
Old 06-25-2019, 07:16 PM   #33
StraightOuttaCanadaEh
Wes
that should sound nice
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Dr. BRZ (06-25-2019)
Old 06-25-2019, 09:16 PM   #34
FunnyGopher
Drives: 2015 BRZ Limited
I saw in that RacerX manifold thread that you were going to get one. Didn't realize you had the Grams TB as well. I too have a Grams, and was lurking on that manifold thread, waiting for someone to try it. I'd be interested in your results after you get everything together.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 06-26-2019, 11:31 AM   #35
Dr. BRZ
Dr. BRZ's Avatar
I do not have it, I only have the greddy snorkel but I will be buying it. Just hoping I get picked for the beta if not, I'm still gonna buy one. The plan is run the general tune and dyno, then contact steve or wayno for a custom tune. Trust me I am interested too and see what the numbers are.
MJones_RB (06-26-2019)
OEM throttle body nikitopo Engine, Exhaust, Bolt-Ons 10 01-07-2024 11:50 AM
OFT and Grams throttle body 86Speedy Software Tuning 27 05-05-2017 05:21 PM
