Old 06-23-2019, 11:32 AM   #15
churchx
churchx's Avatar
Drives: 2014 GT86
Especially for just daily driven, non abused, lightly braked, mostly by thickness of rotors left. There might be some abnormal wear, eg. formed deep lip, but that can be machined off, there also might be unevenly bedded deposits of brake material (commonly mistaken/called as "warped rotors" due resulting pulsation/vibration when braking), but those can be cleaned off and brakes properly bedded. More common for tracked brakes, also state of cracks (net of small cracks on surface is normal, simply from heatcycling, what to watch out - deep cracks throughout disk and extended to outer or inner rim).
Nice article on that.
soundman98 (06-23-2019)
Old 06-23-2019, 09:55 PM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
Learn about cars from an older male role model.
i've clearly been using my penis wrong if it's got anything to do with vehicle repair or maintenance.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
Racecomp Engineering (06-24-2019), Spuds (06-24-2019), wparsons (06-24-2019)
Old 06-23-2019, 10:03 PM   #17
becausethexo
Drives: Subaru BRZ 2015 Limited
I took some pictures today. Are these all vented, anything visibly wrong with them?
becausethexo is offline   Reply With Quote
The Following User Says Thank You to becausethexo For This Useful Post:
humfrz (06-24-2019)
Old 06-23-2019, 11:34 PM   #18
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Well, well, how about I take a looky see? I'll gladly teach you hands on how to use it properly to work on cars like a man. I'm joking. Don't get your panties in a bunch.
On no... you got a bit of rust on them. Sorry bro, car is done. Buy a new one. Don't bother selling it. Pour some gas on, light a match and just walk away.
I'm joking.
Those look 100% normal.
If your brakes feel spongy or notice your stoping power is weaker, then you have worn out pads/fluid. Oh FYI if there is any problem, it's always going to be on the inside of the rotors/pads. Looking form the out side never going to spot it. You'll have to jack the car up or take off the calipers.
If you don't trust anyone on the internet( wihich you should) take it to any auto mechanic, Jiffy Lube type place, or even any auto parts store that does oil changes.
But really dude the amount of over reacting over out of warranty brakes is purely comical. But keep it up. You'll get the knowledge one day.
Old 06-23-2019, 11:40 PM   #19
Dorkhedeos
Drives: 2015 BRZ
Those are vented. You can tell because there is a space in between the 2 braking surfaces. If you aren't going to the track, you can most likely continue using these. The only way to be sure is to take a thickness measurement.
Dorkhedeos is offline   Reply With Quote
Old 06-24-2019, 12:49 AM   #20
soundman98
soundman98's Avatar
^correct, though my personal preference is just to replace the rotors while I've got everything apart, they generally cost less than $$100/pr, so it's cheaper then the headache of tearing everything apart to re-do what was just done.
And i would avoid carid.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
MuseChaser (06-25-2019), Spuds (06-24-2019)
Old 06-24-2019, 01:24 AM   #21
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
My opinion, replace the rotors. Could be a trick of the light but it looks like there's a significant lip (and therefore wear) on them already.
Lol I cringed when I saw carid in OP's post. +1 to all of this.
Old 06-24-2019, 01:57 AM   #22
To me, they look OK. If the brakes aren't pulsating, I'd just replace the pads.
Old 06-24-2019, 09:08 AM   #23
becausethexo
Do you have a good suggestion for part(s) if it's rotors + pads.
Is this a fair quote?
"Thanks for contacting us. I would suggest you change the brake pads and rotors together, this will avoid any noise issues from putting new pads on old rotors. The cost to replace the brake pads and rotors is $180+tax including lube, abrasives and cleaners we use during the service. The tires depend on size, but the price to mount and balance ranges from $100-$140 depending on the profile and type."
I hate how bad I am at cars sometimes
Old 06-24-2019, 02:21 PM   #24
HaXx
Drives: jrsc_brz
That seems fair. Theyre definitely not trying to pull the carpet out from under you. Couple hundred for the pads and rotors themselves, plus a couple hundred for labor to put them on.
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
soundman98 (06-24-2019)
Old 06-24-2019, 03:14 PM   #25
wparsons
wparsons's Avatar
Holy crap...
Canadian cars didn't have the option of solid rear rotors, so unless you imported it from Australia (or somewhere else that got the low spec models), you have vented rotors all around.
I just paid ~$250cdn for all 4 rotors, if you're paying $130/rotor you're paying way too much. Don't waste your money on fancier rotors, stainless lines, etc.
I'd bet a lot that all the car needs is front pads. If it doesn't see track or autox time at all you're probably not hard on the rotors, and the rear pads wear much slower under any circumstances (unless you constantly use VSC to keep the car going in a straight line).
Are the fronts making a squealing noise if you just super lightly press on the brake pedal? If not, then you have way more life left than you think.
I'd offer to help look at it for you (and swap whatever parts are needed), but I won't have free time on weekends until August.
These are quality rotors, and stand up to track use just fine. Way cheaper than stock and every bit as good.
Front rotors: https://www.ft86motorsports.com/cent...tor-front.html
Rear rotors: https://www.ft86motorsports.com/cent...ake-rotor.html
For pads, just get stock ones unless these end up being cheaper:
Front: https://www.ft86motorsports.com/brak...rake-pads.html
Rear: https://www.ft86motorsports.com/brak...-fr-s-brz.html
flickr
new2subaru (06-24-2019)
Old 06-24-2019, 03:16 PM   #26
wparsons
wparsons's Avatar
When I went to the dealership, they gave me an invoice quote for front/back discs 4x 131.94 = $526 as well as 4x brake pads, so I assumed this meant they were also indicating my rotors are worn.
Not, they're upselling you on as much as they possibly can.
flickr
Old 06-24-2019, 03:18 PM   #27
wparsons
wparsons's Avatar
See his earlier post... $550ish + tax for rotors, plus pads. This is a $1000+ (pre-tax) service at the dealership easily.
I'll bet a lot that all it needs (if anything) is front pads. $100 and an hour of time.
flickr
Old 06-24-2019, 05:32 PM   #28
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
you tell HER that -
Yeah, that's the point. $5 says her daddy showed her how to work on cars.
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (06-24-2019)
replacing BRZ key/fob brzcountsright BRZ First-Gen (2012+) — General Topics 12 03-13-2020 03:31 PM
Rear Brake Caliper damage; worth worrying about/replacing? EndlessAzure Issues | Warranty | Recalls / TSB 6 09-13-2017 01:11 AM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-25-2013 12:26 AM
anyone have DIY for replacing OEM HU?? mbh1101 DIY (Do-It-Yourself) Guides 2 01-27-2013 01:18 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
