Old 06-18-2019, 01:43 PM   #1
lazyfrs
Drives: 2015 Scion Frs
Need advice
Alright. So I kinda screwed up. I tried drifting for the first time and it didnt go too well. At first glance I could tell I bent my control arm. Upon further investigation my buddies and I found more stuff bent. Tie rod, trailing arm, and upper control arm + ball joint. Purchased those parts and installed them myself. When I took her to get an alignment, they found my subframe has been bent. See link below.
https://imgur.com/a/laXy0yo
What should I do to fix this last problem? The axels are fine and nothing else is messed up down there, except the subframe.
Would it be beneficial for me to unbend it myself with a torch and some hitting power? Replace the subframe myself? Or have it done by a shop?
Subframes are about $250 which isn't the cheapest but this is an expensive mistake that ive come to own up to. Any advice?
lazyfrs is offline   Reply With Quote
Old 06-18-2019, 02:20 PM   #2
maslin
Benz Tech
Drives: 2017 BRZ Premium
Replace it. Subframes are designed to give, like a crumple zone. Do it yourself or pay to have it done, totally dependent on your comfort level.
maslin is offline   Reply With Quote
Old 06-18-2019, 02:52 PM   #3
norcalpb
norcalpb's Avatar
The subframe will also come with bushings. Frankly it’s a really good deal.
Old 06-18-2019, 02:56 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Crashing is not screwing up, it's learning. Make sure you can learn from this, or drifting won't go well for you at any point. It's a positive interaction between a desired result, and an actual result. It's just an expensive hobby, you'll get it!
Do not be discouraged.
Old 06-18-2019, 03:44 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
If you can do it yourself, you can try. It's usually labor that kills you on most services.
Personally, I'd just leave it alone if I could. As long as it is still structurally good (no cracks in the metal beams) and there isn't any rubbing/interference, I would just keep the damaged one on there and regularly monitor it.
How did the alignment turn out? Were they able to dial it back to your desired specs? If the alignment couldn't be corrected, have you considered just upgrading to adjustable suspension components to allow you to dial the alignment in?
EndlessAzure is online now   Reply With Quote
Old 06-18-2019, 05:18 PM   #6
Turbo
Drives: FR-S Turbo
How/What did you hit that did all that damage?
Turbo is offline   Reply With Quote
Old 06-18-2019, 05:43 PM   #7
maslin
Benz Tech
It's not structurally good. When it is hit the mounts collapse and you replace the subframe. That would be the same as crashing the front and only replacing the sheet metal. Fix it properly and move on.
Lesson learned, don't do donuts next to curbs.
Old 06-19-2019, 10:10 PM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Drifting - Not "If" yo crash, but WHEN you crash.
Old 06-20-2019, 05:49 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
Hence why important choosing location where one crashes , to make inevitable mistakes, when learning, cost less. Big parking areas, tracks .. where even if one slides wrong it's not crash, just slide until stop in wide empty area or on grass/snow in runoff area. I had learned it in past in hard way too, except it was on front of car and even much more expensive then for OP.
Old 06-20-2019, 12:59 PM   #10
wparsons
wparsons's Avatar
You'll never get the subframe fixed without a known good jig for it. Just buy the replacement and install it. "Looks close" doesn't work well on things like subframes and suspension components.
flickr
I Need Advice About An Fr-s! DViper0020 Issues | Warranty | Recalls / TSB 13 05-09-2014 10:15 AM
Some IT advice Sivtec Off-Topic Lounge [WARNING: NO POLITICS] 19 05-11-2013 01:46 AM
New guy needs advice Apexer Tracking / Autocross / HPDE / Drifting 28 05-04-2013 03:53 PM
I need some advice The Robot Cow Scion FR-S / Toyota 86 GT86 General Forum 16 04-06-2013 03:43 PM
