Old 06-15-2019, 05:39 PM   #463
You got this. Keep us posted.
Old 06-17-2019, 12:56 PM   #464
ninjabutt
Drives: White BRZ 2014
Lol thanks. No new info on ILVs and I still can't clear the u0155 code. New ECU calid is za1jd00c and some of my research says that that calid is for 2015 cars only and I may need to reflash to b01c/d (for my 2014). Any info on how likely that is? I have a friend that lives not too far from here that I may be able to link up with and get him to reflash the ECU with proper calid but it's not real close so I'm hoping to not waste the time getting it done.
ninjabutt is offline   Reply With Quote
Old 06-17-2019, 01:47 PM   #465
Help us, @steve99. You're our only hope.
Old 06-17-2019, 02:19 PM   #466
ermax
ermax's Avatar
According to Steve all the ECUs are the same. You can flash any calid you want and be fine. I’ve seen him confirm this several times.
Old 06-17-2019, 03:29 PM   #467
ninjabutt
My local guy, was a master tech at the Toyota dealership for years said you can't go backwards in ECU updates, at least not with techstream unless there's a way to trick the ECU into thinking the older calid is the update.
He also said all the different calids have different communication protocols which may be why I'm throwing the code.
If that's all true, I probably won't buy another ECU to check and will likely instead swap out the cam gear, swap my old ECU back in, and then watch the ILVs to see if bank 1 starts to come back up into spec, clearing codes each time. Any other options or info are welcome
Old 06-17-2019, 04:43 PM   #468
ermax
ermax's Avatar
That may be true when flashing with "Techstream" but flashing with other tools you can flash any calid you want onto any ECU you want. You just need to make sure it's a calid that is compatible with your car.
Old 06-17-2019, 06:06 PM   #469
steve99
Drives: FT86
Yes all ecu hardware is same you just need correct calid
D00C will cause a U0155 dash cluster comms error if that calid is used in a pre 2015 car ie like your 2014, the car will run fine you jist get the odd cel code.
Just get your mate to flash it back to B01C and you will be fine
callisto (03-11-2026)
Old 06-17-2019, 06:39 PM   #470
ninjabutt
Ok cool, just for information relative to the thread (or for an opportunity to receive corrective information lol) the u0155 seems to put me in full limp mode not allowing RPMs over 3500
Old 06-17-2019, 08:38 PM   #471
steve99
Drives: FT86
Yes correct it sets limp mode, i know from when i tried 2015 roms in my 2013 car 4 years ago :-)
Ultramaroon (06-17-2019)
Old 07-09-2019, 07:55 PM   #472
ninjabutt
So I put the 2014 ECU back in because my toy car budget is all being spent on the drift kart I'm building and I should be able to get most of the information I wanted out of this ECU with techstream, I just won't have the luxury of driving without resetting CEL codes. Sooo, I've been periodically checking the ILVs and neither of the I take values have changed. Bank 1 is still out of spec but hasn't fallen any further and there is no change in bank 2 after probably 600 miles (exhaust numbers are both slightly different though). This increases the likelihood that I won't swap bank 2 preventatively. Future me might call me an asshole for this decision, but now me will have $200 to send less future me to the drift event for my birthday. I will report back anything interesting if it comes up. Picture of drift kart for tax
The Following User Says Thank You to ninjabutt For This Useful Post:
bcj (07-10-2019)
Old 07-27-2019, 07:53 PM   #473
69gtojeff
Drives: 2013 FR-S 6MT Ultramarine
I bought an early production 2013 FR-S MT from the original owner almost 2 years ago with 48K miles on it. Car is totally stock and used as a daily driver during the non-road salt months. A few months ago the car had about 65K and my wife filled it with 87 octane gas. I was burning it off the next day hoping to get down to about a half tank so I could top it off with premium. I was running it through the gears about 1/2 throttle shifting around 5500 rpm when I got the CEL/skid light combo. I did the fuel thing and probably ran a full tank of premium through it before checking the code because I figured the knock sensor just pulled timing from low octane and everything would be happy after 20 key starts or however many it takes for the light to go off after a fault is inactive. Code is P0018 and the limp mode power reduction is hardly noticeable while obeying traffic laws. Drifting in the rain is still an option though. I swapped cam position sensors and the code didn't go along for the ride. As I sit here typing, I guess I should have swapped ocvs also...
Car now has 69K and at the Toyota dealer for valve spring recall. I agreed to pay list price for parts if they were installed during the valve spring job. Started out as sparkplugs and now I'll also have a shiny new waterpump and serpentine belt. When I dropped it off I said there was an active P0018 and they should inspect the camshaft actuators while the cams were out. I also asked them to reflash with current software because the windows for setting P0018 have been opened up after 2013.
I received a voicemail Thursday that my car was back together and it drove fine. They had done the reflash and P0018 came back during the test drive. They said they could replace the bank 2 exhaust actuator for $618.31 + tax and wanted to know how I would like to proceed. I called back Friday and said I don't need the car this weekend and we'll talk more on Monday when the head service writer and technician who did the work will both be in. Bank 2 exhaust would be P0019 for those still following along. The last thing I want to do is drive it away from the dealer with a CEL and have it explode 5 miles down the road due to debris in the oil.
After plenty of reading on this forum over the last couple days, I see that I'll be buying an ecu to solve my P0018. Is $500 too cheap and I should expect closer to $600? The list price agreement is off the table going forward.
I'm going to insist on seeing the camshaft learning values on their techstream before throwing any parts at it. Assuming the camshaft actuator didn't pop a spring, will the learning values in my old reflashed ecu be between 52-72 intake and 78-98 exhaust? If the cams move together during an rpm sweep, are the actuators fine? Do the cams move primarily due to engine rpm or does load have an influence?
69gtojeff is offline   Reply With Quote
Old 07-27-2019, 08:26 PM   #474
Reflash will not reset those values.
I don't know if these codes are exclusively caused by jammed spool valves but that is my experience.
If it was mine, I would disassemble and clean all the phasors. I'd also replace the OCV filters and blow the shit out of those passages with compressed air.
Old 07-27-2019, 10:57 PM   #475
69gtojeff
It's all assembled at the dealer with a P0018 waiting for my call for the next move. I totally agree with your plan of attack if I was working on my car in my garage.
Old 07-27-2019, 11:54 PM   #476
kinghurl
Drives: BlueBurz
I'm surprised they didn't recommend an ecu change when they quoted you. Without the ecu it will eventually reset learning values if the OCV is replaced, but it could take 5K miles. If you don't do the ecu then yes ask to see the learning values to see if they're changing. If not do the ecu next.
Sent from my SM-G930V using Tapatalk
kinghurl is offline   Reply With Quote
P0016 fixable without new ECU? Mr.Jay Issues | Warranty | Recalls / TSB 8 02-06-2022 05:15 AM
P0016/P0017 cause AVOturboworld Issues | Warranty | Recalls / TSB 18 04-16-2021 11:09 PM
P0016 Code Shady195 Engine, Exhaust, Transmission 30 02-21-2019 02:31 PM
p0016 need help asap lol Issues | Warranty | Recalls / TSB 25 10-30-2018 03:49 PM
OFT P0016 and TSB question mmmcambelsoup Software Tuning 10 05-24-2017 09:24 AM
