Old 06-15-2019, 05:26 PM   #1
tay.green
Drives: Toyota 86 2018 Halo
2016 Scion FRS Spec D Headlight Rewire: 6 pin to 8 pin
Hey guys, I own a 2016 Scion FRS and am having some trouble with getting my new Spec D headlights to work (with the rewire).
So coming out of the body of the car there is the 8 pin connector and it comes with these wires:
1. Tan
2. NA
3. NA
4. Black
5. Blue
6. Black / White
7. White / Blue
8. Black / White
The Spec D Headlights come with the 6 Pin Connector but only 4 of the 6 pins are being used:
1. NA
2. NA
3. Red / Black
4. Blue
5. Blue / Black
6. Red
From digging through other forums I've found the Spec D Headlights mean this:
3. Red / Black: Motor (-)
4. Blue: Headlight (+)
5. Blue / Black: Headlight (-)
6. Red: Motor (+)
From my understanding the Spec D wires should go into the 8 pin connector as such, but it isn't working:
1. Yellow - turn signal
2. NA
3. NA
4. Black - both grounds
5. Blue
6. Blue / Black
7. Red
8. Red / Black
Does anybody know what the wires from the 8 Pin Connector coming out of the body of the FRS mean and which wires they would connect to on the Spec D Headlights? If I know which connects to which I could be done with this night mare.
Any information would be helpful, thanks.
tay.green is offline   Reply With Quote
Old 06-15-2019, 10:20 PM   #2
TheeIrishGuy
MJLONIR Project Member
TheeIrishGuy's Avatar
Drives: '14 White Scion FRS
I personally don't remember when I did mine (had a mechanic friend help me install), but did some research myself when I was setting up.
https://www.ft86club.com/forums/showthread.php?t=118864
[ame]https://www.youtube.com/watch?v=UWvbE09Zhsk[/ame]
Hope this helps!
TheeIrishGuy is offline   Reply With Quote
Old 06-16-2019, 01:31 PM   #3
tay.green
Hope this helps!
Yeah I tried both this video and that thread before posting, however the frs in the video already has a 6 pin, so the headlights are plug and play. And the other thread doesn’t have the correct wiring for the frs :/ that’s what has me in such a bind.
It could be because mine is the release series 2.0 and they may have done the headlight wiring differently than the base model frs. It’s just been a struggle the past week trying to figure it out.
Old 03-30-2020, 09:51 PM   #4
beyondjv
Drives: 2015 Scion FR-S TRD
8 pin to 6 pin
Sorry to bump an old thread , but have you figured it out because i’m in the same boat. My car has a 8 pin and the headlights have a 6 pin.
beyondjv is offline   Reply With Quote
WTB 2012-2016 BRZ Right Headlight! Olson1288 Want-To-Buy Requests 4 01-13-2017 02:29 PM
Spec-D headlight DRl Mod amngmac Cosmetic Modification (Interior/Exterior/Lighting) 4 01-30-2016 02:50 PM
WTB Spec D headlight mythhelios1 Want-To-Buy Requests 1 09-22-2015 05:42 PM
Spec d headlight. Chen Cosmetic Modification (Interior/Exterior/Lighting) 20 07-21-2015 04:10 AM
Drl rewire to headlight Brianbajnauth Scion FR-S / Toyota 86 GT86 General Forum 0 01-27-2014 12:25 AM
