Old 06-15-2019, 12:51 PM   #15
juniorrr
Drives: Scion Frs
Originally Posted by Turdinator View Post
Yes it would be the biggest restriction you have at the moment.
If you want louder get an exhaust shop to make a track pipe with a vband that connects to the perrin midpipe. I suspect that won't give you much power at all and will add rasp and drone.
As mentioned above, drop the rear muffler off and see how it sounds. Just be careful how much you drive it like that tho as people have melted rear bumpers by autocrossing without a muffler or track pipe.
About how much benefit do you think i'd get from getting an OP? The thing about the connection points for the perrin Exhaust they are only able to use the Vband Clamps from Perrin. I've tried others and they just don't fit correctly and cause an exhaust leak. So thats another issue i have, if they were to put a Y pipe that connects with the perrin mid pipe i was wondering if that was going to be an issue because i'd have to get a y Pipe that has a flange on it which most people dont carry. Yeah ima take it off and see how it sounds. I just hate taking this Perrin V band clamp off cuz alot of ppl have issues with them breaking.
juniorrr is offline   Reply With Quote
DIY Resonated Muffler Delete ButtonMasher Engine, Exhaust, Transmission 18 06-22-2020 10:08 PM
Perrin Catback muffler delete? IAmNotTheDriftKing Engine, Exhaust, Transmission 5 02-07-2014 11:18 AM
Works AB-R Resonated Axle Back Muffler Delete cdo221 Engine, Exhaust, Bolt-Ons 20 03-22-2013 02:24 AM
Works Resonated Muffler Delete touge-n00b Hawaii 3 02-22-2013 04:03 AM
Muffler Delete + Perrin Drop-in Filter SkitterSkotter Engine, Exhaust, Transmission 20 10-10-2012 01:23 PM
