Old 05-22-2019, 09:54 PM   #1149
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by James Russels View Post
Thanks. Maybe the instruction I saw wasn't to wait until it was completely cured, but to give it a few minutes before tightening. The way I understood it was that immediately tightening the pan all the way would cause the sealant to smush out instead of being where it needs to be to make the seal.
I was also considering installing an oil baffle while I have the pan off, as a means of future-proofing. Any opinion on this?
I don't see the need for an oil baffle, from what I've read it's not an issue that you need to be concerned with unless you're a serious track rat that can actually drive and has grip. The sealant smooshing out is in your control, applying a bead too thick is what causes that, it's not about a cure time. Others may be better able to comment on the baffle though.
Old 05-23-2019, 01:06 AM   #1150
James Russels
Drives: 2013 FRS
Basically if there is at least some benefit and no downsides (aside from cost) to the baffle, I'd rather just go ahead and install one while I have the pan off, even if it's unlikely I'll need it.
James Russels is offline   Reply With Quote
Old 06-06-2019, 05:14 PM   #1151
WC-BRZ
Drives: Black BRZ
Very long thread to get through!
Curious about how everyone's been dealing with heat issues in everyday traffic as this is a front mounted kit - melting fans, melting lines, etc.
I have gone through the other heat management thread (quite long) and it seems even with ceramic coatings, wraps and blankets, heat is a major issue (especially in stop and go traffic).
WC-BRZ is offline   Reply With Quote
Old 06-06-2019, 05:33 PM   #1152
OzzyGT86
OzzyGT86's Avatar
Drives: Ultramarine GT86
Honeslty I haven’t had ANY issues with heat. I’m not even running slim fans or a shroud. My cooling mods are 16 row Setrab oil cooler mounted behind fog light insert, koyo upgraded RAD, no front grill thing, and no windshield wiper insert ( behind the hood going up to the windshied) so basically there’s a lot of heat extraction going on.
OzzyGT86 is offline   Reply With Quote
Old 06-07-2019, 02:35 PM   #1153
jRuN
Hello errybody!
As a web developer.. i'm disappointed when i go to JDL's website and see they are still selling their kit via a black friday sale..
I was trying to see what version of their kit they are on.. V2 ? V3 ? What is the most current kit version now? What is the difference between v2/v3 if there is a v3?
I can't trust their website to have updated info!
jRuN is offline   Reply With Quote
Old 06-07-2019, 03:55 PM   #1154
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Originally Posted by jRuN View Post
Hello errybody!
I ordered through 86speed. They often phone home to JDL to get the most current offerings. Their website is a bit more updated too. Staff there was very helpful. I would give them a call and see what's up.
Jesse36m3 is offline   Reply With Quote
The Following User Says Thank You to Jesse36m3 For This Useful Post:
Conman (06-15-2019)
Old 06-07-2019, 08:50 PM   #1155
r3myx626
r3myx626's Avatar
Drives: 2015 Subaru BRZ Limited ISM
If it's a street car you shouldn't have much issue. Add an oil cooler and you're set. I have yet to see a problem on street with high 80s/low 90s degree weather. I'm running slim fan shroud, a turbo blanket, and oil cooler, and ceramic coating.
r3myx626 is offline   Reply With Quote
Old 06-07-2019, 10:57 PM   #1156
Marx
Marx's Avatar
Drives: '13 Lava FR-S 6MT
Got a question for anyone that has the GTX2860R - I get compressor surge and that fluttery sound under basically any circumstance other than hard pull and shifting, it seems like it takes a good second for the line to go from +7lbs (or less) to the -9 needed to pull the blowoff valve open. Is this normal or do I need to drive more gently / change something vacuum-related?
Marx is offline   Reply With Quote
Old 06-09-2019, 10:16 PM   #1157
James Russels
Drives: 2013 FRS
Hello errybody!
The differences I'm aware of is that version 3 has a larger intercooler (for 500+ WHP) and the option for the G25-550/ G25-660. Double check with the vendors though.
Old 06-10-2019, 11:58 AM   #1158
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Sounds like you need to adjust your BOV. Should be just tight enough to stay closed at idle. Anything more and it's set too stiff.
The Following User Says Thank You to ATL BRZ For This Useful Post:
Marx (06-14-2019)
Old 06-14-2019, 02:37 AM   #1159
Marx
Marx's Avatar
Heck, I have that thing unscrewed as far as the indicator they say not to go past. Might try to give it a couple more turns though, thanks.
Old 06-15-2019, 11:40 AM   #1160
Conman
Conman's Avatar
Drives: Red FRS
Parts have arrived.
Conman is offline   Reply With Quote
Old 06-15-2019, 01:44 PM   #1161
WC-BRZ
Drives: Black BRZ
Originally Posted by Conman View Post
Parts have arrived.
Duuude! That must feel so good! Are you all giddy inside?
When is everything going in? Dyno tune or e-tune?
Edit: do you have a build thread?
Last edited by WC-BRZ; 06-15-2019 at 01:45 PM. Reason: I like to go on and on and on and....
The Following User Says Thank You to WC-BRZ For This Useful Post:
Conman (06-15-2019)
Old 06-15-2019, 02:20 PM   #1162
Conman
Conman's Avatar
Drives: Red FRS
Yeah I cant wait for that boost! I've been planning this for like a year and finally was able to pull the trigger... I'm having a local performance shop help me install everything starting next week!. Delicious E-tune. I paid for the flash-and go tune anyways, but the shop has a Dyno and says they could tune it... https://www.ft86club.com/forums/showthread.php?t=134692
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
