Old 05-29-2019, 05:04 AM   #1
Alastor
Alastor's Avatar
Drives: Toyota gt86 my19
Hdd and SSD Pioneer
Hi
What hdd or SSD works with avh Pioneer radios?
Thanks
Alastor is offline   Reply With Quote
Old 05-29-2019, 11:38 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
not many.
from their site:
USB memory devices and USB hard disks in FAT16, FAT32 or HFS+ format are supported.
NTFS is not supported
most drives are not FAT16 or FAT32.
Old 05-30-2019, 02:17 AM   #3
Alastor
Alastor's Avatar
not many.
from their site:
But you can to format on FAT32
The Following 2 Users Say Thank You to Alastor For This Useful Post:
soundman98 (04-03-2022), wparsons (06-14-2019)
Old 05-31-2019, 12:54 AM   #4
soundman98
soundman98's Avatar
not always. i had to try 3 different ssd's to find one that can work.
Old 05-31-2019, 02:31 AM   #5
soundman98
soundman98's Avatar
Oh, and before i forget, there is a size limit somewhere that they don't like to talk about. I want to say its somewhere near 250gb. I'm running an 80prs(also ran a 3500avh) with a 120gb ssd, and it takes a good 2 minutes for music to start playing most times.
Old 05-31-2019, 04:33 AM   #6
Alastor
Alastor's Avatar
Uff. Thanks you.
I hope that the avh-z9100 works fine
Old 06-14-2019, 05:26 PM   #7
wparsons
wparsons's Avatar
The drive itself is completely agnostic to the filesystem being put on it... that sounds like a different issue, or user error.
Windows disk management has a limit of 32gb for FAT32 partitions, but you can bypass it quite easily and get up to 2TB partitions. There is a hard ~4gb file size limit on FAT32, but I doubt that's an issue unless you're putting high bit rate video rips on the drive to play in the car.
https://www.makeuseof.com/tag/format...ive-fat-fat32/
flickr
j3rf (06-14-2019)
Old 06-14-2019, 09:41 PM   #8
soundman98
soundman98's Avatar
some of the drives i tried could not be formatted in fat32. my computer did not give me any option for those drives for anything other than NTFS.
Old 06-18-2019, 11:26 AM   #9
wparsons
wparsons's Avatar
How big were they? Did you see the article I shared about how windows disk management has a hard cap of 32gb for FAT32? That's a windows constraint, not an issue with the drive.
flickr
Old 06-19-2019, 11:54 AM   #10
Alastor
Alastor's Avatar
Hi
A friend saw me that the avh-z9100dab works with NTFS perfectly. I will to try when have the radio.
Old 04-03-2022, 04:59 PM   #11
dennnewt
Drives: Toyota
Because of the fast rotation of the hard drive, it isn't quiet and vibrates, but it is not so noticeable against the background of other sounds. The hard drive is also more massive than the SSD. It is sensitive to vibration and shock. In general, hard disk recording is an older technology: hard disks are cheaper than SSDs in terms of price per gigabyte. If it burns out, the main advantage of it is that you can recover the data at salvagedata.com. As far as SSDs are concerned, things are very complicated there.
dennnewt is offline   Reply With Quote
Pioneer NEX Alabang BRZ Electronics | Audio | NAV | Infotainment 5 08-24-2014 12:53 PM
