Old 08-06-2014, 08:56 PM   #1
Alabang BRZ
Pioneer NEX
Looking forward to getting the first Apple CarPlay head unit from Pioneer's NEX line. AS I will be buying it from the US and shipping it back to the Philippines I'd need to know what other parts I'd need to get to complete the setup on my BRZ.
AVIC-8000NEX
AVIC-7000NEX
AVIC-6000NEX
AVIC-5000NEX
AVIC-4000NEX
Firmware upgrade should be identical to the one for the Hyundai Sonata video.
[ame]http://www.youtube.com/watch?v=_F4kQMRQdfM[/ame]
Alabang BRZ is offline   Reply With Quote
Old 08-07-2014, 12:07 AM   #2
cnk
Drives: '13 DGM BRZ Limited
I used the following for my 8000NEX install:
Wiring Harness - Metra 70-1761 Receiver Wiring Harness Connect a new car stereo to the factory wiring in select 1987-up Toyota, Lexus, Scion, Subaru, and Geo vehicles at Crutchfield.com
USB adapter - Metra AX-TOYUSB Cable for Toyota and Lexus Allows you to connect the factory USB port on select 2012-up Toyota and Lexus vehicles to a new car stereo at Crutchfield.com
Antenna adapter - Metra 40-LX11 Antenna Adapter Connect a new car stereo to the factory antenna select 2009-up Toyota, Lexus, Scion, and Subaru vehicles at Crutchfield.com
Dash kit - Metra 95-8202 In-dash Receiver Kit Fits select 2000-up Lexus, Scion, and Toyota vehicles — double-DIN radios at Crutchfield.com
The dash kit is not a perfect fit. You'll have to notch out a bit of plastic, but it isn't bad and not noticeable once everything is mounted.
cnk is offline   Reply With Quote
Old 08-07-2014, 05:50 PM   #3
Alabang BRZ
Thanks cnk. Are you an iPhone/iPod Touch/iPad owner? Will you be upgrading your 8000NEX's firmware to CarPlay?
Also is your 8000NEX 200mm wide?
Old 08-07-2014, 10:12 PM   #4
cnk
Don't have anything from Apple. Don't like them. I'll probably still upgrade the FW just in case there are any other improvements.
IIRC, 200mm wide would be the perfect fit, but there are very few that are that wide. All the NEX units are 190mm I believe and that's why you need the dash kit which provides some black plastic to fill in the gaps on either side.
Old 08-15-2014, 09:36 PM   #5
TRD_86
Drives: 2013 86 white
Today car makers never work with aftermarket caraudio brands to establish a certain standard headunit sizes. This is the worst era of car audio since the smartphone and tablet have been on the market.
TRD_86 is offline   Reply With Quote
Old 08-24-2014, 11:53 AM   #6
Alabang BRZ
DIN is an industry standard started by the Germans.
AUX in BRZ's Pioneer HU ? Simon99 CANADA 10 05-28-2014 02:22 AM
[FS] Pioneer AVH-P1400DVD ProTekk Audio/Visual, Electronics, Infotainment, NAV 0 11-07-2012 08:48 PM
