Old 06-13-2019, 12:18 PM   #1
brzboy
Drives: 2016 brz limited
To much oil
Recently I took my car to the Subaru dealer to Have the oil changed. And checking the dipstick about two months later I realized is past to full mark by a little. Is this bad ? It’s like 3/4 of an inch over.
Thank You!
brzboy is offline   Reply With Quote
Old 06-13-2019, 12:49 PM   #2
Grady
Grady's Avatar
No.
Old 06-13-2019, 12:50 PM   #3
StraightOuttaCanadaEh
Wes
Nah, this dipstick does that all the time. Check both sides and it's at whatever the lowest side is
Instagram: @gt86ws
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
churchx (06-13-2019), Spuds (06-13-2019)
Old 06-13-2019, 12:51 PM   #4
brzboy
Of the dip stick ?
The Following User Says Thank You to brzboy For This Useful Post:
Spuds (06-13-2019)
Old 06-13-2019, 01:06 PM   #5
maslin
Benz Tech
Drives: 2017 BRZ Premium
Originally Posted by brzboy View Post
Of the dip stick ?
Engine. There's two dipstick holes, use the one that reads lower.
maslin is offline   Reply With Quote
The Following 2 Users Say Thank You to maslin For This Useful Post:
BigTuna (06-13-2019), NoHaveMSG (06-13-2019)
Old 06-13-2019, 01:22 PM   #6
Wes
Of the dip stick ?
yes
Instagram: @gt86ws
Old 06-13-2019, 03:42 PM   #7
brzboy
Where is the other one ?
fika84 (06-13-2019)
Old 06-13-2019, 04:08 PM   #8
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
i always clean my dipstick, put it in pull it out and then read the lowest part. it likes to splash around and read real high for some reason
Old 06-13-2019, 04:25 PM   #9
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Looking for itself apparently...
(There is a single dipstick, with 2 holes in it. Procedure is pull dipstick, wipe it off, put it back in, pull it again and read it. If it still reads high, above the upper hole, then it's a bit overfilled. I wouldn't be too worried unless the overfilling is greater than the distance between the two holes.)
The Following 4 Users Say Thank You to Spuds For This Useful Post:
brzboy (06-13-2019), maslin (06-13-2019), soundman98 (06-13-2019), Ultramaroon (06-13-2019)
Old 06-13-2019, 04:32 PM   #10
Lesson 1: Check the oil after the change before driving off of the lot. What if it really was way overfilled by some noob sloppy tech? Trust no one.
Lesson 2: RTM. Flat-four engine collects oil under the valve covers. Takes a long time to drain back to the pan. Sometimes people don't wait long enough and, thinking it's low, top off unnecessarily.
I don't know how much extra is the limit but it's a lot. I wouldn't sweat it.
fika84 (06-14-2019), humfrz (06-14-2019), Spuds (06-13-2019)
Old 06-13-2019, 06:00 PM   #11
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Meh, I'll just buy a shorter dip stick. That way it would read normal.
Then when the oil gets too low I'll buy a longer one.
See? Problem solved.
The Following User Says Thank You to Mr.ac For This Useful Post:
brzboy (06-13-2019)
Old 06-14-2019, 10:48 AM   #12
fika84
fika84's Avatar
...Trust no one...
Period. Done.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Ultramaroon (06-14-2019)
