Drives: 2016 brz limited
To much oil
Recently I took my car to the Subaru dealer to Have the oil changed. And checking the dipstick about two months later I realized is past to full mark by a little. Is this bad ? It’s like 3/4 of an inch over.
Thank You! Sent from my iPhone using Tapatalk Last edited by brzboy; 06-13-2019 at 12:58 PM. |
#2 |
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
No.
#3 |
Wes
Nah, this dipstick does that all the time. Check both sides and it's at whatever the lowest side is
Instagram: @gt86ws
#4 |
#5 |
Benz Tech
Drives: 2017 BRZ Premium
#6 |
Wes
Instagram: @gt86ws
#7 |
#8 |
Drives: 2017 BRZ w/PP
i always clean my dipstick, put it in pull it out and then read the lowest part. it likes to splash around and read real high for some reason
#9 |
The Dictater
Drives: '13 Red Scion FRS
Looking for itself apparently...
(There is a single dipstick, with 2 holes in it. Procedure is pull dipstick, wipe it off, put it back in, pull it again and read it. If it still reads high, above the upper hole, then it's a bit overfilled. I wouldn't be too worried unless the overfilling is greater than the distance between the two holes.) |
#10 |
Lesson 1: Check the oil after the change before driving off of the lot. What if it really was way overfilled by some noob sloppy tech? Trust no one.
Lesson 2: RTM. Flat-four engine collects oil under the valve covers. Takes a long time to drain back to the pan. Sometimes people don't wait long enough and, thinking it's low, top off unnecessarily. I don't know how much extra is the limit but it's a lot. I wouldn't sweat it.
#11 |
[insert cool phrase here]
Drives: BRZ Premium
Meh, I'll just buy a shorter dip stick. That way it would read normal.
Then when the oil gets too low I'll buy a longer one. See? Problem solved.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#12 |
